The Moving Pictures Theater Construction Thread - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 13Likes
post #541 of 566 Old 08-25-2014, 12:30 PM - Thread Starter
avtexan's Avatar
Quoted: 47 Post(s)
Liked: 89
Originally Posted by mark_anderson_u View Post
I love the idea of some wood sheet goods in the layers. Makes it so easy to hang stuff. Just curious why the OSB in walls and Ply in ceiling? Whay not all OSB or all Ply
One of the best things I did was the OSB / PW layer. It did make hanging columns, wainscot, firing strips, etc so much easier. I spoke with Ted about the trade offs and he said they were small. I did go up to 3/4" OSB and PW to close the gap some.
I used PW in the ceiling for its ability to hold screws better. Not only will PW hold screws better I also felt if I ever had an unknown moisture issue upstairs the OSB could be a problem. It was a cost savings to not use PW on the walls.
Are you happy with soundproofing. I'm hpoping to do my basement later this year and was considering 2x5/8 DW and 1 x OSB or Ply.
I went back and forth on to soundproof or not early in the process. We don't have kids so why do it? I am so glad that I did. We have since had guest with kids stay with us and were able to watch movies a shade under reference with the kids down the hall without waking them.
The big thing is it makes the room dead quiet. I have had guest stand by the door and open and close it and be amazed what a difference it makes.
It is one of things that requires attention to ALL of the details. If you are going to do it do it right. I had so much help from Ted White. He is awesome to work with.
We are here to help as well.
The Moving Pictures Theater Construction Thread:
http://www.avsforum.com/t/1462881/th...ruction-thread
Houston GTG - Summer 2014
http://www.avsforum.com/forum/61-are...l#post26079610
avtexan is offline
post #542 of 566 Old 08-25-2014, 12:36 PM
mark_anderson_u's Avatar
Quoted: 43 Post(s)
Liked: 42
Will definitely enlist some pro help with the details
mark_anderson_u is offline
post #543 of 566 Old 08-28-2014, 06:56 AM
Pain Infliction's Avatar
Quoted: 979 Post(s)
Liked: 508
I must tell you Ron, the first time and only time I have ever heard my wife say we needed better speakers is after hearing your theater! I was shocked! Of course I said "sure no problem!" She was the one limiting me in the theater in the first place and when I was going to buy the Triad golds, she told me she didn't want me to spend that much money on speakers after I have spent a lot on everything else. I thought this was funny and pretty cool at the same time.
avtexan likes this.
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #544 of 566 Old 08-28-2014, 07:38 AM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 968
After hearing almost every speaker under the sun, Triad Golds for specific price point are at the top of heap. Granted, reference at around 14-15 ft is about limit, but who listens to those levels for extended periods of time anyway? Much better sounding speaker at reasonable levels than similarly priced JTR 212's.......and other more expensive offerings.
At my listening levels, I must admit Triad Gold Monitors with Silver Monitors for surrounds is the direction I wished I had gone........and I may change out with Atmos implementation.
Triad's are exception speakers for the money......
doublewing11 is offline
post #545 of 566 Old 08-28-2014, 09:47 AM - Thread Starter
avtexan's Avatar
Quoted: 47 Post(s)
Liked: 89
Agreed. Maybe you and Pain Infliction could do so business when the time comes.
avtexan is offline
post #546 of 566 Old 09-09-2014, 11:55 PM - Thread Starter
avtexan's Avatar
Quoted: 47 Post(s)
Liked: 89
I am making some headway on the automation project. I have the templates done and working for the Alarm panel and the HVAC equipment. The steepness of the learnig curve is starting to flatten out a bit and I am making better progress. Next up is lighting.
For the alarm panel you select the source from the bottom, select the mode on the left and enter the code. I put some misc info in the top right. The red boxes in the window only show if something is tripped, they are normally invisible. The 2 buttons on the bottom show the garage door status and you can open / close them by pushing the buttons.
For the HVAC equipment you select the source from the bottom, select the unit to control on the left and then move the slide to the temp you want and hit set.
The buttons in the center control the mode and fan settings. It is not actually 88 degrees upstairs, that's the rack temp before I changed the label.
Name:	Alarm Template.png
ID:	255658   Click image for larger version
Name:	HVAC Template.png
ellisr63 likes this.
avtexan is offline
post #547 of 566 Old 09-10-2014, 05:49 AM
JVoth's Avatar
Quoted: 304 Post(s)
Liked: 152
I love the look of your panels Ron. Keep the pictures coming.
avtexan likes this.
JVoth is online now
post #548 of 566 Old 09-10-2014, 08:26 AM - Thread Starter
avtexan's Avatar
Quoted: 47 Post(s)
Liked: 89
Thanks! I am having fun putting them together. It is a little intimidating starting with a blank slate for each template but that's the fun part.
I have some ideas for lighting but we will see how that shakes out. Ideas that don't work out are certainly easier to fix than in the HT build.
avtexan is offline
post #549 of 566 Old 09-10-2014, 09:35 AM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
You are doing a great job on your templates... I really like the way they are setup and look! What are you displaying them on?
ellisr63 is offline
post #550 of 566 Old 09-10-2014, 11:00 AM - Thread Starter
avtexan's Avatar
Quoted: 47 Post(s)
Liked: 89
[QUOTE=ellisr63;27298338]You are doing a great job on your templates... I really like the way they are setup and look! What are you displaying them on?[/QUOTE
The screen shots are from my PC but when finished they will be displayed on (4) 15" Borg inwall touchscreens.
avtexan is offline
post #551 of 566 Old 09-10-2014, 11:32 AM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
[quote=avtexan;27300578]
Would you be willing to share the templates?
ellisr63 is offline
post #552 of 566 Old 09-20-2014, 09:56 PM - Thread Starter
avtexan's Avatar
Quoted: 47 Post(s)
Liked: 89
My lighting is pretty much done.
Here is the layout.
The set up is to choose the source at the bottom, choose the area on the left and then choose your scene.
The up and down arrows work after a scene is selected and the scene selected is shown between them. They move the loads up and down by about 20%.
The fans are laid out on the right.
Next up.....Whole House Audio
Name:	Lights Template.png
avtexan is offline
post #553 of 566 Old 09-21-2014, 10:33 AM - Thread Starter
avtexan's Avatar
Quoted: 47 Post(s)
Liked: 89
One of the biggest differences in building the home theater and working on the automation is the amount of Aleve taken the next day. I logged about 4 hours on Friday and 10 hours on Saturday for programing & design work. I would be moving slow today for sure if this was ladder and hammer time.
Now I don't even need to get up from my comfy chair to set the A/C down to 68 vs working in the room last year before the HVAC was finished.
Back to the keyboard!
ellisr63 and speedoflight like this.
avtexan is offline
post #554 of 566 Old 10-04-2014, 06:39 PM - Thread Starter
avtexan's Avatar
Quoted: 47 Post(s)
Liked: 89
I finished up the Whole House Audio tonight. As with my other templates it needs some polish as far as fonts etc. I plan to go back over everything when I am done.
Select the source at the bottom and the party template come up. You can power all zones on or off and choose the party source. The window in the middle gives the status of each zone. The controls for the party source will be on the right side when selected.
Once you select and area you can toggle power, control volume, mute and add a do not disturb. You choose the source on the right and the source overlay populates.
For the XM radio the current info shows in the window up top. You can toggle power and the band from the middle boxes. If you need to input a channel directly a popup box comes up with a keypad.
The box on the right allows you to flip through my top 20 favorite stations. The logo is synched up with the current station chosen.
Any feedback is more than welcome!!
Next up is the templates for the media server.
Name:	WHAudio Template-Party.png
ID:	295010   Click image for larger version
Name:	WHAudio Template.png
avtexan is offline
post #555 of 566 Old 11-02-2014, 09:41 PM - Thread Starter
avtexan's Avatar
Quoted: 47 Post(s)
Liked: 89
I have been working on the control of the pool equipment. I had to pull new wire from my pool equipment to the media closet and then new wire to the outside controller. That was a pain but it is done. YEAH! Next up is so work on the touchscreens and then shade control.
Name:	Pool Template.png
avtexan is offline
post #556 of 566 Old 11-03-2014, 05:52 PM
Quoted: 229 Post(s)
Liked: 968
You're doing a great job!
It's at this stage I leave automation to the experts.......my pocketbook hates it but my beautiful head of hair appreciates it!
I envy your programming and patience skills............
post #557 of 566 Old 11-04-2014, 08:30 AM
AirBenji's Avatar
Quoted: 35 Post(s)
Liked: 84
Wow this is really impressive tex - nice work!!
AirBenji is offline
post #558 of 566 Old 11-04-2014, 11:51 AM - Thread Starter
avtexan's Avatar
Quoted: 47 Post(s)
Liked: 89
Thanks Doublewing & Airbenji. I have some time off next week and I hope to make some serious headway on my automation project.
I want to get this finished up and start my hush box and beef up the exit door a bit. Then I will be finished.........until............???
avtexan is offline
post #559 of 566 Old 11-05-2014, 06:32 AM
JVoth's Avatar
Quoted: 304 Post(s)
Liked: 152
This definitely looks world class, Ron. I had no idea Charmed Quark was so powerful, at least in the right hands.
avtexan likes this.
JVoth is online now
post #560 of 566 Old 02-26-2015, 04:14 PM
conanb's Avatar
Quoted: 20 Post(s)
I am so impressed with your hard-work and the results.
So enjoyed the hospitality at the last meeting.
conanb is offline
post #561 of 566 Old 02-26-2015, 05:49 PM
Quoted: 229 Post(s)
Liked: 968
Sure like the country music tabs!
post #562 of 566 Old 03-15-2015, 03:53 PM - Thread Starter
avtexan's Avatar
Quoted: 47 Post(s)
Liked: 89
After a long break spent watching movies and staying off of any ladders I am ready to tackle a hush box for my PJ. I am stuck on the design and started a new thread. Join the conversation below if you have some time.
Hush Box Design help needed!
avtexan is offline
post #563 of 566 Old 08-15-2015, 07:55 AM
JVoth's Avatar
Quoted: 304 Post(s)
Liked: 152
Howdy Ron!
I posted in your hushbox design thread, too. I was wondering if you were still looking to build a hush box or just keeping your PJ out in the open?
JVoth is online now
post #564 of 566 Old 05-01-2016, 01:29 PM
Quoted: 16 Post(s)
Liked: 1
To revive an old thread... How's the performance of your dual SubM's? I have a similar space above my garage and I'm planning on the same master / slave combo. Do you ever wish you had more bass output?
huxton is offline
post #565 of 566 Old 05-02-2016, 09:45 AM - Thread Starter
avtexan's Avatar
Quoted: 47 Post(s)
Liked: 89
Thanks for breathing some life into an old thread!!!
I love my dual SubM's. They provide plenty of bass for my tastes. I have had many folks comment on the butt shakers but they are surprised to find that I don't have any butt shakers installed.
I am also very happy with how they sound with music. I think they are very versatile.
The master / slave worked fine for my room. I had the extra amp and was going to install it if it was needed during the room calibration but I did not need the extra control and sent it back to Seaton.
I think the subs you choose are half the battle. The placement, EQ, room construction and treatments will also weigh heavily on the outcome.
avtexan is offline
post #566 of 566 Old 05-03-2016, 05:59 AM
Quoted: 16 Post(s)
Liked: 1
Great feedback, thanks!! I have a similar size space (19 x 23) and I'll have one shot at doing it right. My wife (aka CFO) won't take it well if I come back after the fact and tell her I need another $2.5K for more bass.
huxton is offline
