MA Rack question - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 35 Old 05-07-2013, 02:02 PM
jautor's Avatar
Quoted: 1225 Post(s)
Liked: 786
Originally Posted by Chad711 View Post
Did you mount yours in the front or back of the rack? I should probably just go ahead and bite the bullet and get it. This HT project is costing me more and more every day!!!!!
Regardless of the model, all of those should be mounted to the front of the rack, as the outlets are on the rear of the unit.
The light bars are obviously for the front of the rack - but they also have USB-power ports on the back for a gooseneck LED worklamp (which comes in very handy).
jautor is offline
post #32 of 35 Old 05-07-2013, 02:47 PM
Brad Horstkotte's Avatar
Liked: 68
Originally Posted by jautor View Post
"Worth" is a strong word here. It's just a power strip, but in a very nice form factor. You can get a less-nice solution for less money.
I went the other direction - since I wanted a light for the rack, and needed a power strip, I used the MA light / strip. I went with the brushed decorator model, but this one is cheaper:
http://www.customavrack.com/products/946-middle-atlantic-pdlt-815rv-rn-lighting-and-power-distributor.aspx
There are similar alternatives - brands usually associated with music / PA racks vs. HT - that can be had for even less, like Furman and Gemini - I have a Gemini like this one in my music rack, has been working like a champ for years, picked it up used on eBay:
http://www.ebay.com/itm/GEMINI-PL-90-POWER-CONDITIONER-/151039659760?pt=US_Power_Conditioners&hash=item232aaa4ef0
Brad Horstkotte is offline
post #33 of 35 Old 05-11-2013, 10:15 AM - Thread Starter
Chad711's Avatar
I got my MA rack yesterday. Quick question. Does the PD-915 power strip just connect to the rack using the screws on the front or do I need a shelf for it? Wasn't any instructions with it.
Chad711 is offline
post #34 of 35 Old 05-11-2013, 10:51 AM
LeBon's Avatar
Quoted: 184 Post(s)
Liked: 87
The PD-915 mounts to the rack rails (front or rear) with regular rack screws. It takes up one rack unit (RU) of space.
LeBon is offline
post #35 of 35 Old 05-11-2013, 11:04 AM - Thread Starter
Chad711's Avatar
Thanks. Just wasn't sure because of the weight. Didn't know if 4 screws in the front would hold it up.
Chad711 is offline
