Surround Speakers and Acoustic Treatments - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-31-2013, 10:10 PM - Thread Starter
Spall's Avatar
Hi all,
I posed this question at the tail end of another thread of mine that has sort of dwindled over in the Audio Theory section. I thought maybe I should repost here and see if anyone has some opinions for me.
--snipped from other post--
My pillars for my rear surrounds are butting up to the bass traps I made for the rear corners (see attached photo). The surrounds are dipoles with tweeters mounted on a 45 degree facing. I realized that my surrounds are going to be partially firing right along these two bass traps.
Is this cool? Or is this gonna cause me some problems?
Thanks for any help.
-Dave
"Hi floor! Make me a sammich!" - Gir
Spall is offline
post #2 of 3 Old 03-31-2013, 11:32 PM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 441
Well you generally don't want to absorb any more surround energy than you have to. It kind of defeats the purpose. While I don't think it's going to cause any serious issues what about covering the bass traps with a thin sheet of some type of covering. I did this with mine (picked up a 1/8" thick piece of sheeting at HD and wrapped with GOM) for the same thing. The bass will definitely still be absorbed, while allowing the upper frequencies (surround information) to reflect.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #3 of 3 Old 04-01-2013, 10:19 AM - Thread Starter
Spall's Avatar
I'm building fabric frames for my walls anyway, it would be a simple matter to put a thin backing on the frames covering the trap.
Thanks for the advice.
-Dave
Spall is offline
