Shermer Theater - Construction Wrapping Up - Page 40 - AVS Forum | Home Theater Discussions And Reviews
 145Likes
Old 04-06-2016, 06:56 AM - Thread Starter
JRock3x8's Avatar
Quoted: 655 Post(s)
Liked: 165
Originally Posted by BllDo View Post
Nice, I really like those speakers. Are you going to mount those as two rows of side surrounds or a pair for side and one for rear surrounds?
well for the time being 2 of them will go in storage until time and money allow for a 7 channel receiver. For now, I'll just 2 as the rears.
I'd like to reiterate that you've convinced me to spend $1500 on speakers when I had no intention of spending anywhere near that much when this project started. Well done.
edit : I went and spent $200 on the Sub on my own, even against your wishes so revise that to $1300...still...
edit 2 : will I be able to run those traids in serial or parallel for a 9 speaker surround configuration?
JRock3x8 is offline
Old 04-06-2016, 07:07 AM - Thread Starter
JRock3x8's Avatar
Quoted: 655 Post(s)
Liked: 165
and of course this pops up today....
Onkyo TX-NR545 7.2-Channel Network Ready 4K A/V Receiver $285 http://slickdeals.net/f/8641458-onky...source=twitter
JRock3x8 is offline
Old 04-06-2016, 08:31 AM - Thread Starter
JRock3x8's Avatar
Quoted: 655 Post(s)
Liked: 165
I don't understand Atmos wiring - shouldn't there be 11 sets of terminals?
JRock3x8 is offline
Old 04-06-2016, 08:46 AM
Quoted: 13 Post(s)
Liked: 27
This receiver is only capable of 5.1.2 maximum in an Atmos configuration. There are 7 pairs for the speakers and one sub section.
If you are looking for an 11 channel setup aka 7.1.4, you need to buy a receiver further up the chain. Most will max out at 9 channels of amplification and require and additional 2 channel amp to drive them.
I know it gets about as clear as mud but that seems to be the standard for now.
Cheers.
CinemaAwakens is offline
Old 04-06-2016, 08:48 AM - Thread Starter
JRock3x8's Avatar
Quoted: 655 Post(s)
Liked: 165
Cheers.
thats what I thought - thanks
JRock3x8 is offline
Old 04-06-2016, 08:54 AM
Quoted: 13 Post(s)
Liked: 27
No sweat!
Old 04-06-2016, 09:33 AM
BllDo's Avatar
Quoted: 593 Post(s)
Liked: 385
That may be so, but that $1500 is about what you would have to spend on just your Left and Right new. So, at least they were pretty good deals.
I would try just running 7.1 at first. You might never need to add a second row of side surrounds. If you did, you would want to run them together for a combined 8 ohm load so you don't stress your receiver otherwise run the extra set into another amplifier like this one.
Gouie likes this.
BllDo is offline
Old 04-06-2016, 09:37 AM - Thread Starter
JRock3x8's Avatar
Quoted: 655 Post(s)
Liked: 165
so if I needed to buy everything that I bought new, what would that have cost? Yah know, when the wife starts asking questions...
JRock3x8 is offline
Old 04-06-2016, 10:04 AM
BllDo's Avatar
Quoted: 593 Post(s)
Liked: 385
The Silver LCRs would be $850 - $1000 each. The Gold Sats are hard to compare to anything current. Retail on those was probably in the neighborhood of $600 - $700, but that's a guess. So, $5000 worth of speakers for $1300 isn't too bad. Plus, unless they get damaged, they will likely be the only speakers you'll ever need*.
*Unless you keep reading AVS, then the upgrade bug will eventually hit and you'll tear the whole room apart and start over with everything.
JRock3x8 likes this.
BllDo is offline
Old 04-06-2016, 10:06 AM - Thread Starter
JRock3x8's Avatar
Quoted: 655 Post(s)
Liked: 165
I feel like for my own mental health, I should take a break from this forum once I get to a "completion point" if that ever happens
BllDo likes this.
JRock3x8 is offline
Old 04-06-2016, 10:27 AM
BllDo's Avatar
Quoted: 593 Post(s)
Liked: 385
Completion point. That's a good one.
JRock3x8 and COZisBack like this.
BllDo is offline
Old 04-06-2016, 10:59 AM
HopefulFred's Avatar
Quoted: 496 Post(s)
Liked: 432
I spent $1500 on speakers and I still have to build them. You did well.
HopefulFred is online now
Old 04-06-2016, 11:04 AM - Thread Starter
JRock3x8's Avatar
Quoted: 655 Post(s)
Liked: 165
thanks for the encouragement
JRock3x8 is offline
Old 04-06-2016, 12:54 PM - Thread Starter
JRock3x8's Avatar
Quoted: 655 Post(s)
Liked: 165
I neglected to mention that the seller of the speakers complimented me on my good taste in speakers - I said well actually I don't but I have friends who DO have good taste in speakers and they recommended these...
he seemed a bit bewildered that someone would buy speakers for that much money on a recommendation alone. He doesn't know you guys like I do
BllDo likes this.
JRock3x8 is offline
Old 04-06-2016, 01:14 PM - Thread Starter
JRock3x8's Avatar
Quoted: 655 Post(s)
Liked: 165
once again, I don't understand signal flow on this. How do you output from the receiver into something that this thing understands?
JRock3x8 is offline
Old 04-06-2016, 04:55 PM
Quoted: 3424 Post(s)
Liked: 2890
on the back of the receiver there are a bunch of outputs, labeled by channel, Then take an RCA cable and plug it into one of the inputs on the upper corners labeled unbalanced. That is the simplest.
Old 04-06-2016, 07:16 PM
Quoted: 496 Post(s)
Liked: 432
Big is right, but it may not be clear that many receivers don't have the outputs that would be required.
You would need the receiver to have "pre-outs":: output ports of the signal "pre amplification." Remember that within a receiver the signal is 1) received 2)decoded 3)processed 4)equilized 5)amplified. If the receiver has pre-outs, that just means that you can tap into the signal before the last step, for the purposes of offloading the amplification to somewhere else or for inserting further processing (since you can't process the signal post-amplification - only "pre")
Old 04-07-2016, 02:38 AM - Thread Starter
JRock3x8's Avatar
Quoted: 655 Post(s)
Liked: 165
so this doesn't have the required pre-outs right?
JRock3x8 is offline
Old 04-07-2016, 06:04 AM
nitro28's Avatar
Quoted: 131 Post(s)
Liked: 42
No it doesn't. You would need a higher end receiver.
James
My theater build 2015 (Circle N theater)
http://www.avsforum.com/forum/19-ded...ter-build.html
nitro28 is offline
Old 04-07-2016, 06:11 AM
Liked: 2890
it has a subwoofer pre out. not sure what that one is below it, need to check the manual.
Old 04-07-2016, 07:34 AM
BllDo's Avatar
Quoted: 593 Post(s)
Liked: 385
The other solution, though certainly not the first choice, would be to try to use a RCA Line Level converter.
http://www.amazon.com/Scosche-2-Chan.../dp/B00009UHRE
They are used frequently in car audio when trying to hook up an amp to a stock head unit. I don't know what this would do to the combined impedance of the speaker pairs. I also don't know what it would do to the sound. Fidelity isn't as much of a concern for most of the people using these. But it might be a cheaper way to add an amplifier than finding a new receiver with pre-outs.
BllDo is offline
Old 04-07-2016, 06:24 PM
TMcG's Avatar
Quoted: 1124 Post(s)
Liked: 962
It's a second subwoofer preamp output if you want to run stereo subs.
TMcG is offline
Old 04-08-2016, 07:54 AM - Thread Starter
JRock3x8's Avatar
Quoted: 655 Post(s)
Liked: 165
the sale price is long gone on this so it's fine. I'm not in a huge hurry to buy another receiver - especially having just dropped $650 on speakers (Thank you, @BllDo ...)
JRock3x8 is offline
Old 04-08-2016, 07:59 AM
BllDo's Avatar
Quoted: 593 Post(s)
Liked: 385
Hey, you'll thank me once you get those puppies wired up.
BllDo is offline
Old 04-08-2016, 07:59 AM - Thread Starter
JRock3x8's Avatar
Quoted: 655 Post(s)
Liked: 165
I already did thank you - it just wan't very genuine
BllDo likes this.
JRock3x8 is offline
Old 04-08-2016, 12:16 PM - Thread Starter
JRock3x8's Avatar
Quoted: 655 Post(s)
Liked: 165
Drywall is done.
OMG what a mess these guys left behind.
Electric and doors on Monday and then I think construction is done.
Oh and you should have seen the face on the guy when I asked him to patch the hole where they pulled the wire through by mistake. You would have thought that I just told him I killed his dog.
ID:	1366106   Click image for larger version
ID:	1366114   Click image for larger version
ID:	1366122   Click image for larger version
JRock3x8 is offline
Old 04-08-2016, 12:58 PM
Gouie's Avatar
Quoted: 192 Post(s)
Liked: 62
Looking good. Curious, and this may have been brought up previously; is there a specific reason you elected not to finish behind the screen?
Gouie is online now
Old 04-08-2016, 01:14 PM
COZisBack's Avatar
Quoted: 91 Post(s)
Liked: 66
My guess would be already planned acoustic panels.
My Main Setup
Display: Panasonic TC-P60ST60 w/Acoustic Research ARRX18G XSight Touch
Sound: Yamaha RX-V375 / Pioneer AJ SP-PK52FS 5.0 / Dual SVS PB-1000s
Sources: DirecTV HR44/200 / Xbox One 500GB w/Kinect & 4TB External / 1st Gen Chromecast / HP EliteBook 8460p (Win10)
COZisBack is offline
Old 04-08-2016, 02:05 PM - Thread Starter
JRock3x8's Avatar
Quoted: 655 Post(s)
Liked: 165
Cost and sound. May cover with fluffy.
JRock3x8 is offline
Old 04-08-2016, 02:06 PM - Thread Starter
JRock3x8's Avatar
Quoted: 655 Post(s)
Liked: 165
No I don't think so.
A finished wall would reflect a whole ton of sound. Also cost effective. We covered this like 300 posts ago
edit : it was almost 400 posts ago
my initial suggestion :
BllDo backs me up :
COZisBack likes this.
JRock3x8 is offline
