wall construction to hang a screen - AVS Forum | Home Theater Discussions And Reviews
Old 05-09-2013, 08:38 AM - Thread Starter
cdb52's Avatar
Hello.
I want to hang my screen (85 X 60 (in)) but my selected wall is stepped so I need to build up the upper portion (5 inches deep).
What are my best options based on aesthetics, minimal/maximum effort and cost and does it really matter as long as the wall can support the screen?:
The options are -
1. complete the wall across the entire room;
2. build a wall so the the screen rests on the screen verticals (85 w X 49 h);
3. build a wall to hang the hooks for the screen ( approx 44 w X 49 h).
Doug B
cdb52 is offline
Old 05-09-2013, 04:43 PM
bluewaves's Avatar
what screen and how does it wall mount, if it just hangs from the top you could just place a 2x4 on some blocking to bring it even with the bottom of the wall and you'll be set with about $15 in lumber and some screws
bluewaves is offline
