MisterMRs Starry Night Cinema with electric 4-way DIY masking system with Somfy motors - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #31 of 55 Old 05-12-2013, 05:47 AM - Thread Starter
MisterMR's Avatar
Surfdrifter and vipinjosea like this.
MisterMR is offline
post #32 of 55 Old 05-12-2013, 01:05 PM
MrPictureman's Avatar
Thanks MisterMr
Great Job!
MrPictureman is offline
post #33 of 55 Old 05-13-2013, 09:18 AM
calimark's Avatar
I sure have enjoyed reading it ;-). A job well done. Like you have I already referenced those other great masking threads.
Could you clarify on the AL BAR you used for the Horizontal masks?
What is the thickness and width? Do i understand correctly that you also used a U- channel and wood to stiffen up the entire bar?
Have you ever heard of 'delrin' ? It looks to be a nice material to use on the ENDs where the BAR rides in the H-channel.
Thanks for posting all the somfy info! It helps to have a list to reference. They have way too many options.
calimark is offline
post #34 of 55 Old 05-13-2013, 10:52 AM - Thread Starter
MisterMR's Avatar
Originally Posted by MrPictureman View Post
Thanks MisterMr
Great Job!
MisterMR is offline
post #35 of 55 Old 05-13-2013, 10:54 AM - Thread Starter
MisterMR's Avatar
Thanks Calimark! I appreciate you commented on my thread!
I have now tried to measure the aluminium bar and it is 40 mm width and 4 mm thick.
Yes, I use the u-channel to stiffen the mask and to make a straight edge and to keep the tree board and the aluminium bar together. I also use wood to stiffen the construction, to make it more heavy (good for the horizontal mask) and to have something to staple in.
I haven`t heard of delrin. Maybe someone else here can post a reply and comment on that?
I used “silicon super glider spray” to minimize friction in the lower H channel. That is something that plumbers use in their work.
Here is another drawing to make everything more understandable.
The view is from behind. You can see how I fixated the speaker fabric and fidelio velvet with the staples. You can also see the tree bar and aluminium bar and the u channel.
Click to enlarge.
MisterMR is offline
post #36 of 55 Old 05-13-2013, 11:06 AM
Brad Horstkotte's Avatar
Liked: 68
Thanks for taking the time to document MisterMR, looks like a well thought out solution!
Do you ever have any issues with the speaker fabric creasing after being rolled and unrolled over time?
I'd love to have something like this (I have a 2.125:1 screen, currently with no masking) - but just can't get past the cost of the darn motors - so I'll probably either stay with no masking, or create a manual masking system.
Brad Horstkotte is offline
post #37 of 55 Old 05-13-2013, 01:59 PM - Thread Starter
MisterMR's Avatar
The speaker fabric is a bit stretchy and I believe that keeps it from getting creased. So far I have had no problem with this.
I justified the purchase with comparing it to the cost of a projector. I think the masking system is as important as the projector and you buy the motors only once and you will probably buy new projector every 7th year or so. So in the long run maybe the motors aren`t so expensive after all….? rolleyes.gif
MisterMR is offline
post #38 of 55 Old 05-13-2013, 06:06 PM
petew's Avatar
Quoted: 25 Post(s)
Liked: 68
Great thread MisterMR. Your choice of bungee cords is brilliant! I've been struggling with a masking design and bungee cords will work great for me too.
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
post #39 of 55 Old 05-13-2013, 07:20 PM
Moggie's Avatar
Quoted: 23 Post(s)
Liked: 33
MisterMr,
Thanks for documenting your beautiful build and very well done on the masking system!
calimark: I used delrin in my masking build. It is a perfect plastic that is easy to machine and has natural lubricating properties and thus is very unlikely to stick in the track.
brad: I've been using my masking system (a lot) over the past two years. I have absolutely no creasing in the material but I did use iron on non-stretch strips at the edge of the fabric. This also solves the problem of the fabric fraying. I have noticed that my bungy cords are not quite as strong as they were a year ago -- I needed to pull them a little tighter to keep the fabric tight.
Cheers,
- Paul.
My "Old Vic" Theater Build | Screen Build | HT of the Month | Contest Win
My 8 year old daughter: "are contractors the people that mess up your house for money?"
Moggie is offline
post #40 of 55 Old 05-15-2013, 04:38 AM - Thread Starter
MisterMR's Avatar
Thanks petew!
I am glad I could be of inspiration.
Good luck with your masking system!
MisterMR is offline
post #41 of 55 Old 05-15-2013, 05:15 AM - Thread Starter
MisterMR's Avatar
Originally Posted by Moggie View Post
MisterMr,
Cheers,
- Paul.
Thanks Paul! It is fun getting such nice words from an AVS legend as yourself! smile.gif
And thank you for your info on Delrin. It sounds lika a great material!
I have had no issues with the plastic channel and it has been doing its work for 5 months now. I used the whole width of the speaker fabric so I believe there will be no fabric fraying here either.
MisterMR is offline
post #42 of 55 Old 05-15-2013, 07:20 AM
damelon's Avatar
Liked: 269
Excellent job, and quite a DIY engineering feat if I do say so myself
damelon is offline
post #43 of 55 Old 05-16-2013, 10:54 AM - Thread Starter
MisterMR's Avatar
Thanks Damelon, I appreciate your comments very much! And by the way... I have really enjoyed reading about your fantastic HT! Great work!
MisterMR is offline
post #44 of 55 Old 05-17-2013, 09:45 PM
calimark's Avatar
MisterMr,
Cheers,
- Paul.
Good to hear as its on my list...whenever I get around to building my masking system
calimark is offline
post #45 of 55 Old 05-22-2013, 01:13 PM
calimark's Avatar
Could you confirm the thickness of your AL tubes? And do you experience any sagging at 3.5M long (~10.5ft)?
calimark is offline
post #46 of 55 Old 05-24-2013, 11:45 AM - Thread Starter
MisterMR's Avatar
Hi Calimark!
My tubes are 50 mm x 1.5 mm and there is no sagging at all. Even the 3.5 M:s are completely straight.
MisterMR is offline
post #47 of 55 Old 06-19-2013, 06:28 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I'm going to need to review this again when it's screen time.
Mfusick is offline
post #48 of 55 Old 08-20-2015, 06:14 PM
vipinjosea's Avatar
Quoted: 36 Post(s)
Liked: 5
Originally Posted by MisterMR View Post
And more pictures of the theater:<br><br><a class="H-lightbox-open" href="http://www.avsforum.com/content/type/61/id/205723/"><img alt="" class="lightbox-enabled" data-id="205723" data-type="61" src="http://www.avsforum.com/content/type/61/id/205723/width/500/height/1000/flags/LL" style="; width: 500px; height: 747px"></a><br><br><br>
Skyline diffuser<br><a class="H-lightbox-open" href="http://www.avsforum.com/content/type/61/id/205724/"><img alt="" class="lightbox-enabled" data-id="205724" data-type="61" src="http://www.avsforum.com/content/type/61/id/205724/width/500/height/1000/flags/LL" style="; width: 500px; height: 335px"></a><br><br>
Angled wall<br><a class="H-lightbox-open" href="http://www.avsforum.com/content/type/61/id/205729/"><img alt="" class="lightbox-enabled" data-id="205729" data-type="61" src="http://www.avsforum.com/content/type/61/id/205729/width/500/height/1000/flags/LL" style="; width: 500px; height: 747px"></a><br><br>
More to come..
Amazing Work !!! Thank you for sharing. Really brilliant thought on screen masking. May I know why did you use Skyline diffuser most of the places than absorber? Did you use absorber any where in this home theater?
Geek Cinephile
vipinjosea is offline
post #49 of 55 Old 08-22-2015, 07:13 AM
lemonslush's Avatar
Quoted: 823 Post(s)
Liked: 402
What type star ceiling do you have? Looks great @MisterMR
"we need more power" - My Wife.
Theater Build Thread - Wartooth
lemonslush is offline
post #50 of 55 Old 08-24-2015, 04:41 AM
logain2000's Avatar
Baffle wall with 1" insulation
Sand filled stage
Star ceiling
I love your theater. I am looking at putting theater chairs like yours in the back row. I was wondering how you like them? Where did you buy them from?
Stephen
logain2000 is offline
post #51 of 55 Unread 09-09-2016, 05:55 AM
thedudexxi's Avatar
Quoted: 96 Post(s)
I bought some 50 mm aluminium pipes. I have read here somewhere that steel pipes will mess with the IR-signals and therefore should be avoided. I made two long pipes (3.5 meter) and two shorter pipes (2 meter). At one end of each pipe I made a litte cut. The motor has a corresponding ridge and the motor can be fixated to the pipe with that ridge.
At the other end of the motor I put one of the brown plastic cups. I drilled four holes through the aluminium pipe and put 4 screws that fixated the pipe to the motor. The motor is now secured in both ends.
Thanks so much for the walk through on your masking solution!
I'm looking to put together a similar design.. I did have a quick question (I know this thread has been dormant for some time.. So, I totally understand if you don't remember/don't have time.. But, it doesn't hurt to ask!)
I know you had to use normal aluminum tubes (i.e. - not rollease tubes) - and you write that you cut a notch out on the side of the tube - and then you drilled 4 holes. I kind of got lost on where the 4 holes/screws went.. And the notch - did that essentially act as the notch found in rollease tubes (picture attached)?
I'm really excited to try and put this together. Thanks for all your help!
thedudexxi is offline
post #52 of 55 Unread 09-12-2016, 07:25 AM
calimark's Avatar
The motors have screws to secure them so that they actually drive the pipe. The motor I used had 1 screw.
His probably had 4 or maybe he added more.
If using the rollease tubes they have grooves/channels and the drive part of the motor is held securely in them.
With flat round pipes you need to secure the drive portion to the tube, hence the screw.
calimark is offline
post #53 of 55 Unread 09-12-2016, 01:09 PM
thedudexxi's Avatar
Quoted: 96 Post(s)
I think I understand. With a regular, non rollease tube - the motor is equipped to accept a screw to secure the device. If a rollease tube is used - the matching crown will fit and will make the screw unnecessary?
(Thanks for your reply - I'm pumped to try and build this..)
post #54 of 55 Unread 10-19-2016, 11:47 PM
warwwolf7's Avatar
Cool
Hi,
I just wanted to say a little thank you. I respect the fact that you took time to explain very well how you have come with your system. I am really greatful.
warwwolf7 is offline
post #55 of 55 Unread 02-08-2017, 01:32 AM
Quoted: 31 Post(s)
Liked: 2
Wow! Great Work on the masking system MisterMR.
Fronts: RF-82 II
Center: RC-62II
Subs: 2 X R-112SW
Front Surrounds: 2 X RS-52II
Rear Surrounds: 2 X RB-61 II
ATMOS in ceiling: 4 X Klipsch CDT-5800-C II
nandkisham is offline
