Current Light Control Options - AVS Forum | Home Theater Discussions And Reviews
Old 05-24-2013, 12:41 PM - Thread Starter
Pat in Az's Avatar
Hey guys,
Here is a rough Sketchup of the room. I am going to have 3 light zones (side/rear cans, screen wash cans, and rope tray). I do want to be able to control them with a smart remote. Also unsure if I want to put the switch(s) inside or just outside the theater door.
Thoughts or best options?
Pat
Pat in Az is offline
Old 05-25-2013, 01:15 AM - Thread Starter
Pat in Az's Avatar
I guess I should have been more specific. I have read a bunch of threads regarding light control (some old, some new) but I know the technology changes pretty rapidly.
I am trying not to go overboard, and just looking for a simple 3 zone solution.
What are the current "go to" set ups?
Old 05-25-2013, 02:04 AM
Brad Horstkotte's Avatar
Liked: 68
Lutron GrafikEye and Lutron Spacer System are probably the most common.
Edit: check eBay for GrafikEyes, they are pricey new from retailers, but sometimes there are better deals there - here's a used 3 zone for example: http://www.ebay.com/itm/Lutron-Grafik-Eye-Lighting-GRX-4103-4100-Series-3-Zone-Dimming-Control-Unit-/281093983595?pt=Home_Automation_Controls_Touchscreens&hash=item417281cd6b
Brad Horstkotte is offline
Old 05-25-2013, 06:52 AM
Quoted: 3265 Post(s)
Liked: 2751
May want to consider insteon for three zones.
Old 05-25-2013, 08:43 AM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 81 Post(s)
Liked: 126
I just setup my mi casa verde 3 this week and to control some z wave switches and insteon in the theater area and other parts of the house it is easy to setup
also if you using irule or roomie to control you theater you can also control the lighting.
snickers1 is offline
Old 05-25-2013, 11:03 AM
tbraden32's Avatar
That is a 4000 series unit. I do not believe that is the one you are looking for, check, the Grafik Eye sticky. You will want a GRX-3000 series such as 3103 or 3503.
tbraden32 is offline
Old 05-25-2013, 11:30 AM
Liked: 68
Ah maybe so, its been a while since I was in the market - took a look back in my build thread to remind me, I did use a GRX-3104
Old 05-25-2013, 01:24 PM - Thread Starter
Pat in Az's Avatar
Thanks guys!
Old 05-25-2013, 11:12 PM
scl23enn4m3's Avatar
Mind explaining the difference? The auction Brad linked to is significantly less than I expected to drop on a Grafik Eye.
scl23enn4m3 is offline
Old 05-26-2013, 05:53 PM
tbraden32's Avatar
The 4000 series is used mainly in commercial installs and requires other items to work correctly. Again refer to the Grafik Eye sticky (1st page) or Lutrons website.
The 3000 series can work by them selves without need of other Lutron products.
That is why the 4000 series units are so cheap. Sorry I don't know the exact difference, just enough to not buy the 4000 series.
Old 05-28-2013, 07:15 AM
tlogan6797's Avatar
Quoted: 105 Post(s)
Liked: 131
I'm using Insteaon and so far it's been a breeze. One thing to keep in mind is that you HAVE to have a neutral wire at the switch.
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
Old 05-28-2013, 09:15 AM - Thread Starter
Pat in Az's Avatar
Thanks, I will definitely look at that one too.
