Best way to hide cables for running along the ceiling? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 33 Old 04-05-2013, 10:52 AM - Thread Starter
vivithemage's Avatar
Quoted: 23 Post(s)
I have a finished basement with a projector ... so I need to run an hdmi cable and power cable on (don't want to cut into it for 6 feet) the ceiling, and down the wall...so 6 feet of white ceiling, 6 feetish of wall. Any recommendations on hiding the two cables? Like a white channel maybe?
Also, any ideas on hiding 14gauge speaker wire along carpet? Maybe just shove it under the trim if I can?
vivithemage is offline
post #2 of 33 Old 04-05-2013, 11:02 AM
malelan's Avatar
there is a product for this, its called wiremolding, it starts white but can be painted to suit your needs, i believe monoprice carries their version of this product too. search "cable raceways"
http://www.monoprice.com/products/product.asp?c_id=105&cp_id=10520&cs_id=1052005&p_id=8288&seq=1&format=2
here is a link to a starter kit, but you can order pieces individually.
malelan is offline
post #3 of 33 Old 04-05-2013, 11:16 AM - Thread Starter
Quoted: 23 Post(s)
cool, thanks...i'll try a runner.
post #4 of 33 Old 04-05-2013, 11:27 AM
domz777's Avatar
Quoted: 76 Post(s)
Liked: 76
I have nearly the same stuff for about 5 bucks a piece - look in the classifieds. Contact me and we can work something out. smile.gif
domz777 is offline
post #5 of 33 Old 04-05-2013, 11:31 AM
Quoted: 3254 Post(s)
Liked: 2743
Real men run the wires in the ceiling and walls. Cutting and patching drywall is a merit badge every homeowner needs to earn.
post #6 of 33 Old 04-05-2013, 12:00 PM - Thread Starter
Quoted: 23 Post(s)
post #7 of 33 Old 04-05-2013, 12:03 PM
Liked: 2743
Are you saying you don't own a drill? For six feet you just stick it in and grab with your hand.
post #8 of 33 Old 04-05-2013, 12:46 PM
tlogan6797's Avatar
Quoted: 105 Post(s)
Liked: 131
[resisting the urge to go there]
You throw a softball like that and SOMEBODY is going to hit out of the park.
[STILL resisting the urge to go there]
[and let me tell ya, it ain't easy]
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
post #9 of 33 Old 04-05-2013, 01:04 PM
cw5billwade's Avatar
Quoted: 328 Post(s)
Liked: 184
cw5billwade is offline
post #10 of 33 Old 04-05-2013, 01:08 PM - Thread Starter
Quoted: 23 Post(s)
on a popcorn ceiling? You're crazy handman!
post #11 of 33 Old 04-05-2013, 01:10 PM
tlogan6797's Avatar
Quoted: 105 Post(s)
Liked: 131
there goes Big sticking his hand in agian! I went there!
SWING! and a miss.
That's not where I was going.....
Next batter!
Tom Logan
post #12 of 33 Old 04-05-2013, 01:13 PM
Quoted: 328 Post(s)
Liked: 184
I see now you stick it in then grab it!
post #13 of 33 Old 04-05-2013, 01:30 PM
Liked: 2743
I hate popcorn ceilings, but if you have a popcorn ceiling how are you going to attach a raceway and make it nice and flat?
So you cut two holes in the ceiling the exact size of old work electrical boxes. One for the outlet and one for a HDMI cable.
On the wall you cut a hole at the top big enough to get your drill inside the stud bay and two holes below for old work boxes again
You drill holes in the top plate of the wall
You fish your romex and hdmi cables up through the holes in the top plate toward the holes in the ceiling, now you stick your hand in the old work boxes and feel around for the wires. Once you've got the ceiling wires in postion you send the other end straight down to the lower wall holes.
Install old work boxes
Use a PowerBridge connection for the electrical service and a brush plate for the HDMI.
patch the hole in the wall, sand and paint.
This assumes you've located the orientation of the ceiling joists and studs and have everything planned out.
post #14 of 33 Old 04-05-2013, 02:45 PM - Thread Starter
Quoted: 23 Post(s)
not a bad idea ... i'll have to see where the studs are. I'll still have a cable going down the wall though ... or maybe not, if I can drill a nice spot for them...wonder if I can find the blueprints to tell me where the studs are ...
post #15 of 33 Old 04-05-2013, 02:53 PM
TMcG's Avatar
Quoted: 1072 Post(s)
Liked: 870
THAT'S the big assumption I was thinking about, otherwise the advice is sound.
I'm not a fan of surface-mount wiremold, but if I had to put some across a popcorn ceiling I would simply mark where I wanted to install the wire mold and scrape off ONLY that part of the popcorn ceiling so the wiremold would lay perfectly flat against the sheet rock.
TMcG is offline
post #16 of 33 Old 04-05-2013, 03:05 PM - Thread Starter
Quoted: 23 Post(s)
not a bad idea either TMcG ...
what about speaker wires around the floor? This one I can't really drill, as it is cement floor...but I do have a ledge, I could put a runner on...it is a foundation ledge like this:
post #17 of 33 Old 04-05-2013, 03:16 PM
TMcG's Avatar
Liked: 870
Two ways:
  1. I would run 16/4 to get all conductors for a stereo pair inside one sheathed wire.
  2. If there isn't enough room for even a single wire underneath the baseboard, remove the baseboard and cut a small channel at the bottom of the drywall. Run your wire and replace the baseboard to cover the fact you were even there
TMcG is offline
post #18 of 33 Old 04-05-2013, 03:33 PM - Thread Starter
Quoted: 23 Post(s)
It is not drywall though, it is cement.
What do you mean 16/4?16 gauge, 4 wires? In that picture, I was thinking of running the wires on top of that little ledge of the foundation... you'd only see the wires as I run them from the ledge to the floor, to the speakers.
post #19 of 33 Old 04-05-2013, 03:57 PM
greedo's Avatar
I remember seeing some cable raceway that masqueraded as crown molding:
http://www.cableorganizer.com/raceway-crown/
greedo is offline
post #20 of 33 Old 04-05-2013, 11:27 PM - Thread Starter
Quoted: 23 Post(s)
If I don't cut holes, any good way to mount the cables to the ceiling? I basically need a decent hook to hold the hdmi and power cable.
post #21 of 33 Old 04-06-2013, 04:49 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
You can Google baseboard + raceway + cable to find a number of products that could replace your baseboard and hold cables.
Look on legrand's site to find a lot of options for surface mount raceway.
http://www.legrand.us/wire-cable-management/raceways.aspx
Home Depot carries the Wiremold basics (made by Legrand).
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #22 of 33 Old 04-06-2013, 04:55 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
I have a ledge like that in my basement. It's covered with drywall, and the ledge is preserved.
With that door there, I understand that adding drywall would be difficult.
Legrand raceway would allow you to properly add power outlets to the wall, with the outlets integrated into the raceway.
http://www.legrand.us/wiremold/raceway/nonmetallic-raceway/multi-channel-raceway/5000-access-large-capacity-raceway/5000-access-large-capacity-raceway.aspx#Components
D6B75D6E08644A6EB8077611F0D5B833.ashx?w=300&h=300&bc=ffffff&as=1
Neurorad is offline
post #23 of 33 Old 04-08-2013, 08:24 AM - Thread Starter
Quoted: 23 Post(s)
That is cool, but those pictures couldn't be any smaller ...
for the ceiling I was going to run this:
https://www.amazon.com/dp/B0008JIQ18/ref=as_li_ss_til?tag=vivithemageco-20&camp=0&creative=0&linkCode=as4&creativeASIN=B0008JIQ18&adid=1E3RJ0JY1DA66HRKXGZC&
I am also going to use it for the speaker wire...my GF was OK with the idea of it, as the moulding would have looked weird, she also thought it'd be a bad idea to make a few holes for just a few feet in the ceiling. I need to find a good bracket to hold it to the celiing now though, all I see is lame adhesive kinds.
post #24 of 33 Old 04-08-2013, 12:38 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
If you do a google image search of wiremold access 5000 (or any of the other wiremold products), you can find other images.
Do you think that flexible sleeve would be good for the ceiling? Good for hiding bundles, but no structural support.
Neurorad is offline
post #25 of 33 Old 04-08-2013, 12:51 PM - Thread Starter
Quoted: 23 Post(s)
Are there any places locally (55443)that have that wiremold access 5000 stuff? I'd love to run my basement with it.
post #26 of 33 Old 04-08-2013, 07:02 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Did you search the wire mold site for distributors? Might want to buy a couple pieces on Amazon, to play with it (or any other online distributor).
Cableorganizer.com and cablestogo.com might be some places to look.
Neurorad is offline
post #27 of 33 Old 04-09-2013, 05:01 AM
TMcG's Avatar
Liked: 870
Oops. I meant cut a channel in the back of that baseboard, as with a router. Assuming that IS baseboard in your picture...biggrin.gif
And if you are looking for a way to conceal the wires, TechFlex is definitely NOT the answer. Just go with the professional Wiremold products and paint to color match.
TMcG is offline
post #28 of 33 Old 04-09-2013, 05:44 AM
domz777's Avatar
Quoted: 76 Post(s)
Liked: 76
Even as lousy as these pics are, you can still see how much of an improvement putting wiremold in makes.
I have all concrete walls and ceiling. It's an old apt bldg, so I had no other option.
These are kinda like before and after shots
Ignore the circled speakers, but do notice the wires running between them, and also note the wire running
out to the 3D glasses emitter
Here, all wires , um , molded LOL
You need to look close, but you can see the wires running above the screen.
Again, wires - molded - MUCH better.
I have a few cases of this wiremold left over, let me know if you want some.
domz777 is offline
post #29 of 33 Old 04-09-2013, 08:07 AM - Thread Starter
Quoted: 23 Post(s)
Doesn't look bad, but I don't think wiremold will work on my popcorn ceiling ... I do like the idea of that legrand stuff....if I can find it, does anyone have an amazon link, I don't see it on there.
post #30 of 33 Old 04-09-2013, 08:49 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
http://gcs.cableorganizer.com/?q=wiremold+access+5000
I don't see much of the Wiremold Access 5000 on Amazon.
Legrand has other similar products, if you search their site.
Neurorad is offline
