Riser advice needed - AVS Forum | Home Theater Discussions And Reviews
Old 03-26-2013, 11:01 AM - Thread Starter
bduncan118's Avatar
Ok good people, I am now planning my riser. I have an odd L shaped room that is 22ft long. The narrow part is 10 ft wide, the wide part is 14 ft wide. I am trying to get a sketch up done and wanted some opinions on the current plan.
As you can see the corner that is 19" front of riser to wall is real slim. The overall riser is going to be 9' 4'' wide, and 6 ft deep. The screen distance from front row is about 11 1/2 ft.
I plan on having 2 separate recliners in the front and then about a reclining couch or loveseat on the back. Theater seats will happen on down the line that's why I'm making the riser 9'+ wide.
Is there anything I haven't thought about? Thanks for your time and input!!!!
bduncan118 is offline
Old 03-26-2013, 12:42 PM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 690
why not full width and all the way to the back of your HT?
Or are those doors at the rear and therefore access.
mtbdudex is offline
Old 03-26-2013, 12:50 PM - Thread Starter
bduncan118's Avatar
Access to storage and equipment closet.
