How to incorporate my Macbook Pro laptop in my Theater room? - AVS Forum | Home Theater Discussions And Reviews
Old 05-24-2013, 10:57 AM - Thread Starter
Chuck1906's Avatar
I guess another way of asking this is what cable do I need to run from the projector down to where I may have the laptop sitting? I want to be able to play content from my laptop and have it projected on the screen. I actually wired an HDMI to DVI jack I built into the side of my riser and then I would connect another cable from the jack to my laptop but for some reason that isn't working and I am betting the cable somehow became dislodged from the jack on the inside of the riser. Since the riser is fully carpeted now, I can't gain access to the insides unless I cut up the carpet and cut a hole in the riser.
That idea is not going to happen LOL! I can run a new cable and hide it out of the way....I just need to know which cable I would need. Again I am using a older model Macbook Pro laptop.
Chuck1906 is offline
Old 05-24-2013, 11:44 AM
jautor's Avatar
Quoted: 1218 Post(s)
Liked: 782
Can you not unscrew the jack plate and access the cable through the hole to check if it's come loose?
But otherwise, add an AppleTV and use AirPlay video mirroring to display your Mac's screen...
jautor is online now
Old 05-24-2013, 12:47 PM
scl23enn4m3's Avatar
This is what we currently do. The big issue with it though is Airplay doesn't support anything more than stereo audio. And when you're in a theater you want more than stereo. So it's cool for slide shows and general internet browsing, but don't expect a glitch free experience with a 1080p 5.1 file.
Pics of your setup? I'm curious as to why you can't gain access.
scl23enn4m3 is offline
