Stage OSB Layers Should They go Sidewall to Sidewall? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-08-2013, 02:09 PM - Thread Starter
Mark Lem's Avatar
OK So I've built my stage framing, leaving an inch or so space from back wall and both side walls, with 1" Linacoustic RC in those spaces between stage frame and walls. Then filled stage cavities with sand. Thats where I am right now...
Now I'm putting on two 5/8" OSB layers (green glue between). Should this layer be spaced the same (1") from the back and side walls or should it span wall to wall?
Mark Lem is offline
post #2 of 8 Old 05-08-2013, 02:18 PM
HopefulFred's Avatar
Quoted: 490 Post(s)
Liked: 422
HopefulFred is online now
post #3 of 8 Old 05-08-2013, 03:17 PM
TMcG's Avatar
Quoted: 1072 Post(s)
Liked: 870
Leave 1/4" gap to allow for material expansion while still not touching the sides.
TMcG is offline
post #4 of 8 Old 05-08-2013, 03:25 PM
warrenP's Avatar
Liked: 60
It shouldn't touch, but you don't need a full 1 inch gap. As TmcG said, a 1/4" gap will work just fine.
Every man dies. Not every man really lives.
warrenP is offline
post #5 of 8 Old 05-08-2013, 03:47 PM - Thread Starter
Mark Lem's Avatar
thanks all
Mark Lem is offline
post #6 of 8 Old 05-08-2013, 05:33 PM
Quoted: 3257 Post(s)
Liked: 2743
I carry scrap strips of 1/2 plywood and tack to the wall, I build the stage and pull them out
post #7 of 8 Old 06-12-2013, 12:34 PM
avtexan's Avatar
Quoted: 47 Post(s)
Liked: 89
Big,
When you pull the spacers out do you replace it with anything or leave an air gap? I remember reading about using a fiberglass filler but not sure if that is needed.
The Moving Pictures Theater Construction Thread:
http://www.avsforum.com/t/1462881/th...ruction-thread
Houston GTG - Summer 2014
http://www.avsforum.com/forum/61-are...l#post26079610
avtexan is offline
post #8 of 8 Old 06-12-2013, 04:47 PM
Liked: 2743
