Rope lighting control - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-10-2013, 09:05 AM - Thread Starter
mijotter's Avatar
Liked: 59
What are you guys using to control your rope lighting for the ceiling? I'm wanting something similar to this:
I want to be able to turn it on/off and dim from iRule
I have an outlet near too that I can use.
mijotter is offline
post #2 of 4 Old 06-10-2013, 09:12 AM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 81 Post(s)
Liked: 126
most will install an outlet in there light tray and control it by a light switch/dimmer
you will need to make sure the rope light or led's you use are dimmable ,
you can us insteon dimmer switch
in your case if you do not have a switch then check out smarthome.com for insteon or zwave lamp module
something like this
http://www.smarthome.com/2457D2/LampLinc-INSTEON-Plug-In-Lamp-Dimmer-Module-Dual-Band-2-Pin/p.aspx
i rule can control insteon or zwave devices
snickers1 is offline
post #3 of 4 Old 06-10-2013, 09:13 AM - Thread Starter
mijotter's Avatar
Liked: 59
I was thinkiing the dimmer outlet switch as well but The Insteon rep said that it cannot control LED's under 10watts.
mijotter is offline
post #4 of 4 Old 06-10-2013, 09:21 AM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 81 Post(s)
Liked: 126
they do make dimmable leds light strips and they come with remote to control them .... i have led's in my tray and to be honest i really have never seen a need to dim them. The only time i think it would be cool is if you have a scene setup so that when you start a movie it dims the lights then shuts them off.
