Door jamb issues - AVS Forum | Home Theater Discussions And Reviews
Old 04-28-2013, 09:54 AM - Thread Starter
jefftr's Avatar
Quoted: 20 Post(s)
Liked: 26
I thought I'd post this in the general area and see if anyone else has run into this issue. When my GC replaced a door into the theater a large gap was left between the doorjamb and the drywall. (Even though my directions were to put the drywall up to the edge....) This has left a gap in some areas large enough to stick my hand into - and I don't have small hands!
I have some non-expanding foam but this seems like a huge space for that. The problem is mostly on the left side. The right side has a very small gap.
Should I just stuff some insulation in there and then the foam? Fill with something else?
Any help/suggestions would be greatly appreciated!!
jefftr is offline
Old 04-28-2013, 01:11 PM
Brad Horstkotte's Avatar
Liked: 68
I would probably just glue some drywall shims in the larger gaps and then silicone sealant or expanding foam over / into smaller gaps - then door trim over it.
Brad Horstkotte is offline
Old 04-29-2013, 02:07 PM - Thread Starter
jefftr's Avatar
Quoted: 20 Post(s)
Liked: 26
Except the space runs almost the length of the left side - that seems like a lot of shims.
jefftr is offline
Old 04-29-2013, 11:31 PM
Liked: 68
I meant cut a strip of drywall the length of the door, slide it in sideways, glue it in place - doesn't need to be pretty, just fill the space, trim covers it all.
