/// Reference 2: Blu-Ray Demo Disc (BD9s & BD50) \\\ - Page 30 - AVS Forum | Home Theater Discussions And Reviews
 41Likes
post #871 of 886 Old 07-24-2015, 03:28 PM
J_P_A's Avatar
Quoted: 535 Post(s)
Liked: 418
I need seeders if possible! Thanks guys!
I'm excited about getting this demo disc, and I appreciate everyone that has put effort into it!
The Plains Theater Has Begun
J_P_A is offline
post #872 of 886 Old 07-25-2015, 08:56 AM
J_P_A's Avatar
Quoted: 535 Post(s)
Liked: 418
Thanks, everyone! I'll seed as long as I can.
Looking forward to giving this a spin!
J_P_A is offline
post #873 of 886 Old 08-25-2015, 09:15 PM
IanR's Avatar
Quoted: 93 Post(s)
Liked: 68
Tip of the hat and tks to those who built this great resource. I don't have a single one of the titles nor do I have the experience to know what's good/bad so it was great to reap the benefit of other people's advice/recommendations.
I don't use torrent or rar at all but had enough Windows skill to stumble through the download process. I do have a pretty good 64bit video editor (PowerDirector) capable of editing/assembling HD video but I found it interesting that every time I dropped one of the files into it, it said it was an invalid type and crashed .. maybe there was some imbedded HDCP code but I would have expected a warning not a crash. However, I was able to just point my burner to the Ref2 BD-R directory and the burn went fine as did my initial testing of the disks.
For what it's worth, just thought I'd mention that I have a Blu-ray burner but only 25GB disks so I ended up splitting the content onto 2 disks. I successfully used the "get all files" torrent to get the files but I couldn't figure out where the basic disk structure was. So, I used the BD9 to BD50 torrent to get the structure and then copied over the files into the Stream part of the structure. If you copy over files 2 to 34, you'll get the entire Surround, Bass, and Visual sections and it will fit fine on a 25GB disk. Then if you replace 2 thru 34 with 35 thru 69, you can create the second disk with Animation, Music and Superheroes. Leave files 0000 and 0001 the same for both disks. The full disk menu will appear for both .. you'll just have to remember to just use the appropriate 3 sections (first 3 or last 3) for each disk. I tried selecting a non-existent file and my player just locked up and I had to power it off/on to get it back.
Tks again
superleo and LastButNotLeast like this.
Ian
My finished "Media Room"
IanR is offline
post #874 of 886 Old 10-08-2015, 04:09 PM
Quoted: 311 Post(s)
Liked: 197
could someone seed bass version???
yamvmax1 is offline
post #875 of 886 Old 10-14-2015, 07:00 PM
SherazNJ's Avatar
Quoted: 951 Post(s)
Liked: 113
Hi guys,
I'm having an issue with using MultiAVCHD. Some of the demos I downloaded work fine with it but some don't. When I drag and drop AVCHD folder on the main screen of MultiAVCHD, it makes main screen go away and another screen with gray background comes up and stays just like that no matter how long I leave it open. Has anyone face this issue? I'm using MultiAVCHD on windows 8.
Also, when I launch MultiAVCHD, it opos an update version available message and and asks if I want to update. If I press Yes, it fails to do so (not that big of a deal though but may be the update might fix the issue).
SherazNJ is offline
post #876 of 886 Old 10-15-2015, 07:24 PM - Thread Starter
superleo's Avatar
Quoted: 55 Post(s)
Liked: 257
Originally Posted by SherazNJ View Post
Hi guys,
I'm having an issue with using MultiAVCHD...
What exactly are you trying to do with MultiAVCHD?
RPCRT-TV Overscan Reduction
Reference Blu-Ray Demo Disc
superleo is offline
post #877 of 886 Old 10-15-2015, 09:26 PM
LastButNotLeast's Avatar
Quoted: 972 Post(s)
Liked: 680
You will probably find what you need here:
http://multiforum.deanbg.com/
Keep in mind:
"Latest supported version: 4.1.771 (version 4.1 build 771) as of July 4th, 2012"
so Win 8 might be problematic.
Michael
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
post #878 of 886 Old 10-15-2015, 09:58 PM
SherazNJ's Avatar
Quoted: 951 Post(s)
Liked: 113
Use it to make the demo compatible to be played with PS3 using USB drive.
SherazNJ is offline
post #879 of 886 Old 11-05-2015, 06:16 AM
Liked: 0
I would like the Bass disc aswell, but there are not seeders on this.
It have been trying to download for 3 days now.
Will someone please seed the Bass version.
ldplusse is offline
post #880 of 886 Old 11-06-2015, 04:44 AM
J_P_A's Avatar
Quoted: 535 Post(s)
Liked: 418
Sadly, I have a data cap now, and the disc is larger than my cap.
I'll give you a bump, tho! Hopefully someone can see for a few days.
J_P_A is offline
post #881 of 886 Old 11-07-2015, 05:02 AM
drpete12's Avatar
Quoted: 100 Post(s)
Liked: 39
can someone seed BASS and Animation. When I get them done I can seed them for a week or two...thx
drpete12 is offline
post #882 of 886 Old 11-08-2015, 12:28 PM
drpete12's Avatar
Quoted: 100 Post(s)
Liked: 39
trying to bump this if I can. Still waiting on BASS and Animation. If someone can get me done I will seed for a few weeks to keep it going.
drpete12 is offline
post #883 of 886 Old 11-14-2015, 07:48 AM
dengland's Avatar
Quoted: 14 Post(s)
Last year I rebuilt my computer and installed an SSD. I manually moved all of my downloads (Reference 2's and 5 of the RAR's) to a new location not on the SSD. I have never figured out how to get them up and seeding again using Vuze. I don't seem to have the .torrent files. I tried downloading the .torrent file, but cannot seem to get it associated with the partxx files.
If I add in "queued" mode, it starts downloading again. If I add in "Seeding" it says it cannot open the torrent.
I would like to contribute again, but need some help.
dengland is offline
post #884 of 886 Old 11-14-2015, 09:45 AM
dengland's Avatar
Quoted: 14 Post(s)
Looks like it was the file I was using. Was trying with the Bass torrent and not having luck. All the others added just fine.
dengland is offline
post #885 of 886 Old 11-14-2015, 10:10 AM
Quoted: 972 Post(s)
Liked: 680
Thank you for continuing to seed.
Michael
post #886 of 886 Old 12-05-2015, 07:18 AM
Liked: 1
I will continue to seed the combined and the individual compilations. Gotta pay it forward...
superleo likes this.
uf2k is offline
audio quality , Blu Ray Movies , video quality
