The retirement dream home theater - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #361 of 408 Old 02-25-2014, 10:30 AM
marvoroberts's Avatar
Question then... I had not thought of having a stage...Is there something important about having a stage? I was just going to have a audio transparent curtain to the sides and make a black moveable frame to suit the image. This is going to involve a friend of mine who is big into making things happen. The masking is quite interesting and that is my next BIG port of call.
Many Thanks
Mark
marvoroberts is offline
post #362 of 408 Old 02-25-2014, 01:56 PM - Thread Starter
cw5billwade's Avatar
Quoted: 328 Post(s)
Liked: 184
Stage is decoupled from the rest of the room I used roofing felt others use the acoustic mats and are used primarily as in my case to run electric and speaker wires through and stuffed with insulation to absorb base (base trap). In a basement build they put sand in them so the Subwoofer sitting on the stage does not vibrate the rest of the house as concrete does allow sound waves to travel nicely. This added mass helps with the Base as well. Since I am in a second floor build I can’t put a ton of sand in the stage without structural damage and only used the pink insulation. I do fell the rumble but I like it. I have seen rooms where the stage itself is built out no further than the screen wall. Then the treatment around the screen wall includes the stage so it is all black plush velvet. Go to the show me your master thread sticky and check the show me your completed rooms or the before and after threads for some ideas but it sounds like you already have some. I was tossing around having velvet panels or curtains like you but like the front like it is now.
cw5billwade is offline
post #363 of 408 Old 02-25-2014, 01:59 PM - Thread Starter
Quoted: 328 Post(s)
Liked: 184
As me all the questions about other subjects here so we do not have to hijack the sound proffing thread
post #364 of 408 Old 02-26-2014, 03:11 AM
Hi
I was concerned that my questions were in danger of a hijacking. I am very happy to open up a separate thread and invite people to contribute. I dont want to  detract from your home theatre project thread. SHould I open up a new thread - my only concern with this was to stop the high degree of 'chaff' that you sometimes get on these forums. Also I feel as if I am being somewhat overbearing in my questions and I guess you have your own ship to sail. Mind you I could also match you for gardens and John Deere's - although my garden tractor is like this!!! I steers from the rear..   I used to have a wonderful Wheel Horse but that died. I need the front cutter deck to get under the many plants my wife has planted around the edges of the lawn!! Let me know how to play this forum
Regards from the Spring Sunshine!
post #365 of 408 Old 02-26-2014, 04:43 PM
PaulFSemicolen's Avatar
Your build thread has been a pleasure to rewad through. I love ground up whole house builds! Thanks for all the detailed pics and information. You're situation is a goal of mine (5 acres open field, Nice house with projects, etc...) I'm a few years/decade away, so no rush ^_^. Keep the updates rolling!
PaulFSemicolen is offline
post #366 of 408 Old 02-26-2014, 05:39 PM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
Originally Posted by cw5billwade View Post
My build is above the garage I am not calling it a bonus room because I designed the house (along with builder and architect) for that area to be a theater. I lowered the roof of the workshop to accommodate the front of the theater to be 12” lower than the rear which is on level with the rest of the upstairs. In the first few pages of my thread you will see I used acoustical caulk in all of the cracks and holes between the garage and the theater. We also installed a second subfloor of ¾” Tung & Grove OSB using green glue and again every crack had acoustical caulk. The ceiling of the garage was spray foam and I had electrician put putty pads on the light fixtures and outlet for the openers. If there was living space down there I would have used R19 vise the spray foam and did a DW/GG/DW on the ceiling of that space with IB-1 clips.
caulk in garage
you can see the caulk here
Here you can see the green glue on the 3/4" T&G and also the caulk on orginal sub floor and second sub floor going in.
we also put OSB on the 2x12 used to lower the work shop ceiling
pile of T&G
spray foam
caulk on second sub floor
I did not take picture of putty pad in garage ceiling but here is one in the wall between theater and billiard room
I will have to see if I can find it. It may have been in the show me your completed room thread and the person did not have his build linked in his name
Did you use acoustic caulk on all the walls too, or just the ceiling joists?
Yamaha CX-A5100, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, 4 JBL 8340As, 4 JBL 8320s, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, (2) Crest Audio CM2208s, Yamaha XM-4080, (2) MiniDSP DDRC-88.
The Ellis Family Go Big or go Home HT
ellisr63 is offline
post #367 of 408 Old 02-27-2014, 06:39 AM - Thread Starter
Quoted: 328 Post(s)
Liked: 184
Thanks for checking in every time there was a delay in the build my builder said the theater is not ready anyway! I was out there every night and weekends so I was able to watch the house being built so to speak. There were times when a week would go buy and nothing would have been done on the house. I believe a lot of the delays were because he paid the subs as they went so if I were a sub and I had 75% of what I was going to get on a job 15 miles out or put my crew on 4 jobs in local I would do the same thing. Time is money and they have to spend time on the road! Same for the supervisor he had 15-20 homes in 4 subdivisions and mine 20 miles away. At least the builder let me build the theater while still under construction.
PaulFSemicolen likes this.
post #368 of 408 Old 02-27-2014, 09:01 AM - Thread Starter
Quoted: 328 Post(s)
Liked: 184
I also put two layers of 5/8” DW on billiard room side. For the outlet on the billiard side I used an adjustable outlet and caulked around the outlet on that side. Drywall guys make big holes using the zip tool around outlets that need attention. I also caulked the seams between the sheets of the billiard room drywall on the theater side.
You can just make out the caulk between the sheets of drywall at the bottom of this picture
I also caulked every wire intrusion
Bottom line: if there was a hole or seem or crack I put caulk in it! eek.gif Did I need go to this extreme I don’t know but results speak for them self. I have a totally sealed room and the weakest link is the door. I am really pleased with my sound proofing. biggrin.gif There is some debate going on over on the sound proofing sticky about the use of caulk check it out.
post #369 of 408 Old 04-28-2014, 02:18 PM - Thread Starter
Quoted: 328 Post(s)
Liked: 184
just Logan me now this is just a shameless bump because my thread fell way down on my subscribed list rolleyes.gif
post #370 of 408 Old 04-28-2014, 05:17 PM
jnnt29's Avatar
Quoted: 115 Post(s)
Liked: 131
Outstanding
My set up
Marantz SR-7008, Emotiva XPA-3
Samsung UBD-K8500 Ultra 4K Blu Ray Player
Klipsch RB-81II, RC-52II, Boston Acoustics Micro 120s
Klipsch SW-310, RPW-10, Samsung UN65JS8500FXZA
http://www.avsforum.com/avs-vb/showthread.php?t=1227096
jnnt29 is offline
post #371 of 408 Old 04-29-2014, 06:44 AM - Thread Starter
Quoted: 328 Post(s)
Liked: 184
Thanks JNNT29 I hope you were refering to the theater and not the shamless bump
Originally Posted by jnnt29 View Post
Outstanding
post #372 of 408 Old 05-24-2014, 12:01 AM
Rhino11's Avatar
Bump to keep it up for my 2nd story build
Rhino11 is offline
post #373 of 408 Old 05-27-2014, 08:56 AM - Thread Starter
Quoted: 328 Post(s)
Liked: 184
post #374 of 408 Old 05-27-2014, 08:57 AM - Thread Starter
Quoted: 328 Post(s)
Liked: 184
Thanks Rino11 I have been working outside a lot lately if you have any questions prior to your build thread post them here also send me your build thread link
post #375 of 408 Old 05-27-2014, 09:31 AM
Rhino11's Avatar
Will do. But just moving in and honey do's is going to slow my progress. But I have got some of my subs in already. smile.gif
Rhino11 is offline
post #376 of 408 Old 05-27-2014, 02:37 PM - Thread Starter
Quoted: 328 Post(s)
Liked: 184
thats my problem spent all 4 days of the long weekend doing the same washing cars, mowing grass on 5 acers, mulch for the play yard and so on.
post #377 of 408 Old 05-29-2014, 09:54 AM - Thread Starter
Quoted: 328 Post(s)
Liked: 184
I decided to consolidate all my HVAC into one post
I have a 2nd floor build with HVAC in attic but same principle. Here are two of my 6”supply lines and my 10” return line
Bring the return in the center I have a 12"x24" soffit in the rear I used as my muffler. I used 1 1/2" duct liner in the soffit.
here you see how I split the soffit with OSB to form the dead vent making a T from the return to run the dead vent in both directions
here is the dead vent lined with the duct liner I have a 6x16" return one each end.
finished product
with the supplies you bring them into the soffit
I had two supplies on each side the soffit in front had not been hung yet
front snaked around toward the back the center snaked from the rear
build mufflers
hang
stuff with pink stuff
hang OSB cut hole
repeat for drywall
granroth likes this.
post #378 of 408 Old 10-01-2014, 07:22 PM
DavidK442's Avatar
Quoted: 506 Post(s)
Liked: 341
Great post. Thanks.
(My response is as slow as your build. )
DavidK442 is online now
post #379 of 408 Old 10-01-2014, 09:31 PM
Dave Vaughn's Avatar
Quoted: 887 Post(s)
Liked: 1336
Time for an Atmos upgrade now?
mtbdudex likes this.
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
My Atmos Renovation Part 1 http://www.soundandvision.com/conten...odyssey-part-1
My Atmos Renovation Part 2 http://www.soundandvision.com/conten...odyssey-part-2
Dave Vaughn is offline
post #380 of 408 Old 10-02-2014, 07:30 AM - Thread Starter
Quoted: 328 Post(s)
Liked: 184
Dave too easy when the time comes which is the goodnees of being on second floor I can just run the wires through the attic space and hand speakes on the coffers. I will be looking at Volt 10s for my sourrounds and think they would make good ATMOS as well.
Dave Vaughn likes this.
post #381 of 408 Old 10-02-2014, 07:31 AM - Thread Starter
Quoted: 328 Post(s)
Liked: 184
Originally Posted by DavidK442 View Post
Great post. Thanks.
thanks for bringing me back from the dead I have been putting my 1099s from DIY sound group together keeping me busy
post #382 of 408 Old 10-02-2014, 11:35 AM
cuzed2's Avatar
Quoted: 187 Post(s)
Liked: 236
"CW"
Good to see you checking in!
By chance have you posted a build thread anywhere for the 1099's ?
(I've heard lots of enthusiasm for this design)
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #383 of 408 Old 10-02-2014, 12:56 PM - Thread Starter
Quoted: 328 Post(s)
Liked: 184
"CW"
in my Signature
post #384 of 408 Old 10-02-2014, 01:13 PM
DallasMike's Avatar
Liked: 0
looks amazing! great job
DallasMike is offline
post #385 of 408 Old 10-02-2014, 03:17 PM - Thread Starter
Quoted: 328 Post(s)
Liked: 184
post #386 of 408 Old 11-25-2014, 05:22 PM
K2sno311's Avatar
Bill, can't wait to see your finished 1099's and hear your impressions. Great build!!
Also, I do like your idea of 2.0:1 screen ratio... when we can afford to upgrade, it will hopefully be a projector of this setup
sub'd
cw5billwade likes this.
K2sno311 is offline
post #387 of 408 Old 11-25-2014, 06:21 PM - Thread Starter
Quoted: 328 Post(s)
Liked: 184
Been really busy lately running to Baltimore to move my mother into independent living and getting ready to sell her home. Next week she will be getting surgery so another trip up north even minor stuff is tuff and go when you are 90
post #388 of 408 Old 11-25-2014, 06:22 PM - Thread Starter
Quoted: 328 Post(s)
Liked: 184
post #389 of 408 Old 11-25-2014, 06:29 PM - Thread Starter
Quoted: 328 Post(s)
Liked: 184
sub'd
There is no down side to 2.0:1 if you have the space I have 19' wide and 10' ceilings up front so it was a no brainer
post #390 of 408 Old 12-28-2014, 06:00 PM
granroth's Avatar
Quoted: 664 Post(s)
Liked: 445
A few questions for you, Bill.
Did you end up putting duct liner in your duct boot/muffler like you did for the dead vent? Or did it remain just unadorned OSB?
Why did you put what looks like support boards in the corners of the duct boot? Why not just a plain box made of OSB?
Is the white gunk acoustic caulk or duct mastic?
granroth is offline
