/// Reference 2: Blu-Ray Demo Disc (BD9s & BD50) \\\ - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 49Likes
post #811 of 941 Old 10-19-2014, 11:27 AM
Gurba's Avatar
Quoted: 399 Post(s)
Liked: 193
Originally Posted by arasef View Post
.part31 in the torrent is only a partial file. The torrent contents reflect this. Aside from using a usenet group, what are my options in getting this file?
Its Complete. Just remove the !ut and it's good.
Gurba is offline
post #812 of 941 Old 10-20-2014, 12:18 PM
realife3's Avatar
Liked: 30
Can someone please send me the link to the file? Greatly appreciated.
realife3 is offline
post #813 of 941 Old 10-20-2014, 02:15 PM
Gurba's Avatar
Quoted: 399 Post(s)
Liked: 193
Read the bottom of post #3 in this thread.
Gurba is offline
post #814 of 941 Old 10-20-2014, 04:56 PM
arasef's Avatar
Liked: 1
Worked perfectly. Thank you!!!!
I love these demo discs. Great job all around.
Gurba likes this.
arasef is offline
post #815 of 941 Old 10-21-2014, 09:24 AM
realife3's Avatar
Liked: 30
Wink
Thanks. I did follow that link, i was not opening it properly. Finally got it right.
Gurba likes this.
realife3 is offline
post #816 of 941 Old 11-02-2014, 11:00 AM
cornell's Avatar
Can someone seed the Reference Music disc please?
cornell is offline
post #817 of 941 Old 11-02-2014, 07:54 PM
realife3's Avatar
Liked: 30
Originally Posted by cornell View Post
can someone seed the reference music disc please?
done
realife3 is offline
post #818 of 941 Old 11-04-2014, 11:56 AM
martinq's Avatar
Quoted: 23 Post(s)
I'm looking to finish the Bass disc ... I'm at 16% and haven't made much progress in the last day or two.
martinq is offline
post #819 of 941 Old 12-08-2014, 12:54 PM
easycruise's Avatar
Quoted: 100 Post(s)
Liked: 30
I can't download the multiavchd program from the link in Post #1 . Seems that the file is gone from all the mirrors. Any help? I have having all sorts of trouble trying to make these disks. I have a bunch of single layer DVD-R that have 4.7MB capacity, can I burn just a few movie scenes on those or do I need to get the DL disks? Thanks!
easycruise is offline
post #820 of 941 Old 12-08-2014, 01:15 PM - Thread Starter
superleo's Avatar
Quoted: 77 Post(s)
Liked: 302
The individual segments are designed to fit into a DL DVD, so to answer your question, no the file as it was created will not fit onto a regular DVD. If you use MultiAVCHD you can re-author the disc in any way you want to fit a regular DVD.
The next best thing is probably to copy the m2ts files from the STREAM folder to a USB drive or external drive. Most players or TVs have a USB connector that would play m2ts files.
RPCRT-TV Overscan Reduction
Reference Blu-Ray Demo Disc
superleo is offline
post #821 of 941 Old 12-08-2014, 01:56 PM
LastButNotLeast's Avatar
Quoted: 1587 Post(s)
Liked: 1197
http://multiavchd.deanbg.com/
http://www.digital-digest.com/software/multiAVCHD.html
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
For most of the time, the here and now is neither now nor here. Graham Swift
LastButNotLeast is offline
post #822 of 941 Old 12-16-2014, 07:12 AM
easycruise's Avatar
Quoted: 100 Post(s)
Liked: 30
I bought the DL DVD disks, but the DVD+R version. Did I buy the wrong kind? No luck so far, as I've made a couple of coasters. I'm also having trouble with the MultiAVCHD program, it bombs out a lot at the beginning when I am trying to load files to convert. My .m2ts files have hundreds of megabytes in them so I think the torrent download went OK. Any ideas? Thanks!
post #823 of 941 Old 12-16-2014, 07:30 AM - Thread Starter
superleo's Avatar
Quoted: 77 Post(s)
Liked: 302
As long as your burner supports the format, either -DVD or +DVD, and of course they need to be doubled layered, no difference.
have you tried playing the discs through your computer? You can use any of the software available; VCL player, TMT or Power DVD. If you are able to play the discs, there should be no reason why they shouldn't play once you burn them to disc.
There should be no need for MultiAVCHD if you are burning to DVD DL. MultiAVCHD is used only if you are trying to play the disc(s) from a USB or external drive.
Hope this helps, let us know, if you have any other questions post them.
superleo is offline
post #824 of 941 Old 12-16-2014, 08:11 AM
easycruise's Avatar
Quoted: 100 Post(s)
Liked: 30
No, the discs won't play in my computer with either Windows Media Player or the HP DVDSmart Player.
You said...""There should be no need for MultiAVCHD if you are burning to DVD DL. MultiAVCHD is used only if you are trying to play the disc(s) from a USB or external drive.""
I only have Sony and Panasonic Blu-ray players, so I thought I had to convert to AVCHD format to play in these players? Thanks.
post #825 of 941 Old 12-16-2014, 08:41 AM - Thread Starter
superleo's Avatar
Quoted: 77 Post(s)
Liked: 302
I'm referring the downloaded files (as disc structure) when I say play them from your computer. I don't think windows media player will play the downloaded disc structure and I'm not familiar with HP DVDSmart player. The main factor here is a software player that is capable to play BDs and that also has the necessary codecs for audio and video.
I would download TMT, free trial, and open the BDMV folder, it should play the segment disc. Once you are sure it plays then you could go head and burn it to disc.
Although higher success has been reported by using MultiAVCHD with Panys and Sonys players there are no guaranties.
I know that the disc with the highest success on playing BD9s has been the "Best of BD Disc" demo. You might want to try that one first. That disc has already been run through MultiAVCHD so no need to do any extra steps.
superleo is offline
post #826 of 941 Old 12-16-2014, 11:10 AM
easycruise's Avatar
Quoted: 100 Post(s)
Liked: 30
OK, I just downloaded the "Best of BD Disc". I don't know what you mean by "play them from your computer". I right click on any of the .m2ts file names in the Stream folder and it wants a program to open up that file with. Usually Windows Media Player or some other player.
I did download that, but TMT, Arcsoft Total Media Theatre, won't let me open any of the folders. When I try to open the individual .m2ts file, TMT says "unsupported file type".
Any ideas?
post #827 of 941 Old 12-16-2014, 11:24 AM - Thread Starter
superleo's Avatar
Quoted: 77 Post(s)
Liked: 302
Any ideas?
Once you open TMT use the "open>disc folder". Navigate to the folder where the BDMV folder is. Then just click "Enter". TMT will play the folder just as it was a disc. You should be able to use the menus and have a physical like experience playing it this way.
I might be mistaken but I don't think Windows media player will play the individual m2ts files correctly. Windows is missing the lossless codecs for audio.
superleo is offline
post #828 of 941 Old 12-16-2014, 11:40 AM
easycruise's Avatar
Quoted: 100 Post(s)
Liked: 30
It's not working. When I highlight the BDMV folder, the "OK" button is grayed out. Same thing happens when I highlight the Stream folder. Maybe the torrent download wasn't successful?
post #829 of 941 Old 12-16-2014, 11:53 AM
Liked: 1197
Make sure TMT preferences screen is set to play all file types (for now, anyway; you may not want to keep it that way if you keep using the program). When you double-click on an m2ts file, it should open TMT and play.
post #830 of 941 Old 12-21-2014, 06:49 AM
easycruise's Avatar
Quoted: 100 Post(s)
Liked: 30
I enabled all the file associations and I still get a TMT error message "unsupported file type".
post #831 of 941 Old 12-21-2014, 08:11 AM
Liked: 1197
If you can't play ANY m2ts file, then there's something wrong with your copy of TMT or your system.
If you just can't play any of these (do you get a preview in finder [sorry, using my mac - explorer] or the TMT logo?), then there's something wrong with the download.
post #832 of 941 Old 12-21-2014, 11:02 AM
Liked: 0
hello, no seed ?
bluray-collec is offline
post #833 of 941 Old 12-21-2014, 11:18 AM
Ph8te's Avatar
Quoted: 4585 Post(s)
Liked: 4043
Originally Posted by bluray-collec View Post
hello, no seed ?
Hello, you need to be more specific in what you need a seed of. One section? The entire disc? Help us help you. This disc is quite old so most don't constantly seed all the time anymore (if they have it available).
Sent from an system/360
Ph8te is offline
post #834 of 941 Old 12-21-2014, 11:37 AM
Liked: 0
if possible, all section but separately thanks
post #835 of 941 Old 12-21-2014, 01:13 PM
easycruise's Avatar
Quoted: 100 Post(s)
Liked: 30
How do I tell that I successfully downloaded the .m2ts files successfully in the torrent download? It took a while for it to finish the "checking files", operation, but then did nothing after that, so I thought the download was finished. What is seeding? If my .m2ts files are hundreds of megabytes in size, does that mean the download was successful? I don't know anything about torrents. Thanks again.
post #836 of 941 Old 12-21-2014, 01:43 PM
Liked: 1197
The download probably did finish. Seeding is when you're providing parts of the file to others who are downloading, as you were. It is considered polite to continue seeding after you've downloaded as a courtesy to others. While the torrent program is running, you won't be able to do anything else with those files, so maybe that was your problem. You will need to quit the torrent program. To be on the safe side, I copy the files to another disc, and work with them there.
Do you have a regular blu-ray disc around? You should be able to play the m2ts files in that stream folder. If you can, then we need to continue to figure out why your downloaded files don't work. If you can't, we need to figure that out first.
Michael
post #837 of 941 Old 12-21-2014, 08:23 PM
Slingblayde's Avatar
Quoted: 14 Post(s)
Liked: 64
Have there been any new Demo discs created lately? I have been MIA from the forums since the start of motorcycle season and now that the weather is caca again I was hoping to d/l some new AVS member awesomeness.
edit: I found one called Reelwood 2014, gonna start d/l that immediately.
Optoma HD33, Onkyo TX-NR818 in a 9.2 setup, Emotiva XPA-5 G2, UPA-700 for eventual 11.2 setup
Oppo BDP-103, , Middle Atlantic Slim 5-37-26
F - Klipsch RB-61 II, C - Klipsch RC-62 II, Side/Rear Surrounds - Klipsch RS-42's, Heights - Klipsch RS-41's
Dual - PSA XV15's, Fractal Designs Node 605 HTPC
Slingblayde is offline
post #838 of 941 Old 12-22-2014, 12:00 AM - Thread Starter
superleo's Avatar
Quoted: 77 Post(s)
Liked: 302
AFAIK here are the demo discs on AVSForum:
If you go through the thread you'll come across other demo discs on other forums.
superleo is offline
post #839 of 941 Old 12-22-2014, 12:10 AM
Quoted: 14 Post(s)
Liked: 64
Thanks Superleo, I found the 2 Reelwood discs by ready your posts
I have all of your discs, Scuba's, Jindraks and the Best Of discs, they are all fantastic. but Ive been so out of touch lately I had no idea that he had made these 2 discs. Looking forward to finishing downloading them and taking them for a test run later today.
post #840 of 941 Old 12-24-2014, 06:09 AM
easycruise's Avatar
Quoted: 100 Post(s)
Liked: 30
It was days later, so with a computer restart, the torrent program should have stopped? And how do you know the torrent program is running?
Michael
My 2 desktop computers can't read Blu-ray movies, I can't get to the file structure. One computer just keeps trying to read the disc and the other one automatically ejects the disc as soon as I click on the drive.
audio quality , Blu Ray Movies , video quality
