MA Rack question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 35 Old 04-28-2013, 07:51 PM - Thread Starter
Chad711's Avatar
I've been looking at these racks online. Are the prices I'm seeing for the rack itself, without shelves, etc?
Chad711 is offline
post #2 of 35 Old 04-28-2013, 08:12 PM
homeav's Avatar
Unless it's part of some kit (that specifically includes some shelving) - then yes.
The Slim5 racks are pretty popular for HT needs.
homeav is offline
post #3 of 35 Old 04-28-2013, 08:13 PM
NGiovas's Avatar
Liked: 43
Typically, yes it is just the rack itself.  That is one of the issues with racks - the price can really jump when you add all of the accessories (power strips, shelves. etc.).
NGiovas is offline
post #4 of 35 Old 04-28-2013, 08:45 PM - Thread Starter
Chad711's Avatar
Thanks. Yeah little to speedy for some painted metal. They must make a fortune off the racks.
Chad711 is offline
post #5 of 35 Old 04-29-2013, 03:34 PM
Spec4's Avatar
Liked: 24
Watch your local Craigslist for used server racks. I picked up a 42U 4-post rack with sides, doors and a top w/ dual fans for $100. I check CL whenever I can and recently scored a 20amp 24 outlet power strip for $80. The deals are out there just have to be patient and willing to buy used.
Spec4 is offline
post #6 of 35 Old 04-29-2013, 03:54 PM - Thread Starter
Chad711's Avatar
Thanks I did look and I found a few but when I read the details and such I just don't understand what they are selling really and if it fits my needs. I just need to be more educated on what items are which and what I need.
I'm in Dallas Fort Worth if you see any deals!
Chad711 is offline
post #7 of 35 Old 04-29-2013, 03:57 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
I've been watching craigslist the last couple years, and I've seen several AV racks (as well as many server racks). SearchTempest allows you to search multiple CLs. Also, you can set up eBay searches by distance (within X miles), with email notifications.
You can always buy vertical rack rail, and DIY a cabinet. If you don't want fancy, forego custom face plates, and try to use rack ears when possible.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #8 of 35 Old 04-29-2013, 04:35 PM
Spec4's Avatar
Liked: 24
^ This is probably the cheapest route and can look good when done as an in-wall unit.
This is a 4-post in your area that would work if you have the space.
Here's another
A swing out design
A white one with shelves and power strips included
A 2-post with CAT 6 patch panels and cable management.
There are a ton of these in your area you should have no problem grabbing one for cheap. IMO I would not pay over $200 for a 4-post rack, unless it came with a lot of extras like shelves, outlet strips, etc. Unfortunately I did not see much in the way of accessories like shelves and panels, but they come around eventually.
Spec4 is offline
post #9 of 35 Old 04-29-2013, 05:30 PM - Thread Starter
Chad711's Avatar
Thanks for looking. Yeah most that I found, like you did as well are a little taller then I'd like to go and didn't seem to have much racks. I may just wing it until I find the right deal. I pretty much have everything else or I will have it in the next two weeks and want to get started. Just hate thinking about putting something like this off. Wanted to do it before paint ad carpet go in..
The way my setup is gonna work is I have a closet on the other side of my theater wall and the wife has given me the go ahead to use this as the audio/video storage. It works perfect because if I need to access to the back side I just open the closet door. I just need cut out the drywall for my rack. Which as I said I'd like to do it before the carpet and paint.
Chad711 is offline
post #10 of 35 Old 04-29-2013, 05:58 PM
kelton325's Avatar
I debated between total DIY and landed on a solution with rack rails and shelving from MA, with custom faceplates which really blew up the cost. You could do it alot cheaper without the faceplates.
Check out the link to my build thread for details and pics starting with post 95
http://www.avsforum.com/t/1361916/the-i-want-it-done-build-thread/90
Finished product:
kelton325 is offline
post #11 of 35 Old 04-29-2013, 06:50 PM - Thread Starter
Chad711's Avatar
Kelton it looks like you have what I want. When are you putting it on Craigslist? Lol kidding. Seriously though I like what you did and it's what I had in mind with my setup. With the extra panels you got what did that all come out to in cost? I have the same setup basically....receiver, bluray, Xbox, ps3, pc I built as well with Apple TV. I will be putting that in the closet space in the back though.
Do these racks screw into the studs on the left and right?
Chad711 is offline
post #12 of 35 Old 04-29-2013, 11:20 PM
kelton325's Avatar
About $850. The rack rails are screwed directly into a square wooden frame of 2x6's I built and attached to studs in the wall. Everything else attaches to the 2 rack rails.
post #13 of 35 Old 04-30-2013, 04:33 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Various search terms I used included:
"Middle Atlantic"
Lowell rack
AV rack
Audio rack
19" rack
Rackmount
AV enclosure
AV cabinet
Server rack
Neurorad is offline
post #14 of 35 Old 04-30-2013, 07:01 AM
Quoted: 3265 Post(s)
Liked: 2751
I'm using this one for a project. It will be built into the wall near the rear of the theater. Back opens or can be removed.
$499 local pickup $599 shipped. Additional shelves for under $10 each. We also considered MA but by the time you buy all the custom shelves the cost approached $2000.
HTdepot.com
post #15 of 35 Old 04-30-2013, 09:52 AM - Thread Starter
Chad711's Avatar
Kelton how much of that $850 was the custom cut outs? That is a lot more then I want to spend so may not be a option for me.
BIGmouthinDC where is that pic from? That smaller rack on the left side I may be interested in. I'm looking for one around 3'.
I think the site you posted should be HTdepot.com right? I will look on there.
Chad711 is offline
post #16 of 35 Old 05-01-2013, 06:32 PM
kelton325's Avatar
The custom face plates versus just standard shelves is about $325 more. So you could do a similar rack with a drawer, the remote/mp3 player cubby, 4 non-custom shelves and 3 blanks for about $525.
post #17 of 35 Old 05-01-2013, 10:10 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Big, you should become a MA dealer.
Comparable MA is $800 street, plus freight. Let us know what brand that one is, when you see it.
Neurorad is offline
post #18 of 35 Old 05-01-2013, 10:30 PM
Liked: 2751
Someone pointed out that it looks identical to
http://www.omnimount.com/products/rack_systems_and_carts/rack_systems/re42/
So it probably comes from the same Chinese factory. The difference is with this local vendor (HTdepot.com) you get a much smaller assortment of included shelves.
Neurorad can you explain your comment of why I should be a dealer?
post #19 of 35 Old 05-01-2013, 11:16 PM - Thread Starter
Chad711's Avatar
Edit: Nevermind I just got my answer
Chad711 is offline
post #20 of 35 Old 05-02-2013, 09:50 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
You would be able to buy the equipment from MA, delivered to you or the jobsite, and sell the equipment to the end-user. Your markup would be similar to that of a distributor or reseller. Client gets the benefit of your rack experience (you know what to order), and you get paid for your experience. Fewer ordering mistakes, and equipment is drop-shipped where you need it.
Just a thought, throwing it out there.
Neurorad is offline
post #21 of 35 Old 05-03-2013, 02:58 PM - Thread Starter
Chad711's Avatar
Does anyone know if this rack would allow me to use the standard rack shelves that are for most video/server racks?
http://www.ebay.com/itm/NEW-19-18U-500mm-19-7-deep-wallmount-cabinet-for-multiple-uses-black-color-/221222203942?pt=US_Rackmount_Cabinets_Frames&hash=item3381def226
Chad711 is offline
post #22 of 35 Old 05-03-2013, 03:35 PM
LeBon's Avatar
Quoted: 184 Post(s)
Liked: 86
The 19" width is standard, and would fit any shelf designed for a 19" RETMA rack. Note that this rack has square holes in the vertical rails, into which you snap "cage nuts" at locations where you want to screw something in.
LeBon is offline
post #23 of 35 Old 05-03-2013, 04:34 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Also, that linked ebay rack is pretty shallow. The rear panel looks like pressboard, not sure if that will be an issue for you.
I don't know what this means: "Handle room: 1.5" at least". Does the handle interfere with closing, if equipment is mounted there?
I'd have concerns about that no-name rack. That's a pretty short rack, too.
Neurorad is offline
post #24 of 35 Old 05-03-2013, 10:12 PM - Thread Starter
Chad711's Avatar
Thanks. What is a RETMA rack? I'm all new to this. Also LeBon I wasn't sure what point you where trying to make about the cage nuts? Sorry again I'm just not familiar so not sure if you we're trying to tell me to be concerned, etc.
Neurorad by short you mean the 39"? I'm looking for one that size.
Thanks for the feedback!
Chad711 is offline
post #25 of 35 Old 05-04-2013, 10:04 AM
LeBon's Avatar
Quoted: 184 Post(s)
Liked: 86
RETMA as the old Radio Electronics Television Manfuacturers Association, who adopted the standards for the racks we now call standard. You prbably need to be an old guy like me to even know what RETMA is. 19" wide, and divided into 1.75" units vertically. So equipment designed to fit in a standard rack are multiples of 1.75" ( 1 RU = Rack Unit) high.
The square hole/cage nut racks are usually server racks. An A/V rack like the Slim 5 has drilled and tapped screw holes in the vertical rails. Shouldn't be a problem, as long as you have a source for the cage nuts.
LeBon is offline
post #26 of 35 Old 05-05-2013, 08:29 AM - Thread Starter
Chad711's Avatar
Thanks for the info! The more I look around it seems my best bet is to go with the Slim 5 rack and get some shelves for it. Is there any reason to get something other than the Half Rack Shelves if I'm just putting in standard stuff like BluRay player,. Receiver, cable box, Xbox? I was thinking about just getting a few of those, a storage box for remotes and then something for cable management. Any suggestions or comments about what I'm getting?
Chad711 is offline
post #27 of 35 Old 05-05-2013, 10:24 AM
LeBon's Avatar
Quoted: 184 Post(s)
Liked: 86
Pretty hard to beat the Slim 5 rack for a built-in installation. Any standard 19" rack shelf or panel will work in it.
The main thing that sets MA apart is their line of custom rackshelves with front panels to fit around virtually any piece of electronics you can come up with.
kelton325 likes this.
LeBon is offline
post #28 of 35 Old 05-07-2013, 10:27 AM - Thread Starter
Chad711's Avatar
Chad711 is offline
post #29 of 35 Old 05-07-2013, 12:15 PM
jautor's Avatar
Quoted: 1218 Post(s)
Liked: 780
Is this worth getting? Placing my order today and they recommend this.
http://www.customavrack.com/products/592-middle-atlantic-horizontal-rack-mount-server-rack-power-strip-pd-915r-15a.aspx
"Worth" is a strong word here. It's just a power strip, but in a very nice form factor. You can get a less-nice solution for less money.
I went the other direction - since I wanted a light for the rack, and needed a power strip, I used the MA light / strip. I went with the brushed decorator model, but this one is cheaper:
http://www.customavrack.com/products/946-middle-atlantic-pdlt-815rv-rn-lighting-and-power-distributor.aspx
jautor is online now
post #30 of 35 Old 05-07-2013, 01:22 PM - Thread Starter
Chad711's Avatar
Did you mount yours in the front or back of the rack? I should probably just go ahead and bite the bullet and get it. This HT project is costing me more and more every day!!!!!
Chad711 is offline
