Homemade MDF Register Boots will screws hold together - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-11-2013, 04:00 PM - Thread Starter
Mark Lem's Avatar
Have to move two supply hvac floor vents and moving a return from floor to new soffit above projector. Plan is to make some register boots out of MDF and line with linacoustic RC.
MDF seems to disintegrate a bit in the screw hole when I screw it to 2x6's for my stage curve, but the head of the screw holds the mdf well enough against the 2x6. If I screw MDF into MDF to make a rectangular boot, will it hold together?
Thanks in advance
Mark Lem is offline
post #2 of 3 Old 05-11-2013, 07:04 PM
Colm's Avatar
Liked: 94
If you predrill and use approriate screws, like these, you should be fine. Otherwise you are likely to have trouble.
Colm is offline
post #3 of 3 Old 05-11-2013, 07:36 PM
NGiovas's Avatar
Liked: 43
My boots are made from MDF. I didn't use any screws. Just wood glue and a few brads to hold it together while it dried. The glue is stronger than the wood.
NGiovas is offline
