Like a Boss Theater Build - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #121 of 136 Old 02-20-2014, 08:31 PM - Thread Starter
Yzfbossman's Avatar
Quoted: 44 Post(s)
Liked: 75
Originally Posted by jimmyk36 View Post
Did you have someone design the acoustical treatment layout or was that all DIY?
Trying to get a feel for the depth of the walls. Looks like 2" of OC70x covered by fabric frames.
What is the depth of your columns from the wall?
What is the depth of the frames covering the OC70x?
Hey Jimmy,
DIY on the acoustic layout. I put enough hours in studying this forum to know 85% what needed to be done. I traded a few e-mails with Brian Pape at http://www.gikacoustics.com/ for some thoughts too. He is awesome....I didn't end up buying anything from them but their site and his posts on home theater shack were very helpful. I also read just about everything Ethan Winer published too.
I like a room with a bit of acoustic "control" vs an overly loose sound, so it's an absorption focused plan. If I had a bit more room depth to play with I would have incorporated more diffusion.
I planed and had the fabric frames built so I could do some tweaking on acoustics after it was done....but it turned out just as I hoped. smile.gif
You are right, 2" OC703 glued to the wall and then covered with fabric frames. Here is a bit more detail in this post:
http://www.avsforum.com/t/1465533/like-a-boss-theater-build/30#post_24052874
The columns are 8" from the wall. (14" wide) We debated on the depth of the columns for a bit. I mocked up several as I wanted depth but didn't want to block too much of the access to the stairs. The 8" x 14" turned out to be a good compromise.
Originally Posted by BrolicBeast View Post
Wow, what an inspiration.  I'll be working with an 18x18 space and my biggest concern was fitting enough seating in there for two rows (also going with the Jives).  I see that at 19x19, you were able to comfortably fit two rows in here, so I'm no longer worried :-)
We like the chairs...and the trays are awesome! They are not quite as "stout" as larger chairs as there is a bit of "wiggle" to the arms. But you can't beat the width of them.
Two rows will be fine for you. Just know that he last row is so close to the back wall that the bass is too boomy when sitting there for action movies. Front row is our money seat for blu-ray and even DVD movies. But we move to the back row for HDTV. (just too compressed) Most of the TV programming we watch lacks heavy LFE so it works for us.
Here is my build thread:
---->Like a Boss Theater Build<----
Yzfbossman is offline
post #122 of 136 Old 04-27-2014, 05:58 PM - Thread Starter
Yzfbossman's Avatar
Quoted: 44 Post(s)
Liked: 75
I was taking some pictures and looking at the SDE vs the weave....and thought I would do a screen shot:
post #123 of 136 Old 04-28-2014, 10:10 PM
DavidK442's Avatar
Quoted: 506 Post(s)
Liked: 341
I'm not sure what you are showing here?
Is the Screen Door Effect of the Epson LCD visible from your seating distance? You chose the EluneVision AudioWeave 4k over Centerstage XD to eliminate visible weave. Surely that isn't impacting the image...which looks fabulous by the way.
I almost missed the completion of your theater. Nice contrasting color choices and a great classic look.
DavidK442 is offline
post #124 of 136 Old 04-29-2014, 05:44 PM - Thread Starter
Yzfbossman's Avatar
Quoted: 44 Post(s)
Liked: 75
Ya sorry that was a confusing post. I should have just said, here are some screen shots. smile.gif
The SDE is not visible 99% of the time especially with bluray. In bright light monotone, especially all white, scenes I can see it a bit. Every once in a while I'll take a close look to see if I'm noticing SDE or weave...it's the SDE. My wife claims she can't see it.
Ok here is another set of shots:
No A-lens:
With A-lens:
post #125 of 136 Old 04-29-2014, 06:55 PM
DavidK442's Avatar
Quoted: 506 Post(s)
Liked: 341
Yowza!
Yup, I don't know how people watch scope movies on a 16:9 screen.
These two shots you posted say it all.
post #126 of 136 Old 05-04-2014, 04:10 PM
Trogloraptor's Avatar
Great looking room!!! Your dimensions are pretty similar to mine but I didn't see posted anywhere the height of your ceiling, I was just curious how tall it is so I can compare with different design ideas I'm contemplating?
Trogloraptor is offline
post #127 of 136 Old 05-06-2014, 09:03 PM - Thread Starter
Yzfbossman's Avatar
Quoted: 44 Post(s)
Liked: 75
My ceiling is 12' at max. The soffit is at about 9' 10"
Hope that helps
post #128 of 136 Old 05-14-2014, 10:27 AM
Thanks! And it does help.
My room is 22x24 (pre construction) but I only have a 10ft ceiling.
So I'll probably steal some design ideas from you if ya don't mind and I'm sure I'll be back for plenty more questions once the construction begins smile.gif
post #129 of 136 Old 05-14-2014, 12:02 PM - Thread Starter
Yzfbossman's Avatar
Quoted: 44 Post(s)
Liked: 75
post #130 of 136 Old 11-22-2014, 10:31 PM
mogrub's Avatar
Quoted: 212 Post(s)
Liked: 180
Great thread. Love your results, especially all the attention to detail. 👍
Every once in a while, quite inexplicably, things actually go according to plan.
mogrub is offline
post #131 of 136 Old 11-23-2014, 07:09 AM
rms8's Avatar
Quoted: 488 Post(s)
Liked: 317
^ Yes, very nice looking room! I assume it's completed by this time?
*DIY ConcreteBunker Rustic Dream Build w/11' screen, 11.2chnl, 8x18" IB subs, 28.8KW*
GR Research LS-9 + LS-C | Denon AVR-4520 11.2 | Sony VPL-HW55ES | DaLite 11' screen | Sanway FP-14000 & FP-10000Q | Sherbourn PA 7-350 | Behringer iNuke NU1000DSP | 8x IB318's | Buttkicker Original(2x), LFE(2x), MiniLFE(8x) | MinDSP 2x4 | 21'W x 27'L x 10'H | MiniSplit
rms8 is offline
post #132 of 136 Old 11-24-2014, 07:01 PM - Thread Starter
Yzfbossman's Avatar
Quoted: 44 Post(s)
Liked: 75
Yes, finished up and about 1,200 hours on the projector.
Here are the final pics:
post #133 of 136 Old 11-13-2015, 08:44 AM - Thread Starter
Yzfbossman's Avatar
Quoted: 44 Post(s)
Liked: 75
I just added a few more things to my room. Sometimes it's the little details that make a room more enjoyable and easier to live in/with.
Storage drawer:
I've been meaning to add drawer storage for some time and finally added a 3U drawer. My "rack" is just shelving so I had to jury rig how to make it work...a little "creative time" and I had it in securely. As always, when moving things on the "rack" I had to re-cable a bunch of stuff. I also took out my butt kicker amps. (need to sell them). I spent more time on the re-cabling than installing the drawer. LOL
Movie storage:
Next we need a better way to store our small Blu-ray collection. We don't buy a ton of movies, we netflix most. But the ones we do have were piling up and we need a better solution. While googleing I found the DiscSox system. I really liked how clean it looked and the slide out feature was great. (http://mmdesign.com/cd-dvd-blu-ray-storage.php) The first tray has about 70 discs in it. One day I'll follow through with my movie server....
Lastly I added some LED light for the drawer and the movie storage area. I used an LED strip from Lowes...the type that you can cut every three LEDs. I put 3 in the drawer and 3 above the movie drawers. I added a door plunger switch to turn the LED lights on and off. The lights are 12v and I just ran the 12v output through the door switch rather than running 120v and another wall plate. The color temp is is off but not enough to change them
Here are some pics of the work:
ID:	1054545   Click image for larger version
ID:	1054553   Click image for larger version
ID:	1054561   Click image for larger version
ID:	1054569   Click image for larger version
ID:	1054585   Click image for larger version
post #134 of 136 Old 12-05-2015, 10:50 AM
quamosa's Avatar
Quoted: 99 Post(s)
Liked: 72
Great theater!!! I am contemplating a darker navy colored carpet and I like how yours turned out. What is the brand and color name of it? I'd like to start testing a few samples.
My First Build Ever in progress
quamosa is offline
post #135 of 136 Old 12-05-2015, 11:05 AM
Dingo07's Avatar
The work and image looks great! Amazing job! How do you service the equipment in your "rack" - from the pics I saw it looks like custom shelves, not a Middle Atlantic style pull out steel rack. Is there access behind the equipment?
Dingo07 is offline
post #136 of 136 Old 12-09-2015, 06:48 PM - Thread Starter
Yzfbossman's Avatar
Quoted: 44 Post(s)
Liked: 75
Thanks....I can't seem to find it...I'll keep looking
I had a small "closet" built in the attic. Here is the door to the attic (hidden by curtains).
Then once in the Attic, there is another door into the side/back of the "rack".
Denon Avr 4311ci 9 2 Channel Network Multi Room Home Theater Receiver With Hdmi 1 4a , Epson Powerlite Pro Cinema 6020ub 3d 1080p 3lcd Projector , Triad , Subwoofers , Triad Inwall Gold 6 Lcr
