Beam and Pole interruptus NOT - BIGmouthinDC and NYGiantsFan23 launch - The Rawlinsway Theater - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 21Likes
Old 06-22-2013, 09:19 AM
Tom Bley's Avatar
Quoted: 593 Post(s)
Liked: 529
Originally Posted by Mfusick View Post
I've built a bunch of car subwoofer boxes from it back in the1990's (I was a kid) when I was into car audio. I still have the speaker design cookbook laying around by Vance Dickason, and I am certain it's of late 1990's vintage with the red top cover.
I remember MDF was the choice back then for that reason. And yes- It's heavy. A full sheet is a little more than I can or want to carry, I'd need help. lol. Did you use that for the speakers too ?
I'm not BigmouthinDC but, yes the speakers are mdf. They are a kit from the DIY Sound Group.
http://www.diysoundgroup.com/waveguide-speaker-kits/alpha-series-kits/alpha8-kit.html
Tom Bley is offline
Old 06-22-2013, 10:06 AM - Thread Starter
Quoted: 3256 Post(s)
Liked: 2743
My approach to buying sheets of MDF (49x97 inches) if to have them cut it into manageable size pieces at the store. In this case I had them rip a 17 1/2 inch piece off of each full sheet then I cleaned it up for the final 17 inch columns on-site. In the case of the Bacon Race we actually had them rip all the 10 inch pieces for the soffits at the store.
Old 06-22-2013, 10:10 AM - Thread Starter
Liked: 2743
Tom, the front baffles were 3/4 MDF. The boxes were 1/2 inch Baltic Birch. At the dimensions of those speakers Plywood is OK, DIY Sound Group uses MDF for their sub-woofer boxes.
Old 06-22-2013, 01:14 PM
Tom Bley's Avatar
Quoted: 593 Post(s)
Liked: 529
Oh, nice. I should have looked at the build pics again. I actually like BB better than MDF but, it's expensive.
Tom Bley is offline
Old 06-22-2013, 02:13 PM - Thread Starter
Liked: 2743
it is hard to believe that DIYsoundgroup sells the CNC perfectly cut cabinets for $25 shipping included.
Old 06-22-2013, 02:15 PM
HopefulFred's Avatar
Quoted: 490 Post(s)
Liked: 422
HopefulFred is offline
Old 06-22-2013, 03:57 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
The entire cabinet ? Or just the face ?
What is it made from ?
Mfusick is offline
Old 06-22-2013, 04:21 PM - Thread Starter
Liked: 2743
Please read the link that Tom provided.
Old 06-23-2013, 07:23 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
OK- I never saw the link for $25. Thanks.
http://www.diysoundgroup.com/flat-packs-1/seos-flat-packs/eos-8-flat-pack.html
It seems like I could barely build a cabinet myself for that cost. Dragging out the table saw, buying glue, screws, etc... seems futile to do yourself almost. Even though I kind of want to do it eek.gif
You think MDF home built cabinet would make and difference versus the $25 they sell ? Better? What did you do ?
Isn't a sheet of MDF expensive these days ?
Mfusick is offline
Old 06-23-2013, 07:27 AM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 81 Post(s)
Liked: 126
I built my own Econowave speakers and i can tell you this much if i knew about these flat packs then i would of bought them in a second. MDF a full sheet i think is close to 40$, it weighs a ton, the smell when cutting it is awful, the dust even if you have a shop vac attached it still makes a huge mess
don't forget you will need to invest in Jasper jig for cutting nice speaker cut outs there is another 40$ and hopefully it is compatible with your router assuming you already have one. The time and cost savings with flat packs is a no brain er to me.
snickers1 is offline
Old 06-23-2013, 07:37 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Yeah. That is what it seems. I've built plenty of MDF sub boxes before and I own all the tools. The kit appears to come with CNC machine cut fronts. So making the box might be easy. I'm just wondering if it's worth it ???
Perhaps if I was doing all 11 speakers at once for 11.2 the savings might add up to take a full saturday if my time cutting and gluing and screwing. But for a pair.. I'd spend $50 in a split second to save the time.
Mfusick is offline
Old 06-23-2013, 08:56 AM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
a 2' x 4' x 3/4" MDF from home depot is 12 bucks which would make one box so it's only a 2x markup which is a pretty good deal unless you're making bulk boxes.
JWagstaff is offline
Old 06-23-2013, 09:23 AM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 81 Post(s)
Liked: 126
Originally Posted by JWagstaff View Post
a 2' x 4' x 3/4" MDF from home depot is 12 bucks, and that makes 3 of those boxes I think, so that's only $4.00 in wood per box, its a 6x markup for the wood, so it's not that good of a deal unless you don't have any of the tools already.
If you're just making like 1 or 2 boxes it's definitely worth it just to not have to get out the saw and stuff.
i think your math is incorrect your not getting six sides from one piece of 2x4 so not sure how you would even come close to getting 3 boxes
it will take two sheets minimum per box so that is 24$ ... so 25$ fully cut and ready to assemble is a very good deal i think smile.gif
Old 06-23-2013, 10:13 AM - Thread Starter
Liked: 2743
There is a section of the forum talking about DIY speakers and a thread about the DIY sound group flat packs. Lets focus on finishing this theater.
Old 06-23-2013, 10:19 AM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 81 Post(s)
Liked: 126
Old 06-26-2013, 02:51 PM
NYGIANTSFAN23's Avatar
Liked: 39
*NEW PICS* Well, the painting is 98% complete; just need to hang some ceiling moldings.
AppleMark
NYGIANTSFAN23 is offline
Old 06-26-2013, 02:55 PM
ScAndal's Avatar
Liked: 27
ScAndal is offline
Old 06-26-2013, 03:07 PM
Liked: 39
I hope that's a good wow!
Old 06-26-2013, 03:40 PM
cuzed2's Avatar
Quoted: 187 Post(s)
Liked: 236
+2
And I mean a damned-good WOW !!
Cuzed2
CuznEddy Cinema
cuzed2 is offline
Old 06-26-2013, 03:55 PM
Willie's Avatar
Quoted: 75 Post(s)
Liked: 106
I think the Wow! is more along the lines of great transformation of the space from basement to elegant theater. Looks very good. Soffit treatment using the beam to delineate the riser from the main floor seating looks like you set out to define two separate spaces, not like you were working around the beam. The design draws the eye to the screen and makes the main seating position a bit more intimate. Very nice look.
Willie is offline
Old 06-26-2013, 03:58 PM
javeryh's Avatar
Quoted: 68 Post(s)
Liked: 26
Really nice finishing details on that trim and paneling. How deep are the columns?
javeryh is offline
Old 06-26-2013, 04:09 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I love it !! progress looks amazing. !! Nice work !!
Did you use MDF as the back board ?
I'd imagine it's easier to paint and less sanding ?? Was that the reason ?
Mfusick is offline
Old 06-26-2013, 04:59 PM
jnnt29's Avatar
Quoted: 115 Post(s)
Liked: 131
My set up
Marantz SR-7008, Emotiva XPA-3
Samsung UBD-K8500 Ultra 4K Blu Ray Player
Klipsch RB-81II, RC-52II, Boston Acoustics Micro 120s
Klipsch SW-310, RPW-10, Samsung UN65JS8500FXZA
http://www.avsforum.com/avs-vb/showthread.php?t=1227096
jnnt29 is offline
Old 06-26-2013, 06:18 PM - Thread Starter
Liked: 2743
The columns are 10 3/4 inch deep because the speakers are 9 1/2 deep.
We did not use MDF on the walls just molding.
Fabric panels yet to be installed on top, dark brown surrounded by frames painted the cream color.
Old 06-26-2013, 06:38 PM
NGiovas's Avatar
Liked: 43
LOVE the colors!  An amazing transformation.  I didn't see this coming.
NGiovas is offline
Old 06-26-2013, 06:49 PM
Tom Bley's Avatar
Quoted: 593 Post(s)
Liked: 529
Nice job! I like the columns on each side of the screen wall. How much black area from the left or right screen viewing area to the column is there?
Tom Bley is offline
Old 06-26-2013, 06:55 PM - Thread Starter
Liked: 2743
The upright is 3 1/2 inches wide, the 3 1/2 inch wide screen frame outer edge will land in the middle of the upright. It will be blacked out from there to the side of the column.
Old 06-26-2013, 06:58 PM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 81 Post(s)
Liked: 126
Looks Great!!! can't wait to see the carpet go in and and all finishing touches
Old 06-26-2013, 08:09 PM
Liked: 39
Thanks Guys, but I owe all the credit to Big and Bill... I showed Big a picture and asked him if he could do it and he told me Yes, I can make it happen. All of the pieces are coming together just like we planned.
Old 06-26-2013, 08:18 PM
petesvt's Avatar
Quoted: 13 Post(s)
Awesome work!!!! It is absolutely amazing...
petesvt is offline
