The Vortex Theater Build - Page 6 - AVS Forum
 3Likes
post #151 of 152 Old 09-25-2014, 04:38 PM
RedStripe88's Avatar
Quoted: 12 Post(s)
Originally Posted by ClemsonJeeper View Post
Got the soffits framed up using lighter soffit building techniques since they are hanging from channels in the ceiling:
Hung the first layer of drywall under the soffit in the front of the room:
I realized I need to come up with a full plan for how I'm going to attack the light tray design before I continue. I may end up having to use MDF instead of drywall, so don't want to go too far.
My build is at about the same spot. I'm figuring out how to build a 3-4" light tray before I cover mt soffits. I'd prefer to use 1/2" drywall to cover the soffits. That would minimize weight hanging from the clips and channel. But, I'm not sure how to support all the stuff that will go in the tray (LED strip, black lights) plus the crown molding.
What ideas are you considering? Anything other that going the MDF route?
My in progress build thread:
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
RedStripe88 is online now
post #152 of 152 Old 09-28-2014, 08:29 PM - Thread Starter
ClemsonJeeper's Avatar
Quoted: 90 Post(s)
Liked: 39
Thanks @BIGmouthinDC for swinging by this weekend to give me some tips about my light tray and other things. Definitely will get me back on track this week.
Going to have to empty out my local HD's MDF stock.
My Home Theater Build:
ClemsonJeeper is offline
User Tag List
