Urgent........second layer screw length - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 04-13-2013, 06:37 AM - Thread Starter
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 961
First layer of OSB is done after using 1-1/4 inch Grabber fine thread screw.............so far so good!
Green glue and second layer of 5/8 sheet rock is about to commence but can only source 1-5/8's inch Grabber screw.....been looking for 2" grabbers but special order would take 7 days which is too late due to drywall coming Tuesday.
Will 1-5/8's " fine thread Grabber screw be adequate for 5/8'' osb, GG, then 5/8 inch Drywall? Help is gladly appreciated.............and yes, I've already searched the question. smile.gif
doublewing11 is offline
post #2 of 12 Old 04-13-2013, 06:30 PM
Quoted: 3647 Post(s)
Liked: 3099
I would grab 2 inch fine thread screws of any brand if you can't get the Grabber. It will be fine, I think I'm the one that promoted Grabber and I like them but I've also used Grip-Tite from Home Depot without issue.
post #3 of 12 Old 04-13-2013, 07:52 PM
Johnsteph10's Avatar
Quoted: 31 Post(s)
Liked: 24
5/8 + 5/8 = 1 2/8
1 5/8 screw
= 3/8 penetration into studs...
You definitely want to go more.
I used Griptite without any issues. I'm surprised you can't find the Grabber in 2 inch lengths... have you tried a drywall supplier vs. the big box stores? I got mine much cheaper through my drywall supplier than I ever could have through Lowes/HD.
John
Johnsteph10 is offline
post #4 of 12 Old 04-14-2013, 04:01 AM
JRock3x8's Avatar
Quoted: 708 Post(s)
Liked: 187
Is he screwing into studs or furring strips? If furring strips, then wouldn't it not matter re screw length?
JRock3x8 is offline
post #5 of 12 Old 04-14-2013, 04:33 AM
Liked: 3099
Since he said FINE thread screws for the first layer I assume he is screwing to metal hat channel in a Resilient clip and channel system. That being the case, it is critical to use the correct length screw so that no scew makes contact with a stud and short circuits the decoupling system. Even when you are careful, keeping track of where the studs/joists when you are focused on hitting the channel is tedious and drywall crews slap up the screws with mindless abandon as long as they hit the channel. Using the correct length makes the process fool proof as long as you hide the two inch screws until the first layer is up. First layer 1 1/4 second layer 2. You want to be sure the second layer is secure to the channel not just the first layer.
post #6 of 12 Old 04-14-2013, 04:45 AM
JRock3x8's Avatar
Quoted: 708 Post(s)
Liked: 187
The part I can't figure out is that the furring channel is only 1/16" thick so it seems to me that any screw that penetrates it is going to fasten or hold but it seems like you're saying that's not the case?
JRock3x8 is offline
post #7 of 12 Old 04-14-2013, 05:32 AM
Liked: 3099
A screw is tapered you want to get a good grip on the channel. Using at 1 5/8 screw to attach 1 1/4 inch of material is cutting it too close, I've tried. Use the 2
post #8 of 12 Old 04-14-2013, 07:37 AM - Thread Starter
Quoted: 229 Post(s)
Liked: 961
This was my exact concern........................
Yes, and the reason why I sourced the grabber screws. At first, I was a little concerned experimenting with small pieces of channel with these screws........they wouldn't hold anything.......it wasn't until we torqued down and changed to screw gun rather than rattle guns did they show promise. Spinning the screws is very easy to do.............and I'm glad I took 10 minutes to experiment!
post #9 of 12 Old 04-14-2013, 07:42 AM - Thread Starter
Quoted: 229 Post(s)
Liked: 961
Been all over a 75 mile radius...........drywall suppliers.............big box stores........local builder supply business..........no one has 2" grabber. 1-1/4, 1-5/8, and 2-1/2 inch fine thread screws are abundant, but not 2 inch........go figure!
If 2" griptite works............then I'll hand the drywaller crew those.........
thanks to all........I'm good to go.
post #10 of 12 Old 04-14-2013, 07:53 AM
JRock3x8's Avatar
Quoted: 708 Post(s)
Liked: 187
Got it. Thanks for explaining.
JRock3x8 is offline
post #11 of 12 Old 04-15-2013, 10:14 AM
235
235's Avatar
I think that's the problem I had on my first layer. Contractor started with 1 1/4 fine thread through 5/8 OSB into 25 gauge hat channel but it wasn't holding. He quickly switched to coarse thread and those held. I think the problem may have been the high speed gun he was using mad.gif. My 2nd layer isn't up yet so maybe I can get him to switch to 2" fine thread on 2nd layer. I hope coarse on the first layer is safe to leave as-is?
235 is offline
post #12 of 12 Old 04-15-2013, 08:44 PM - Thread Starter
Quoted: 229 Post(s)
Liked: 961
Torquing the driver is key.............I tacked up several 4 X 8 sheets of 5/8's OSB with only 4-5 screws and came back the next day and screwed in the rest at 4-6 inch intervals. I feel comfortable the sheets will hold even through a massive earthquake!
The only issue I have now is watching over the drywall crew and supervise their guns are torqued correctly. I have scrap around and will have them test their drivers........or let them use mine.
