How/Where to install wall sconces? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-16-2013, 11:50 PM - Thread Starter
lnong's Avatar
Quoted: 58 Post(s)
Liked: 24
I'm planning to mount an 80" flat screen onto my wall, and I want to install a wall sconce on each side of the TV. The center of the TV is 50" off the ground and the top edge of the TV is 74" off the ground. Is there a general rule as to how high off the ground and how far from each side of the TV a sconce should be mounted? You guys have any suggestions?
Also, I havent bought any sconces yet, but the electrician is coming over this weekend to run the wiring. I have no idea how a sconce is installed and so I wanted to know how should he set up/lay out the wires so that it is "install ready"? Does he need to put in old work boxes or junction boxes? Can he leave the power cables sticking out of the wall, so that when I buy the sconces, i can just connect the wires?
TV: Samsung 85" UN85HU8550 (TD01) with SEK-3500
AVR: Marantz SR7010
Speakers: Dynaudio Audience
lnong is offline
post #2 of 3 Old 05-17-2013, 04:54 AM
Quoted: 3653 Post(s)
Liked: 3103
about 20 feet to the sides of the TV
post #3 of 3 Old 05-17-2013, 09:51 AM - Thread Starter
lnong's Avatar
Quoted: 58 Post(s)
Liked: 24
20' ?!!
My wall is about 18' long. The TV is about 6' in length. So when the TV is centered on the wall, it would leave about 6' of linear wall space on each side of the TV. I'm thinking of placing the sconces about 2' or 3' away from each side of the TV. Is that still too close to the TV and would create a distraction or glare?
As for the height of the sconce, should it be mounted at eye-level when standing up? Should it be centered vertically with the TV?
AVR: Marantz SR7010
lnong is offline
