Beam and Pole interruptus NOT - BIGmouthinDC and NYGiantsFan23 launch - The Rawlinsway Theater - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 21Likes
post #721 of 870 Old 10-18-2013, 06:46 PM
NYGIANTSFAN23's Avatar
Liked: 40
Gravity was great!
PaulFSemicolen likes this.
NYGIANTSFAN23 is offline
post #722 of 870 Old 10-18-2013, 10:42 PM
jbcain's Avatar
Liked: 64
Great build.
jbcain is offline
post #723 of 870 Old 10-25-2013, 06:44 PM
d_c
d_c's Avatar
Quoted: 890 Post(s)
Liked: 1020
d_c is offline
post #724 of 870 Old 10-25-2013, 09:37 PM
Liked: 40
Thanks a lot d_c..
post #725 of 870 Old 10-28-2013, 09:15 PM
jimmyk36's Avatar
Quoted: 89 Post(s)
Liked: 41
Used the smallest profile possible for the ladders on each side of beam. 1 5/8 steel pro-trak, 2x4 turned flat. Built on the ground and screwed to the channel directly above. Two layers of 5/8 Drywall, caulk and Green glue for the bottoms and sides.
Where did you guys buy the Pro-Trak? I don't see it on the Lowe's or HD Web Sites.
jimmyk36 is offline
post #726 of 870 Old 10-28-2013, 10:42 PM - Thread Starter
Quoted: 3820 Post(s)
Liked: 3249
I bought some a couple weeks ago at Home Depot. They had 100s in stock on the shelf in the metal framing section. They come bundled in group of 10 but there will be loose ones laying there as well. Don't pay attention to the Pro-Track name, it is a basic steel framers commodity and sold under different names.
post #727 of 870 Old 10-29-2013, 10:30 AM
jimmyk36's Avatar
Quoted: 89 Post(s)
Liked: 41
Thanks Big - one other question - (I also posted this in theSound Containment - Air Cavity - soffit. thread a few days ago) - is this now your preferred way to build soffits versus using 3/4" MDF?
jimmyk36 is offline
post #728 of 870 Old 10-29-2013, 03:05 PM - Thread Starter
Liked: 3249
MDF works, So does Drywall. I don't do drywall finishing so If I bring in someone for that task They can hit the soffit, I'm lazy and have no love for sanding MDF soffits and breathing the dust.
post #729 of 870 Old 11-04-2013, 06:32 PM
jimmyk36's Avatar
Quoted: 89 Post(s)
Liked: 41
Big - When you are doing MDF soffits are you gluing and screwing or just attaching to the 2x2s etc. with just screws?
jimmyk36 is offline
post #730 of 870 Old 11-04-2013, 06:41 PM - Thread Starter
Liked: 3249
2x2 is glued and screwed, If I wake up and my OCD is above 8.5, I glue the MDF to the 2x2s.
post #731 of 870 Old 11-04-2013, 06:48 PM
jimmyk36's Avatar
Quoted: 89 Post(s)
Liked: 41
Liquid Nails?
jimmyk36 is offline
post #732 of 870 Old 11-04-2013, 07:19 PM - Thread Starter
Liked: 3249
yes, keep it off your clothes
post #733 of 870 Old 11-08-2013, 11:05 PM
PaulFSemicolen's Avatar
B.E.A.UTIFUL!!! Great job on what appears to be a quick 5 month build ^_^
PaulFSemicolen is offline
post #734 of 870 Old 11-09-2013, 04:29 PM
wru2006's Avatar
NYGiantsFan,
did you ever gather costing for this project? this is a beautiful room - i'm sure you're enjoying it!
wru2006 is offline
post #735 of 870 Old 11-10-2013, 11:33 AM
Liked: 40
Originally Posted by wru2006 View Post
NYGiantsFan,
Hey wru2006, I decided in the beginning of this project that I would not pay much attention to the cost because I knew that it would drive me crazy Just wondering how and why would I spend that kind of money on something that does not yield a monetary return. With that said, I did have a budget of 30k and I did exceed that limit. I do have all of my receipts and Im certain that someday I will check the raw numbers, but for now I will just enjoy and keep spending..... biggrin.gif
post #736 of 870 Old 11-11-2013, 04:31 AM
willmo's Avatar
Originally Posted by NYGIANTSFAN23 View Post
willmo is offline
post #737 of 870 Old 11-11-2013, 04:12 PM
linkseo's Avatar
Liked: 25
Lets talk about the contrasting color frames.
Big I have to ask. did you staple the fabric onto the black painted strips? this is what i assumed but looking at this pick it looks like the fabric is stapled to the wall. Was this just a few missed staples?
linkseo is offline
post #738 of 870 Old 11-11-2013, 04:19 PM - Thread Starter
Liked: 3249
I tried to hit the wood, but sometimes the angle was such that it didnt happen. I have some panels on my ceiling that were stapled just to the drywall and covered with molding not an issue.
post #739 of 870 Old 11-18-2013, 06:48 PM
linkseo's Avatar
Liked: 25
BIG. thanks for all the responses. sorry to ask so many questions. Just want to get it right the first time from the expert.
Can you please provide the staple gun and staple type used for this project?
Thansk again
linkseo is offline
post #740 of 870 Old 11-18-2013, 08:21 PM - Thread Starter
Liked: 3249
post #741 of 870 Old 11-30-2013, 07:43 PM
jimmyk36's Avatar
Quoted: 89 Post(s)
Liked: 41
We used a cheaper fabric that is actually easier to work with by the novice. Acousticmac DMD. it is discussed earlier in the thread.
When you ordered the DMD - did you order "fireproof" or just the standard fabric on the web site?
jimmyk36 is offline
post #742 of 870 Old 11-30-2013, 08:04 PM - Thread Starter
Liked: 3249
Standard, NYGF23 doesn't smoke.
post #743 of 870 Old 11-30-2013, 08:25 PM
jimmyk36's Avatar
Quoted: 89 Post(s)
Liked: 41
Great - no smokers here either - just placed my order - they extended the black Friday 10% code thru the weekend.
jimmyk36 is offline
post #744 of 870 Old 12-06-2013, 01:42 PM
linkseo's Avatar
Liked: 25
http://www.amazon.com/Porter-Cable-US58-22-Gauge-C-Crown-Upholstery/dp/B00004SBC3
I usually use a 3/8 inch staple
I'm LOVING this staple gun BIG. I'm a stapling fool right now!
linkseo is offline
post #745 of 870 Old 12-08-2013, 09:46 PM
M.T.Nest's Avatar
Quoted: 30 Post(s)
That stapler is over 50% off at the moment...I'm just sayin'.
M.T.Nest is offline
post #746 of 870 Old 12-09-2013, 05:40 AM - Thread Starter
Liked: 3249
it always is, it usually is in the 80s when it drops to the 60s it's a deal.
post #747 of 870 Old 12-11-2013, 02:46 PM
Liked: 40
No smoking at least not for another 2 years!!!!!!.............
post #748 of 870 Old 12-11-2013, 03:09 PM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 82 Post(s)
Liked: 126
snickers1 is offline
post #749 of 870 Old 12-11-2013, 08:56 PM
BrolicBeast's Avatar
Quoted: 1358 Post(s)
Liked: 1430
LOL--counting down already bro? lolol
BrolicBeast is offline
post #750 of 870 Old 12-19-2013, 09:10 PM
Liked: 40
Oppo problem solved. Feels good to be able to hear my rear speakers again. They said the server board went bad somehow. They were extremely apologetic and they took care of the problem in 4 days. they paid for shipping both ways, updated my software, and gave me a courtesy call to make sure everything was alright after i hooked the system up again. Aside from making a great product, the customer service was awesome. I would definitely Go oppo again in the future.
