Riser step - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-08-2013, 09:17 PM - Thread Starter
johnnybwis's Avatar
I'm currently working on a riser in my basement theater room. Due to lack of ceiling height it is a 2x4 on edge with 3/4" plywood decking.The main area where you would step up is fine and I will do bull nose overhang and have the carpet tucked around the overhang. I'm not sure what to do with the front area of the riser. There will be a cove area in the riser for a smaller sized couch with a step down on either side. Problem is due to the basement floor being pitched towards a drain that riser step has only 2" on one side & 1-3/4""of 2x4 height on the other. Do I even want to overhang the decking or would I just be creating a toe buster. If I do overhang will the carpet guy have room to wrap around?
johnnybwis is offline
post #2 of 5 Old 03-09-2013, 07:15 AM
design1stcode2nd's Avatar
Quoted: 31 Post(s)
Liked: 44
A picture might help illustrate it for us. My first thought is 4 1/4 inches of riser isn't going to be enough for your back row to see over your front row. I'm assuming you have two rows since you are building a riser.
Play like a Raven
design1stcode2nd is offline
post #3 of 5 Old 03-09-2013, 09:26 AM
Quoted: 3256 Post(s)
Liked: 2743
In case you haven't stumbled across the concept when you have a headroom issue and need to raise the height of the second row, you can also add a booster riser just under the base of the seats. When standing it isn't a factor but when seated you get the benefit. Carpet to match the riser and no one will notice it. You can experiment with finding an acceptable height by putting some temporary blocks under the base.
post #4 of 5 Old 03-09-2013, 10:53 AM - Thread Starter
johnnybwis's Avatar
I'll have to look at that. I guess I consider the seating in front as overflow seating. Just a low inexpensive couch. I should really mock something up just to be sure on the line of sight.
I'm mostly concerned on how to handle that step that will be about a total of 2-3/4 inches high. Do I just make it square or over hang the decking like you would for a stair tread. Or maybe make it a ramp?
post #5 of 5 Old 03-09-2013, 12:24 PM
Liked: 2743
I think square is going to work the best. The carpet installer needs to get his stapler head under a lip, So any kind of really low lip will be nearly impossible to fasten.
