Lutron Spacer System and Harmony remote - AVS Forum | Home Theater Discussions And Reviews
Old 05-21-2013, 03:10 PM - Thread Starter
Crash11's Avatar
Quoted: 23 Post(s)
So I tried getting an answer to this in the remote forum, but I'm not getting any response. I've read a few threads that talk about this topic, but they aren't very specific. Everyone says you set your lighting zones how you want them, then just hold down the scene button and it will automatically program the dimmers. I need specifics. I've tried this and the dimmers don't program, they just start reacting as if I'm telling them to go to a particular scene, which they can pre-programmed with some default settings. I have a Harmony 700, and I set it up such that when I go to device mode and select my lighting device.....I have just a few buttons: All on, All off, Dim, Brighten, Scene 1, Scene 2, Scene 3, and Scene 4. When I set my 4 zones how I want them for a particular scene and hold that scene button, the lighting just changes to the default command. Do I have to program these scene buttons as soft buttons in the number pad (i.e. scene 1 = "1" on the number pad)?
Crash11 is offline
Old 05-23-2013, 12:08 PM - Thread Starter
Crash11's Avatar
Quoted: 23 Post(s)
Crash11 is offline
Old 05-23-2013, 12:21 PM
jason4vu's Avatar
Quoted: 26 Post(s)
Liked: 92
It should work as you are describing. Hold down a button on the scene controller and then it would program the dimmers at their current state. I had this setup before my remodel.
Race to the finish home theater buildhttp://www.avsforum.com/forum/19-ded...ter-build.html
jason4vu is offline
Old 05-23-2013, 01:33 PM - Thread Starter
Crash11's Avatar
Quoted: 23 Post(s)
What's the scene controller?
Edit: Nevermind. I figured it out. You can't use the activity buttons at the top. You have to assign the scenes to any other buttons down below (e.g. 1,2,3 and 4 on the numberpad). Unfortunately it seems like scene 1 is linked to "All Lights On".
Crash11 is offline
Old 05-23-2013, 03:09 PM
jason4vu's Avatar
Quoted: 26 Post(s)
Liked: 92
That's correct and the bottom is all lights off
jason4vu is offline
