Updated w/ PICS! My first dedicated home theater room! Input needed before I begin - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 03-15-2013, 12:27 AM - Thread Starter
gerth_vader's Avatar
I have been into home theater for a lil over a decade but never had the oppurtunity to have a dedicated theater room.
Most of the epuipment will be entry level so I really think the design is going to play the biggest role.
htpc:
amd liano powered in an htpc case. pretty generic, running xbmc. I also have a server with all my music and movies etc.
avr: pioneer vsx 1022
front channels: pioneer fs51
center: pioneer cs21
surrounds: pioneer bs41
sub: acoustech pl200
projector: JVC DLA-X30
screen: DIY
Here is the demensions of the room and a short description of each wall. The cieling is 8ft.and unfinished and the
floor is concrete.
wall
A is a exterior wall and has two inches of foam already. it is called insulfoam http://www.insulfoam.com/
B is also an exterior wall with 2 inches of foam.
C connects to a storage room. no sheet rock hung thats not a door its a lil closest. tight fit but
i think it will fit all the equipment
D there is no wall built yet. That is as far left as the the door can go because of a closet
in a small bedroom connects there.
My plan is for a screen on wall A anywhere from 90-120 inches wide. I am shooting for a 10 ft. seating distance
and the seating will be a pit style couch. 2x4 2 inch thick sound absorption panels at the first reflection point
and a couple 2x4 4 in. thick absorption panels on the rear wall. Bass traps floor to cieling in the corners of the rear
wall and a 2x4 2in thick absorpion panel (or dshould I go with a diffuser?) on the cieling at the first reflection point as well.
The projector I wanted to build its own housing in the storage room
behing wall C. Any input about lighting would be great. Also other concerns I have are the foam on the walls,
should I get more foam for the other walls?
this shows the walls with foam
This shows the cutout on wall C
gerth_vader is offline
post #2 of 10 Old 03-15-2013, 06:30 AM
Quoted: 3280 Post(s)
Liked: 2757
Leave the DIY screen until last. Get your projector and shine it on the primed but unpainted wall in your space. experiment with different image sizes and see what you like best. No need to try to guesstimate your needs.
post #3 of 10 Old 03-16-2013, 04:49 PM
Tedd's Avatar
Quoted: 944 Post(s)
Liked: 351
Why not just use Goo Systems Goo Screen paint, for a 1.3 gain? Excellent product.
The video side is very solid. Will the room get symmetrical side walls?
Tedd is offline
post #4 of 10 Old 03-17-2013, 10:13 AM
petew's Avatar
Quoted: 25 Post(s)
Liked: 68
I don't think you will need a 1.3 gain screen with the JVC. I'm projecting on a DIY blackout fabric screen with an RS2 and it looks great.
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is online now
post #5 of 10 Old 03-18-2013, 12:59 AM - Thread Starter
good point. I def. want to find that sweet spot on the zoom lense. I'm by no means locked in on a actual # for screen size, of course seating is only 10 ft away so that sets my boundries.
I have never heard of the goo paint before. I will have to research. and by symmetrical side walls do you mean parallel? or if its an exact square room?
this is the input i need. I'm not sure about the screen or the accoustics of the room thought the accoustics part is really a crap shoot cause every room is diff. I can def. say that the room will be dark and the projector is the jvc at around a 15ft throw max. screen size from 90 to 120 diagonal. hoping to find the middle ground with great contrast and a super crisp picture.
thanks for the input so far. im still learning but very eager. I know the design will make or break this room so i'm very cautious to begin without a thorough plan.
post #6 of 10 Old 03-18-2013, 06:09 PM
Tedd's Avatar
Quoted: 944 Post(s)
Liked: 351
Parallel side walls (so the front speakers have reflective walls). Ideally, you don't want a square room.
Tedd is offline
post #7 of 10 Old 03-18-2013, 10:32 PM
SierraMikeBravo's Avatar
Quoted: 339 Post(s)
Liked: 215
Best way to get help is to draw it out, post it, then request feedback. You'll got quite a bit I'm sure.
Shawn Byrne
CEDIA Certified Professional EST II - HAA, THX.
Theater Design Information and Examples
skbyrne@sbcglobal.net
shawn@questai.com
SierraMikeBravo is offline
post #8 of 10 Old 03-20-2013, 08:56 PM - Thread Starter
post #9 of 10 Old 03-22-2013, 09:18 PM
Zach Peterson's Avatar
As for DIY screens check out the forum. There are some very helpful ppl there. they helped me make a 120" SilverFire screen that I am/was really proud of (moved into new home and am not using it currently). If done correctly it is said to be comparable to some very nice screens. thats a debate for another day. Nice thing about SilverFire is you can customize the gain to the needs of room and the mixing and spraying is very easy. Believe I spent around ~250 for extruded PVC, paints, and HPLV sprayer.
Zach Peterson is offline
post #10 of 10 Old 03-23-2013, 04:24 AM
RTROSE's Avatar
Quoted: 192 Post(s)
Liked: 167
Looks like you are going to have a great space. I'll second the DIY painted screen. I went with another type of painted screen and I'm very happy with its performance. Do some lurking in the DIY screen thread, it will be very informative.
As far as sound treatments go, the more you read about that (the acoustical treatments master thread is a great way to start), the more you realize there is voodoo, black magic, and alchemy. Before reading there bring some Advil or Excedrin you'll need it after a few pages in.
Good luck and I'm looking forward to seeing this come together.
RTROSE
RTROSE is offline
