Show me your rack.....but from the back ! - AVS Forum | Home Theater Discussions And Reviews
Old 04-23-2013, 02:09 PM - Thread Starter
vanrags's Avatar
Can y'all share some pictures of how cable connections are managed on a A/V rack ?. I started the installation of my equipment, but the wires soon became a mess. I want to know a better way of clubbing the cables together. I am using a Middle Atlantic A/V rack.
vanrags is offline
Old 04-23-2013, 03:17 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
MA lacing bars are your friend...
http://www.cableorganizer.com/articles/cable-management.htm
An image search for them also gives a bunch of hits in the "Show me" thread here and similar threads over at RemoteCentral.
jautor is offline
Old 04-23-2013, 09:02 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
Old 04-23-2013, 09:15 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Power cables run vertically all on the right, LV on the left. 1-2 lacer bars per component. Velcro OneWrap easier to change and adjust than zip ties. I used 3 pairs of vertical rack rails.
Speaker cables (distributed audio system) are patched at rail mount terminal blocks.
No sharp bends for Ethernet cables.
This is a repurposed very deep server rack which will be replaced with a 20-24" deep AV rack. The terminal blocks will be replaced with panel mount Neutrik SpeakOn connectors for quick disconnection in the event the furnace needs replacement or significant service. I've used 0", 2", and 4" offset L-shaped lacer bars.
This old used server rack has been great practice for the next one.
Neurorad is offline
Old 04-24-2013, 11:51 AM - Thread Starter
vanrags's Avatar
Thanks a lot !!!!!. This helps a lot !.
vanrags is offline
Old 04-24-2013, 09:52 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
View from above.
Neurorad is offline
Old 04-25-2013, 01:06 AM
TMcG's Avatar
Quoted: 1072 Post(s)
Liked: 870
Not finished, but a couple of pictures of my last rack while I was in the wiring process. Power and signal lines were kept separate, fyi.
TMcG is offline
Old 04-27-2013, 08:57 AM
landshark1's Avatar
Quoted: 18 Post(s)
Liked: 62
landshark1 is offline
