Show Me Your Under the Stairs equipment rack! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 04-29-2013, 11:15 AM - Thread Starter
greedo's Avatar
Moving my rack destination to under the stairway, and wondering who has some great design ideas...
greedo is offline
post #2 of 9 Old 04-29-2013, 01:17 PM
jacquesstrap's Avatar
Subscribed. I'm doing the same for my basement and would love to see some design ideas.
jacquesstrap is offline
post #3 of 9 Old 04-29-2013, 02:28 PM
camsauce3000's Avatar
Interested in this as well!
camsauce3000 is offline
post #4 of 9 Old 04-29-2013, 06:22 PM
kelton325's Avatar
My rack is under the stairs in my utility room facing into my theater room. It started as a temporary shelf but evolved into a Middle Atlantic rack mounted in the wall. My build thread (see sig) has full details starting on page 4.
Started with this...
Cut hole in the Theater room wall - you can see the shelving above through the opening...
Final product...
kelton325 is offline
post #5 of 9 Old 04-29-2013, 07:54 PM - Thread Starter
greedo's Avatar
What type of MA rack is that? I'm planning on doing the same thing.
greedo is offline
post #6 of 9 Old 04-29-2013, 11:23 PM
kelton325's Avatar
It's just 2 rack rails attached to the box you can see in the photo. You can attach any accessories, shelves, etc that only need front rail mounting. I have a full part list in my build thread.
post #7 of 9 Old 04-30-2013, 09:16 AM
wildcat91's Avatar
Still a work in progress but here's a few picks. Rack opening will be covered with a bookcase and glass door to access equipment
wildcat91 is offline
post #8 of 9 Old 04-30-2013, 09:23 AM - Thread Starter
greedo's Avatar
One issue I'm curious about is how people are using an IR blaster. With my rack pointing into the hallway, should I mount the blaster opposite the rack?
greedo is offline
post #9 of 9 Old 05-01-2013, 06:50 PM
kelton325's Avatar
I use IR heads that plug into a blaster hidden in the rack. I run the head wires through the rack to the front of the component where they stick on. The "stick" doesn't hold very long but they make a hood-like sticker that you can put over them to hold them on really well (and also clean up the look a little).
