Best way to cable wall mounted tv? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-18-2013, 02:04 PM - Thread Starter
Eppo120's Avatar
So I'm planning a home theater in my basement. So far, i know I'm going to wall mount the LG ga6400. I'm going to have my 5.1 reciever , cable box, ps3, and PC with hdmi out in a closet. So i plan to run 4 hdmi, cat 6, and the ir blaster cable in the wall.
How should I route the cables to the tv? Just through one of those grommet plates? Can I get a plate with 4 hdmi? I've only seen them with 2. Then I would need 2, 1 gang plates just for hdmi, then one for network, and one for power.
I would just like to know how you guys who have done it before did it, and made it look nice and work correctly.
Eppo120 is offline
post #2 of 6 Old 05-18-2013, 02:42 PM
Quoted: 3265 Post(s)
Liked: 2751
get an HDMI switching receiver and just run one HDMI cable from the receiver to the TV.
post #3 of 6 Old 05-18-2013, 03:11 PM
weaselfest's Avatar
Quoted: 46 Post(s)
Liked: 41
your wall mounting bracket will dictate how much depth the other stuff you have behind the TV can take up. adding another wall plate connection behind the TV is going to add the depth of that connector as well as create another failure point in the system. some sort of pass through grommet or snorkle gives you the ability to stuff cable back into the wall if needed, makes servicing the installation much easier.
underachiever extraordinaire
weaselfest is offline
post #4 of 6 Old 05-18-2013, 03:39 PM - Thread Starter
Eppo120's Avatar
The receiver I'm using has hdmi ports that don't work though I'll save $120 in cables if I just run one. I may go that route. I saw a TV Mount where the cables routed right through it. So I'll probably just mount the 1 gang for electric, and calls in the wall.
Eppo120 is offline
post #5 of 6 Old 05-18-2013, 03:39 PM - Thread Starter
Eppo120's Avatar
Eppo120 is offline
post #6 of 6 Old 05-25-2013, 10:39 PM
abirdie4me's Avatar
PowerBridge is the way to go.
http://www.powerbridgesolution.com/
abirdie4me is offline
Lg Electronics 55ga6400 55 Inch Cinema 3d Led Lcd Hdtv
