IR Remote Lights - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-27-2013, 11:06 AM - Thread Starter
mijotter's Avatar
Liked: 59
Does anyone know of any LED puck lights or perhaps strips that work off of an IR remote? Links would also be helpful.
mijotter is offline
post #2 of 6 Old 05-06-2013, 10:59 PM - Thread Starter
mijotter's Avatar
Liked: 59
Anyone?
I'm looking for a light that can be hardwired in to a wall since I have no room for soffit at the bottom of the wall for walking lights.
mijotter is offline
post #3 of 6 Old 05-07-2013, 08:54 AM
Swervepf's Avatar
Quoted: 38 Post(s)
Liked: 31
http://www.ebay.com/sch/i.html?_nkw=led+light+strip+remote&_sacat=0&_odkw=led+light+strips&_osacat=0&_from=R40
something like this?
I need to figure out if I do a crown molding in the room, mounted an inch or so down from the ceiling with these in there or not.
mijotter likes this.
Swervepf is offline
post #4 of 6 Old 05-07-2013, 10:59 PM - Thread Starter
mijotter's Avatar
Liked: 59
Does anyone know if these can be hard wired? I want the cords and everything to be out of sight and not just simply plugged in to a wall outlet.
http://www.amazon.com/Waterproof-Strips-Remote-Controller-Power/dp/B008YRZ9YS
mijotter is offline
post #5 of 6 Old 05-09-2013, 11:14 PM - Thread Starter
mijotter's Avatar
Liked: 59
Anyone?
mijotter is offline
post #6 of 6 Old 05-10-2013, 07:59 AM
stockmonkey2000's Avatar
Liked: 30
I bought a little remote control plug in module at Home Depot at Christmas time that was meant to plug a Christmas tree into. I have a couple spot lights behind my acoustically transparent screen that light up my center speaker. I did not have extra space on my Grafik Eye to control this so I just did it with this simple $9 solution at Home Depot.
It looks something like this.
http://1000bulbs.com/product/59658/CMS-ODHOLREMOTEGRN.html
stockmonkey2000 is offline
