Dead Vent Design: Vent or Drywall First - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 06-23-2013, 11:02 PM - Thread Starter
mijotter's Avatar
Liked: 59
Is it best to put the supply vent boot in and drywall around it or drywall first then cut out the necessary hole for the square vent?
mijotter is offline
post #2 of 10 Old 06-24-2013, 04:54 AM
Quoted: 3649 Post(s)
Liked: 3099
need to know the design of your duct work, the dead vent, the location of this supply, the drywall plans etc. You haven't even started construction yet have you?
post #3 of 10 Old 06-24-2013, 06:38 AM - Thread Starter
mijotter's Avatar
Liked: 59
Furnace duct work is all on the other side of the basement. Both the supply and the return vents for the theater room will be on the same wall up towards the ceiling as I have no room for soffits. Supply will be towards the back of the room and the return will be towards the front(screen) of the room. All of my equipment except for the PJ will be under the screen so I figure that will be the best place to put the return. This particular wall is a double wall as well.
What makes you say that sir?
I can put some pics on here when I get home from work to sort of illustrate where the deadvents will be going.
mijotter is offline
post #4 of 10 Old 06-24-2013, 09:46 AM
Liked: 3099
I 've got the jist of the room now I need to understand your design of a dead vent in relation to the room. As a general rule cutting holes in double layer walls is easier after the fact because you can do a more accurate job, the question is can you hook everything up from the outside looking in?
post #5 of 10 Old 07-02-2013, 03:16 PM - Thread Starter
mijotter's Avatar
Liked: 59
Sorry it took me a while to respond. Here are some pics displaying my wall as it is currently. The first pic is of the theater side with the return opening NE of the tank. The second picture is just on the other side of the same spot.:
Using this dead vent design from Ted:
Instead the Supply and Return on the theater side will be at the top and exit on the bottom on the adjacent side. I had to put the drywall on the inside of the exterior wall of the theater as that wall was already there and drywall could not be placed on the outside of that wall. There is a new wall built in front of that wall if that makes sense.
I have 6" PVC that will go through the double wall and then 6" flex duct attached to that. Just need to know how best to start it with the boot and all and if it would be best to drywall up the theater side wall THEN cut out the hole for the boot and 6" PVC.
mijotter is offline
post #6 of 10 Old 07-03-2013, 08:18 AM
BllDo's Avatar
Quoted: 595 Post(s)
Liked: 395
Originally Posted by mijotter View Post
No idea on the dead vent, but is that enough support for your tank?
BllDo is offline
post #7 of 10 Old 07-03-2013, 10:51 AM - Thread Starter
mijotter's Avatar
Liked: 59
Oh yes, I reinforced the double wall that 85% of the tank is resting on bigtime. I made sure of it as I did not want a pool in my theater room. It's been filled for the past 4 days and everything is still nice and level:)
Any thoughts on my specific dead vent design anyone?
mijotter is offline
post #8 of 10 Old 07-07-2013, 08:11 PM - Thread Starter
mijotter's Avatar
Liked: 59
Anyone?
mijotter is offline
post #9 of 10 Old 07-14-2013, 01:58 AM - Thread Starter
mijotter's Avatar
Liked: 59
Hello?
mijotter is offline
post #10 of 10 Old 07-14-2013, 05:30 AM
Liked: 3099
drywall first then do surgery on the wall to add the dead vent. I don't think you will be happy with a 6 inch duct entering and leaving the theater. If you have more than 250 ft per minute of air through the duct and entrance to the theater there may be air turbulence noise. With a 6 inch duct 250 ft per minute is hit with a fan rated at 50 cu ft per min or more. I'd go for a dead vent design with a larger manifold as it enters the theater.
