The Moving Pictures Theater Construction Thread - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 13Likes
Old 04-10-2014, 01:29 PM
design1stcode2nd's Avatar
Quoted: 31 Post(s)
Liked: 44
Fantastic space, love the wood work.
avtexan likes this.
Play like a Raven
design1stcode2nd is offline
Old 04-11-2014, 09:55 AM - Thread Starter
avtexan's Avatar
Quoted: 47 Post(s)
Liked: 89
The WAF for my HT project went from a 1 to a 10 today. I spent most of last night cleaning up the gameroom and 2 bedrooms that I had taken over with tools, boxes and trash.
1 full load for the dump and another load that I am sure the garbage men are going to be happy about on a Friday.
thrillcat likes this.
The Moving Pictures Theater Construction Thread:
http://www.avsforum.com/t/1462881/th...ruction-thread
Houston GTG - Summer 2014
http://www.avsforum.com/forum/61-are...l#post26079610
avtexan is offline
Old 04-11-2014, 11:55 AM
Nightlord's Avatar
Quoted: 712 Post(s)
Liked: 237
I hope you checked the weather service....
Under construction: the Larch theater
Nightlord is offline
Old 04-13-2014, 11:30 PM - Thread Starter
avtexan's Avatar
Quoted: 47 Post(s)
Liked: 89
I have been working on the HT with every last spare minute over the last couple of weeks to get ready for Master's Weekend.  I had some family come in town to watch the Master's and everybody really enjoyed the space. I am not sure what cameras CBS use but the visuals were stunning.  You could see every blade of grass.  I also played some of the demo disks and the room sounds much different with the panels.  I still need to do some tweeks and will dial everything in further when I get it calibrated on the 23rd.
I have made some good progress and I am down to some misc odds and ends.  I finished all of the track and fabric up front.  I did not cut the fabric for the piece under the screen yet.  I will do that after calibration.  I wanted to leave the bottom support off in case we need to get back there for anything.  I put up a piece of scrap GOM for a temporary solution.
I will take a couple of days off and then get back to work and finish everything up.
Thanks for all of the help and support over the last month!
Screen Wall track is done
I am very happy with the FR701 fabric.  It looks like Burlap in the sample but looks much better when stretched and there is not any light behind it..
avtexan is offline
Old 04-13-2014, 11:38 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 938
Looks great!
Are you going to hide the speaker wire? I might suggest gaffers tape to cut down on possible reflections from white wire......
doublewing11 is offline
Old 04-13-2014, 11:52 PM - Thread Starter
avtexan's Avatar
Quoted: 47 Post(s)
Liked: 89
Originally Posted by doublewing11 View Post
Looks great!
Thanks.  Good thought on the gaffers tape.  I have that on the list to do before I install the bottom support and fabric.
avtexan is offline
Old 04-14-2014, 01:23 AM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
A roll of TechFlex would work, too, and doesn't tie everything down.
jautor is offline
Old 04-14-2014, 06:08 AM
DavidK442's Avatar
Quoted: 509 Post(s)
Liked: 341
Absolutely beautiful!
avtexan likes this.
DavidK442 is online now
Old 04-14-2014, 12:14 PM - Thread Starter
avtexan's Avatar
Quoted: 47 Post(s)
Liked: 89
One of the reasons for the extra wire behind the stage was the pull I made for the 12/2 was not long enough to put the speakers outside of the screen. I originally thought they would be inside of the screen and I did not order enough wire, rookie mistake!
To get everything running I installed a box with banana plug connectors with screw terminals on the back of the plate. I used some heavy duty cables from a prior setup to go from the box to the LCR's.
I am not happy with the added connectors so I will want to get rid of the box. I was going to order some extra wire and soldier a splice with the old wire to extend it. Is this what you guys would do or something else? Do you recommend terminating the ends or using bare copper to connect to the a Triads?
Also, I should have some extra black FR701 and will cover the treatments behind the screen. I can't see anything now but I guess it's better to be safe than sorry.
avtexan is offline
Old 04-14-2014, 12:34 PM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
Yes I would solder it. That is what I did. More of a garuntee that if something in the chain were to mess up that it wouldn't be the solder point. Put some heat shrink over it and all will be good.
Mfusick likes this.
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
Old 04-16-2014, 01:25 AM - Thread Starter
avtexan's Avatar
Quoted: 47 Post(s)
Liked: 89
I had a chance to re-run a full Audyssey analysis post Quest panels tonight.  I also ran some fresh REW graphs.
I am really glad I spent a fair amount of time in the room without treatments.  I was able to tell that it is a night and day difference with the Quest panels!!  I am VERY excited about how the room sounds now.:)   I played a bunch of my favorite songs through my NAD DAC and was enjoying it immensely.  The room sounds much bigger and the soundstage is WIDE.
Before on tracks that had a bunch of instruments playing at the same time (Dave Matthews) it was all smeared together.  Now you can hear each one.  I was running 2.1 but had to keep checking the pre/pro to make sure it was in stereo because it sounded like the side and rear speakers were on, they were not.
The bass is really tight and accurate  It was much boomier before.  I have to give another thumbs up to my Seaton Subs.  You really cant drive those things to hard.  I am running them fairly hot but it sounds great to me.
I can't wait for next week when I will add a miniDSP and have Jeff Meier calibrate the room.  I know he can make it sound even better.
Thanks Scott for all of your help with the Quest products!
avtexan is offline
Old 04-16-2014, 08:26 AM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
You are very welcome. It's amazing what that stuff does to a room when it's engineered by the HAA Master. I've enjoyed working on your whole project, nice to see in come out so incredible. Send your friends, I've got an open slot for another theater smile.gif
GetGray is offline
Old 04-16-2014, 03:57 PM
superleo's Avatar
Quoted: 77 Post(s)
Liked: 301
Congrats on the room!!!
RPCRT-TV Overscan Reduction
Reference Blu-Ray Demo Disc
superleo is offline
Old 04-16-2014, 05:45 PM
24Changer's Avatar
Quoted: 115 Post(s)
Liked: 124
Nice job on the build.
Now comes the easy part ~ enjoying it
Thanks for the inspiration
avtexan likes this.
Creekside Stone Cinema
24Changer is offline
Old 04-16-2014, 05:53 PM
TMcG's Avatar
Quoted: 1072 Post(s)
Liked: 870
Excellent job! Can you post your before and after REW graphs? I'd be very interested to see the differences.
TMcG is offline
Old 04-17-2014, 10:26 AM - Thread Starter
avtexan's Avatar
Quoted: 47 Post(s)
Liked: 89
I need to start a new thread for the next GT. I will try and start one next week.
avtexan is offline
Old 04-17-2014, 10:40 AM
7channelfreak's Avatar
Quoted: 286 Post(s)
Liked: 190
Looking forward to it. You going to put that popcorn machine to use?
7channelfreak is offline
Old 04-17-2014, 10:48 AM
jautor's Avatar
Liked: 777
jautor is offline
Old 04-17-2014, 12:43 PM
Quoted: 286 Post(s)
Liked: 190
Originally Posted by jautor View Post
Hahaha.
Old 04-21-2014, 11:18 PM - Thread Starter
avtexan's Avatar
Quoted: 47 Post(s)
Liked: 89
I received my miniDSP over the weekend.  I went with the OpenDRC-AN.
I also received the second amp for my Seaton HP+'s.  I may turn the slave into active if Jeff thinks he needs the flexibility.  Should be fun!!!
avtexan is offline
Old 04-22-2014, 06:28 AM
Quoted: 978 Post(s)
Liked: 506
Sounds fun! So, is Jeff coming over to your house to tune your submersives?
Old 04-22-2014, 08:05 AM - Thread Starter
avtexan's Avatar
Quoted: 47 Post(s)
Liked: 89
Yes, on Wednesday.
avtexan is offline
Old 04-22-2014, 08:09 AM
Quoted: 978 Post(s)
Liked: 506
Will you please post up your pre and post calibrations?
Old 04-22-2014, 08:53 PM
gdfein's Avatar
Quoted: 17 Post(s)
I had a fun day with Jeff today as well. Talk about a wealth of knowledge. H-town keeping him busy this week.
gdfein is offline
Old 04-22-2014, 10:44 PM - Thread Starter
avtexan's Avatar
Quoted: 47 Post(s)
Liked: 89
We finished the electrical trim tonight.  I had to replace one of the step lights and replaced an outlet that had stain on the face.
We also got all of the sconces installed.  They make a HUGE difference on how the room looks.  It is a much warmer feel.  The back of the room was too dark and now looks much better.  The textured ceiling and coffer are much more visable as well.  I put the front sconces on a separate zone and can have the back (4) on low and not wash the screen.
I was worried that they would rattle but I played some demo material tonight with lots of bass and I did not hear a peep from them.  I will run a bass sweep tomorrow to see if they need a bead of silicone between the glass and frame.
Next up.....calibration!
The original plan had a larger sconce in the middle section.  That one had to go back because it was a head knocker.  I think the spacing turned out OK.
avtexan is offline
Old 04-23-2014, 05:36 AM
Jonny5nz's Avatar
Quoted: 31 Post(s)
Liked: 93
Looks fantastic. It's amazing how much of a difference good lighting makes. I bet it looks even better in person.
avtexan likes this.
Jonny5nz is offline
Old 04-23-2014, 06:49 AM
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
Looks like Triad did a good job matching those surround grill covers to your stain.
avtexan and 24Changer like this.
GetGray is offline
Old 04-25-2014, 11:18 PM - Thread Starter
avtexan's Avatar
Quoted: 47 Post(s)
Liked: 89
The video and audio calibration is done.  Jeff Meier did an excellent job.  He was a pleasure to work with and he really knows his stuff.  I have not been able to spend much time in the room post calibration as I pulled the screen down as soon as it was done to try and finish things up this weekend.
VIDEO:
I thought the PJ was looking good before but now my Lumis is really looking awesome.  The test disk I used for the intial setup had the contrast all wrong but now everything is much improved.  We watched some scences form Casino Royale and it looked pretty sweet.
Post Calibration Numbers:
AUDIO:
He bypassed Audyssey and manually setup the graphic EQ in the Marantz and miniDSP.  He set up for reference but gave me a memory in the DSP to adjust to my preference.  I know I will probably run the bass a little hotter but it sounds great now.
We did run into some phase issues.  It turns out that the Marantz and my 2ch B & K amp use different pinouts for the XLR's.  But all is fine now.  I look forward to some extended listening.  We did play some Dark Side of the Moon on SACD.  I am going to have to get that one, it sounded awesome.
Jeff was very complimentary on the room acoustics.  He gave Quest a thumbs up for their plan.
RT60 Graph:
Pre Calibration Graph:
Post Calibration Graph:
avtexan is offline
Old 04-26-2014, 07:52 AM
Quoted: 978 Post(s)
Liked: 506
That's great! What was your subs crossover set at? Do you have any charts that show below 20hz? Thanks for posting the charts. I really want to hear your room!
Old 04-26-2014, 08:29 AM
KNKKNK's Avatar
Quoted: 39 Post(s)
Liked: 103
eek.gif That is one awesome room Texan.. I think your fabric compliments the wood finish exceptionally well, and the carpet put it over the top.. Congratulations on a Job well done..
KNKKNK is offline
