Wood floor in projection room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-10-2013, 03:40 PM - Thread Starter
sbbamafan's Avatar
Our carpet it pretty worn where our projector is. I would like to have a wood floor in the room (it is my man cave). I have some material left from a project that will do the room. It is a prefinished very dark material. I laid a bunch of it out in the room and 'tested'. I like the color being darker than the old carpet but there is more reflection with the floor. Also, I realize there could/will be acoustic issues. In my 'test' it wasn't bad though. I appreciate your thoughts and knowledge.
sbbamafan is offline
post #2 of 5 Old 03-10-2013, 06:28 PM
sebberry's Avatar
Quoted: 26 Post(s)
Liked: 30
Is this a "general purpose" room or more of a dedicated theater room? You could always get a nice area rug to put on top of it where you'll be dealing with some reflections.
If you're looking for an all-dark room with little echo, then a hardwood floor isn't a good choice.
sebberry is offline
post #3 of 5 Old 03-10-2013, 07:10 PM - Thread Starter
sbbamafan's Avatar
It is mostly 90% for watching sports. Yes - I thought of the area rugs and that seems to be a pretty popular choice.
post #4 of 5 Old 03-11-2013, 05:25 AM
RTROSE's Avatar
Quoted: 192 Post(s)
Liked: 167
I would put down the wood, buy a nice area rug to treat reflections and not look back. My .02 worth.
RTROSE
RTROSE is offline
post #5 of 5 Old 05-11-2013, 08:51 PM
rabident's Avatar
Quoted: 333 Post(s)
Liked: 107
I would like to do hardwood as well. Why is wood a problem on the floor, but not the walls?
If it's due to reflections, how much absorption does carpet and a pad really absorb? Carpeting the walls is frowned on because of the high frequency absorption. Why is it ok / desirable to apply that same skewed high frequency absorption to the entire floor?
rabident is offline
