Hat Chanel joints and IB-1 Clips - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-22-2013, 07:00 AM - Thread Starter
cw5billwade's Avatar
Quoted: 328 Post(s)
Liked: 184
My question to the masses I have 23 foot wall. I am using 12 foot hat channel. More out of laziness I am not cutting just overlapping 12”. Due to 24” on center studs every other channel’s joint is on a IB-1 clip. This makes for a pretty stiff joint. Is this ok or should I cut the channel so that the joint is not on a clip?
cw5billwade is offline
post #2 of 5 Old 05-22-2013, 07:08 AM
J_P_A's Avatar
Quoted: 651 Post(s)
Liked: 484
The clip is not designed to have double layers of hat channel in it. The SIM for the IB-1 specifically states that the joints must fall between clips.
EDIT: Are you planning to put fiberglass insulation in those walls?
The Plains Theater Has Begun
J_P_A is offline
post #3 of 5 Old 05-22-2013, 07:52 AM - Thread Starter
Quoted: 328 Post(s)
Liked: 184
thanks I will trim them I must have mised that in the instructions. Yes the builder is having them install R13 and R19 in the ceiling
post #4 of 5 Old 05-22-2013, 08:11 AM
J_P_A's Avatar
Quoted: 651 Post(s)
Liked: 484
You made me curious, so I had to go back and check. Item 4 from the SIM. It's pretty easy to overlook stuff in these instructions. I pestered John and Ted to death because I was worried about overlooking something important. Fortunately, they are very patient people smile.gif Hopefully they won't mind me posting an excerpt from their instructions.
J_P_A is offline
post #5 of 5 Old 05-22-2013, 08:43 AM - Thread Starter
Quoted: 328 Post(s)
Liked: 184
thanks I remmember that now I did not have my instructions with me when I put the channel up.
