Need Help with Acoustic - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-20-2013, 09:27 AM - Thread Starter
tkarns24's Avatar
CREATOR: gd-jpeg v1.0 (using IJG JPEG v62), default quality
Here are some specification
Tile floor
multiple archway and opening
large open floor plan
What can i do, Do i need to do anything?
tkarns24 is offline
post #2 of 7 Old 05-20-2013, 10:57 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Curtains and rugs will naturally help
Mfusick is offline
post #3 of 7 Old 05-20-2013, 12:08 PM - Thread Starter
tkarns24's Avatar
Hey I am trying to load the the layout plan of my place so that i could get some more help ,but the system will not allow odg file. Any advise
tkarns24 is offline
post #4 of 7 Old 05-20-2013, 12:23 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
what is an odg file ?
Mfusick is offline
post #5 of 7 Old 05-21-2013, 11:16 PM
GIK Acoustics's Avatar
Quoted: 16 Post(s)
Liked: 33
Can you be a bit more descriptive on the room please?
Can you give us the dimensions of the room? What is the line drawn behind (above in the drawing) of the television. A wall? Half wall? Neither?
Do you notice specific problems you're trying to address or just overall improve clarity?
Guaranteed there is a lot of reflections in the room as it is, since it's bare with reflective flooring. This layout is a bit more typical of a studio and not a theater but hits the same general ideas that are important for treatment and you can use it as a guide: http://gikacoustics.com/acoustic-advice/
Alexander Reynolds
GIK Acoustics
GIK Acoustics is offline
post #6 of 7 Old 05-22-2013, 05:35 AM
HopefulFred's Avatar
Quoted: 523 Post(s)
Liked: 484
HopefulFred is offline
post #7 of 7 Old 05-31-2013, 01:40 PM - Thread Starter
tkarns24's Avatar
Room Size 20 x15
Line is a half wall
I don't currently have the system fully setup. I am wanting to anticipate the problem as i say that i have a lot of open space and tile floor. Since i am renting i am limited on what i can ,but i would like to add some acoustic panels in order to balance out the issues.
tkarns24 is offline
