Home theater seating riser tread lighting - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #31 of 42 Old 08-14-2013, 10:22 PM - Thread Starter
depew23's Avatar
Oh gotcha. Yep just used standard non waterproof strips connected with 4 wire
depew23 is offline
post #32 of 42 Old 08-15-2013, 08:52 AM
Bryan A Hagan's Avatar
Got it, I have tons of the 5050 with waterproof covering. You think that will fit in the track or will I need to take the waterproof covering off.
Bryan A Hagan is offline
post #33 of 42 Old 08-15-2013, 05:36 PM - Thread Starter
depew23's Avatar
your LEDs would not probally fit in the track i used. It is designed for 3528s and is a rather tight fit laterally. But im sure there are other tracks that will fit both 5050 and water proof LEDs in them
depew23 is offline
post #34 of 42 Old 08-26-2013, 12:27 PM
J_P_A's Avatar
Quoted: 591 Post(s)
Liked: 443
How did you cut the lens?
The Plains Theater Has Begun
J_P_A is offline
post #35 of 42 Old 08-26-2013, 02:14 PM - Thread Starter
depew23's Avatar
just used a chop saw then used a steel file to get the burs off.
depew23 is offline
post #36 of 42 Old 08-26-2013, 02:18 PM
J_P_A's Avatar
Quoted: 591 Post(s)
Liked: 443
Chop saw as in a miter saw for wood, or a chop saw for metal?
J_P_A is offline
post #37 of 42 Old 08-26-2013, 08:13 PM - Thread Starter
depew23's Avatar
Miter saw for wood. But I also used a cutting wheel on a radial arm saw that worked real well too.
depew23 is offline
post #38 of 42 Old 10-02-2013, 10:28 AM
Nobody Special Member
BamaDave's Avatar
Quoted: 86 Post(s)
Liked: 44
If you guys have any additional photos, ideas to share I would be appreciative as I’ll be working on my 2nd row riser here in the next couple of weeks. Thanks, David
BamaDave is offline
post #39 of 42 Old 10-30-2013, 12:31 AM
gerard143's Avatar
Quoted: 12 Post(s)
Use electroluminescent wire. Cheap and awesome
http://www.lighttape.com/library/LumaGrip%20at%20Boujis2.jpg
gerard143 is offline
post #40 of 42 Old 11-06-2013, 05:40 PM - Thread Starter
depew23's Avatar
I liked those too. Only issue is it didn't fit into the design of the room. The plastics took away from the very sleek modern classy design. They just looked like an after thought.
depew23 is offline
post #41 of 42 Old 11-06-2013, 06:24 PM
TMcG is offline
post #42 of 42 Old 02-26-2016, 08:06 PM
Liked: 0
For your consideration, we have a stainless steel, custom flush-mount LED nosing product that works great for theater applications.
stairNosing is offline
