The Dog Diner (Re-)Do - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 68 Old 04-03-2013, 08:32 PM - Thread Starter
CDLehner's Avatar
Quoted: 768 Post(s)
Liked: 1146
AWESOME! Dude, I'm doing a happy dance here! If that's a picture of your theater room before drywall, you are golden!
CDLehner is offline
post #62 of 68 Old 04-03-2013, 08:59 PM
J_P_A's Avatar
Quoted: 591 Post(s)
Liked: 444
Frowny face!
The Plains Theater Has Begun
J_P_A is offline
post #63 of 68 Old 04-04-2013, 05:13 AM - Thread Starter
CDLehner's Avatar
Quoted: 768 Post(s)
Liked: 1146
JPA, I was joking; that is my insulation.
CDLehner is offline
post #64 of 68 Old 04-06-2013, 10:58 AM - Thread Starter
CDLehner's Avatar
Quoted: 768 Post(s)
Liked: 1146
So...some good news, and some bad (but mostly good biggrin.gif)
As advised; before I go about killing my buzzing nuisances...I layered-up, and tried to find the source of my invaders. Too cold here last night; they were long gone. But I'll keep trying.
However, going up into the HT today...I definitely had more a sense of can-do, than can-don't. Miss my HT, and the positives are starting to dance in my head; more-so than the problems.
As such...if I'm really getting down to business; while it's not sexy, one of the first projects probably has to do with the "adjacent" space (can we just start calling this the "storage area"?).
As I've mentioned; we've got the ceiling joists from our Bedroom...jutting up into that space.
Rather than have that just be dead, unusable space; I want to create some much-needed storage area from it. Probably just needs to be "squared-off", like this...right? All I want to be able to do, is store boxes...up on top of it (as we've previously talked about, that area would mostly be used for). I could probably even do something like this myself; seems to be about the easiest of DIY projects (and...it saves a few hunny against the re-model budget; and...gets boxes the hell off the riser, so I can't start to envision that space empty).
If it were me, I'd just do some 2x4 framing and MDF. My only concern; that top "shelf" will span about 11'. Do I need more bracing, than just the ends...to keep it from sagging in the middle? Not sure how to address that. Thanks
CDLehner is offline
post #65 of 68 Old 04-06-2013, 01:12 PM
J_P_A's Avatar
Quoted: 591 Post(s)
Liked: 444
Depending on how heavy the boxes are that you plan to put up there, I'd probably just build a "floor" with 2x6's spaced on 16" centers, then put some 1/2" decking on top. something cheap like OSB rather than MDF. If you want to make it a little sturdier, then you could go up to 3/4" ply, but I don't think it's necessary unless you're planning to put some pretty heavy stuff up there, and then you'll need to look at the framing a little closer as well.
J_P_A is offline
post #66 of 68 Old 04-06-2013, 01:27 PM
RTROSE's Avatar
Quoted: 192 Post(s)
Liked: 167
^^^^^^^^Agreed. Boxing it in (or squaring it off) would be pretty easy IMO and would actually be a benefit to the "storage area" FKA the adjacent space. biggrin.gif
Glad to hear that you are being infected with a more positive outlook. Attitudes can be contagious so glad to hear that you are "catching" a better one.
RTROSE
RTROSE is offline
post #67 of 68 Old 04-18-2013, 09:23 AM
RTROSE's Avatar
Quoted: 192 Post(s)
Liked: 167
Don't think for a second you are off the hook. We need updates.
RTROSE
RTROSE is offline
post #68 of 68 Old 05-06-2013, 08:29 PM - Thread Starter
CDLehner's Avatar
Quoted: 768 Post(s)
Liked: 1146
RTROSE
Ha...got back-burnered; while I took on the pet-project of re-vamping my lawn RT.
I'll be back soon. I've actually reached-out to my GC; but he hasn't responded in a few days.
CDLehner is offline
