hiding my projector? (Pics) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 04-22-2013, 09:26 PM - Thread Starter
madskaman's Avatar
I'm not even sure this is the right section for this, but I think it's close. I've been looking online for solutions to hide my projector that don't include me spending $1500. I was curious if anyone has made their own motorized tray system to lower and raise their projector? If so, some pictures or advice on the subject would be very helpful. Even a point in the right direction would be nice; as I'm pretty much starting from scratch.
madskaman is offline
post #2 of 18 Old 04-23-2013, 05:22 AM
Quoted: 3258 Post(s)
Liked: 2743
You can buy the motorized linear actuators at places like:
http://www.firgelliauto.com/
post #3 of 18 Old 04-23-2013, 04:09 PM
weaselfest's Avatar
Quoted: 46 Post(s)
Liked: 41
AVS Forum search is your friend.
Check out this thread.
http://www.avsforum.com/t/1456557/diy-remote-controlled-projector-lift
underachiever extraordinaire
weaselfest is offline
post #4 of 18 Old 04-24-2013, 08:22 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
If you want it hidden so no one sees it at your place but it still works every night, send it to my place! eek.gif
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #5 of 18 Old 04-25-2013, 08:55 AM - Thread Starter
madskaman's Avatar
I'm looking to have it completely hidden in the ceiling. I'm going to build a motorized drawer that will drop down when the screen does. I have some basic plans now and will keep updating with pictures when I start, hopefully on Friday. I found a 12volt motor that I can use with a cable and pulley.
post #6 of 18 Old 04-26-2013, 08:51 PM - Thread Starter
madskaman's Avatar
I've started on the box today. It's basically going to be a drawer that will drop from the ceiling. The major problem I'm fighting is space. I've only got 11 inches up to work with. When the unit is closed it will be flush, finished with the sheet rock on the bottom. I've got telescoping drawer slides and the electric motor on the way. Here is what I've got so far.
post #7 of 18 Old 05-04-2013, 12:03 AM - Thread Starter
madskaman's Avatar
I got the slides in the mail and installed them.
post #8 of 18 Old 05-04-2013, 12:32 AM
warrenP's Avatar
Liked: 60
Looking good. One thought to keep in mind is that you don't time your power off trigger to retract the projector. It should have some cool down time before going back up into the box.
Every man dies. Not every man really lives.
warrenP is offline
post #9 of 18 Old 05-04-2013, 05:53 AM
Liked: 2743
looking good, please post pics of the motor part of the this project when you get there.
post #10 of 18 Old 05-05-2013, 08:06 PM
NYGIANTSFAN23's Avatar
Liked: 39
Interesting concept. Looking forward to seeing more.
NYGIANTSFAN23 is offline
post #11 of 18 Old 06-10-2013, 09:50 AM - Thread Starter
madskaman's Avatar
I'm still working on this project. I found a couple motors to try to power this unit. I burnt one out and broke a tooth in the other. I'm going down a slightly different path now. I'm going to use an actuator. I'll post some pictures when I get it setup.
post #12 of 18 Old 07-12-2013, 01:58 PM
cbehr1's Avatar
Any updates, looking to do the same thing!
cbehr1 is offline
post #13 of 18 Old 05-22-2014, 06:27 AM
aj587166's Avatar
Was this project ever finished? really keen to start my own drop mount, but would love to know how this one turned out? Thanks for sharing so much so far though!
aj587166 is offline
post #14 of 18 Old 05-24-2014, 07:17 AM
dhendriksen's Avatar
Quoted: 25 Post(s)
Liked: 31
Mine isn't a drop mount, but it is completely hidden within the soffit.
Sent from my Droid MAXX via Tapatalk.
dhendriksen is offline
post #15 of 18 Old 05-24-2014, 09:35 AM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 938
What are you going to do when you change out projectors? Looks like major surgery! I was thinking the same, but gave up due to very same issue.........
doublewing11 is offline
post #16 of 18 Old 05-24-2014, 10:21 AM
Liked: 2743
velcro that front black panel
post #17 of 18 Old 05-24-2014, 12:48 PM
Quoted: 25 Post(s)
Liked: 31
^exactly. The panel is attached via Velcro. It pulls off real easy and the projector is just sitting there. I routed the panel out of MDF and wrapped it with speaker grill cloth. I'd argue that I can have my projector out and on the bench quicker than you can get it off your mount =)
Here's the back side of the panel.
As you can see, the intake and exhaust vents flow freely. It works awesome.
Here's a picture right after I cut the hole.
post #18 of 18 Old 05-24-2014, 12:51 PM
Quoted: 25 Post(s)
Liked: 31
I actually had originally planned to essentially build a drawer so I could slide it out, but haven't done that yet and probably won't because it's pretty rare that I need to access it.
