Small can lights: new or old construction housings for soffit? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-29-2013, 05:17 PM - Thread Starter
eyekode's Avatar
Quoted: 21 Post(s)
I am trying to redo my bonus room as a theater and will be starting construction this weekend.
But I am quite confused with the offerings for smaller can lights. I am building a new soffit and I would like some smaller can lights. But confusingly the old construction kits in 4" and especially 3" are much cheaper than the cost of a new work housing + trim.
Is there any good reason to go with the new construction housings?
Salem
eyekode is offline
post #2 of 4 Old 03-29-2013, 07:29 PM
colour's Avatar
Quoted: 13 Post(s)
Liked: 38
The new work housings are attached to the joists where as the remodel housings rely on the drywall. Personally I would go with the new work housing they are better, silly to go with remodel housings in a new construction..
colour is offline
post #3 of 4 Old 03-29-2013, 07:40 PM - Thread Starter
eyekode's Avatar
Quoted: 21 Post(s)
So will the remodel lights fail in some way? The issue is I can find 12$ 3" remodel kits but just the housing without trim for the new construction is 20$. So they end up costing like 3x the price.
Thanks for your input!
Salem
eyekode is offline
post #4 of 4 Old 03-29-2013, 08:50 PM
Quoted: 3266 Post(s)
Liked: 2751
I use those 4 and 3 inch remodel kits all the time. they are very easy to install, just be sure you have the right size hole saw.
