Comfortable walking distance between seats and wall - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-24-2013, 03:43 PM - Thread Starter
neaner72's Avatar
Hey all!! It's been a long time. I have a quick question. I'm exploring my seating options for my 13'x23' HT. I would love to do a curved 3 wide set-up @ approx. 110" wide which would leave me 2' on either side of the seats. Is 2' a comfortable space to travel through? Just seems a little tight to me. How far away are your seats from the wall? Would I be better off with a HT sofa under 100"? Thanks in advance!! BTW......I enter my HT from the rear center of roomso I would like the seating to be centered.
"Nick, what did your dad get done in the movie room tonight?" "Nothin', he just went down there and stared again".
Build Link
http://www.avsforum.com/avs-vb/showt...4#post18526304
neaner72 is offline
post #2 of 6 Old 03-24-2013, 04:35 PM - Thread Starter
neaner72's Avatar
Anyone?
Build Link
neaner72 is offline
post #3 of 6 Old 03-24-2013, 04:44 PM
AaronN's Avatar
2 feet on either side should be OK. You can always shift it a few inches so the side used more often has a little more space. Most people aren't walking back and forth that much. I'm actually going to have closer to 18" for my front row.
__________________________________________________ ______
http://www.avsforum.com/t/1415464/aa...sement-theater
AaronN is offline
post #4 of 6 Old 03-24-2013, 05:17 PM - Thread Starter
neaner72's Avatar
Good point AaronN. Didn't think about the walking back and forth thing. I have a bad problem over thing things sometimes lol! Btw. Following your build. I'm currently finishing the main portion of my basement. I'm hoping to get back on the HT soon.
Build Link
neaner72 is offline
post #5 of 6 Old 03-24-2013, 08:32 PM
audiovideoholic's Avatar
Quoted: 654 Post(s)
Liked: 216
You'll be fine with 2'.
neaner72 likes this.
audiovideoholic is offline
post #6 of 6 Old 03-25-2013, 11:39 AM
235
235's Avatar
I also have a 13' wide room and bought the 3-curved Fusion Jive's for my front row.
235 is offline
