Best thickness or weight of upholstery to cover linacoustic - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-18-2013, 02:34 PM - Thread Starter
neaner72's Avatar
I've been exploring my upholstery options for my HT as far as wall treatments. Is there a desired thickness or weight of upholstery to cover the linacoustic on the walls? Any input on this matter would be appreciated.
"Nick, what did your dad get done in the movie room tonight?" "Nothin', he just went down there and stared again".
Build Link
http://www.avsforum.com/avs-vb/showt...4#post18526304
neaner72 is offline
post #2 of 5 Old 06-18-2013, 04:55 PM - Thread Starter
neaner72's Avatar
Bueller............Bueller.............
Build Link
neaner72 is offline
post #3 of 5 Old 06-18-2013, 05:24 PM
TMcG's Avatar
Quoted: 1186 Post(s)
Liked: 1002
Whatever fabric you choose should be as acoustically transparent as possible for the panel behind to do its job without interference from the fabric. There is a lot of variability in how acoustically transparent different fabrics are, but generally speaking the thicker the fabric and the tighter the weave, the less acoustically transparent and more absorptive it will be and vice versa. Each manufacturer should have ratings for the acoustic transparency of their different fabric types. The test methods are not consistent from company to company from what I have seen, but should give you a general idea of the differences. Good luck!
TMcG is offline
post #4 of 5 Old 06-18-2013, 05:33 PM - Thread Starter
neaner72's Avatar
So, if I can hold it up to a light and see moderate light through it (versus no light) The one I can see light through is the one I want?
Build Link
neaner72 is offline
post #5 of 5 Old 06-18-2013, 06:19 PM
TMcG's Avatar
Liked: 1002
Generally speaking, yes.
EDIT - To elaborate....you really don't want the fabric doing the job of your acoustical treatments. You want the fabric to allow the treatments to function as expected without interference. That being said you will always have some absorption of the high frequencies, but that can be minimized with the right kind of acoustically transparent fabric.
TMcG is offline
