sound proofing a wall between my duplex and neigbhoor - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-26-2013, 09:36 PM - Thread Starter
Kathb's Avatar
Hi everyone. I need some of your help. Just bought a 1920 duplex, brick with plater wall separating me from the neighboors duplex. I can hear conversations and banging doors. I really need to sound proof the wall and gain some privacy . I do not want to loose to much floor space because the house is already small. I have been looking into so many options i am confused. First has any one heard of Peacemaker ? it is a absorbent for sound made of recycled tires, Saw it on the Audiomute web site. I was thinking of putting one sheet of peacemaker on the wall then a sheet of Quiet rock and maybe green glue ? Maybe i am overdoing it ? Any way this is my first adventure in sound proofing and i need your advice and experience , thank you for sharing
Kathb
Kathb is offline
post #2 of 5 Old 03-26-2013, 10:02 PM
Quoted: 3906 Post(s)
Liked: 3338
Do you own both sides?
post #3 of 5 Old 03-26-2013, 10:27 PM - Thread Starter
Kathb's Avatar
no i do not
Kathb is offline
post #4 of 5 Old 03-26-2013, 11:24 PM
Liked: 3338
This is advice you can trust.
http://www.soundproofingcompany.com/soundproofing-solutions/soundproofing-walls/
I want to caution you that simply treating a wall may have disappointing results if there are flanking pathways like floor and ceiling joist spaces. Back to back outlet boxes and shared duct work can be other problems. Sound can also travel from your neighbors ceiling to the attic to your ceiling. You can't think of sound as traveling in a straight line,
Do you have any idea how the partition wall between your units is constructed? Today's standard their would be a massive wall from foundation up through to the roof.
post #5 of 5 Old 03-27-2013, 06:33 AM - Thread Starter
Kathb's Avatar
Thank you for your advice.
I did look up the soundproofing company, i will phone them.
I am no expert on construction but from what i can see , because downstairs we openned a part of the wall is that it is brick and stone covered with layers of plaster..no wood on the that wall.
Kathb is offline
