Wiring my Home Theater - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-05-2013, 10:47 AM - Thread Starter
kuip64's Avatar
Quoted: 14 Post(s)
Hey all, I am in the process of finishing off my basement with a home theater. Nothing over the top but I am planning for surround sound, large TV, and a gaming system at a minimum. My TV will be centered on a wall and my AV equipment will be in a cabinent about 10 feet away. I am at the point now where I need to start wiring but I am a bit stuck on how to run power to my equipment. Should I put all of my AV equipment on one circut with multiple outlets? Multiple circuts? Should I hardwire in a surge protector in the back of my cabinent? If so, what kind? Or should I just plug a surge protector into one of my outlets? I just want to do it right. If you have any help or thoughts on what to do, please let me know. Thanks,
kuip64 is offline
post #2 of 4 Old 04-05-2013, 11:36 AM
petew's Avatar
Quoted: 25 Post(s)
Liked: 68
If you don't have huge power amps or anything one circuit should be fine.
I used a power strip like this. Plenty of outlets and nice spacing. Forty bucks at the big orange box.
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
post #3 of 4 Old 04-05-2013, 08:40 PM - Thread Starter
kuip64's Avatar
Quoted: 14 Post(s)
Thanks, but then you still dont have any surge protection, right?
kuip64 is offline
post #4 of 4 Old 04-05-2013, 08:48 PM
Gerry S's Avatar
I used something like this to protect my wall mounted plasma:
http://www.amazon.com/Leviton-5280-W-Suppressor-Receptacle-Industrial/dp/B0006I33Y6
Then just use a standard plug in surge suppressor for your cabinet.
Gerry S is offline
