New House and New Dedicator Theatre Room... Will this work for a projector and screen? - AVS Forum | Home Theater Discussions And Reviews
Old 03-31-2013, 09:06 AM - Thread Starter
BuddyRich's Avatar
So we are moving into a new house in a couple of months and this is the room I have to work with to build the theater. Not ideal but workable I think.
I plan to refinish it with drywall and new flooring but the dimensions will mostly stay as is (though I might loose an inch in floor to ceiling height due to floating floor.
I want to do a projector and given the layout of the doors, etc. I will likely project onto the left wall in the picture, sitting against the right wall. Its almost a square room, and their are no windows in the room (they are in the laundry and study room). Unfortunately there is a large bulkhead covering duct work. I'll put the servers and maybe the components in the workshop (already has built in shelving).
Ideally I'd be projecting against the wall opposite the stairs but the wife is against the idea of our backs towards the stairs (I don't really blame her) so Ive got to make the left wall work.
Whats my best bet? I am mulling something between a 106" to 92" screen. I am not sure a ceiling mount would work give the bulkhead. I'd have to drop it about 2 feet to clear the bulk head.
BuddyRich is offline
Old 03-31-2013, 09:59 AM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
Figure out your seating arrangement and room layout first, then worry about the projector and screen size. The projector can be mounted on the ceiling, it will "clear" the bulkhead as long as the screen is not above the bottom of the bulkhead (easily).
jautor is offline
alittletank's Avatar
Liked: 26
The picture will help the smart guys here see what you are dealing with for bulkheads however a floor plan drawing would be helpful as well. Draw it out or use paint with dimensions and you will get helpful suggestions.
alittletank is offline
Old 03-31-2013, 10:02 AM
CDLehner's Avatar
Quoted: 767 Post(s)
Liked: 1146
CDLehner is offline
Old 03-31-2013, 11:27 AM - Thread Starter
BuddyRich's Avatar
Feng Shui. Its bad Feng Shui to have your back to a doorway. Apparently. ;-)
I don't go for that but in some respects I could see how it could be unnerving if intently watching something, to have someone sneak up behind you unawares as you back is to the main room entrance.
I'll work on a floorplan diagram next (need to take a few more measurements first).
Old 03-31-2013, 04:19 PM
Quoted: 3256 Post(s)
Liked: 2743
Old 04-01-2013, 01:19 AM
cheezit73's Avatar
Liked: 24
I was just explaining to my wife your plight while extolling her virtues as I'm lucky enough to have a wife who absolutely appreciates the design of the theatre around function. My wife requested I post her reccomendations in your thread.
1. Orient the room the way you want it for optimum audio and video (There is no exception to this.).
2. For seating use an L shape sectional couch, if she sits in the corner L she can easily see the stairway to her side with minimal immersion loss.
3. Go 11.2 surround sound so that she is so immersed that she forgets about the stair case.
4. Get a new wife.
Seriously though, the sectional L couch might be a great compromise.
cheezit73 is offline
