RESCUE MY THEATER - Erskine design - Parkinson (BIGmouthinDC) construction - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 15Likes
post #91 of 185 Old 12-05-2013, 05:21 PM - Thread Starter
Quoted: 3500 Post(s)
Liked: 2957
A few of the how I did its, I got support from Erskine as he designed the space, but the ceiling was a client change mid project. I found this handy calculator to convert the width of room the height of the arc into the radius, http://www.handymath.com/cgi-bin/arc18.cgi?submit=Entry
First you need to start with some curved pieces and without any elaborate CNC machine I developed my own 22 ft swing arm saw. I used two sections of hat channel. a piece of Ikea flooring, my Bosch jig saw, The saw is attached to the flooring with double sided carpet tape.
You need to keep the work elevated for blade clearance. I put a temp platform together that had side rails to keep the sheets straight. I would cut a piece then slide the work forward 3 1/2 inches
The pivot point, it is nice to have a wood sub-floor
A few hours later.
Then I assembled two layer pieces with construction adhesive and narrow crown staples.
I stacked them up using the previous piece as my guide.
next you build some assemblies
lift into place, two guys, two ladders then position third hand supports to keep it there, screwed to the ceiling, first layer was OSB
Add a bunch of notched cross pieces. I cut the notches with my table saw and Jig saw.
Then working from the back forward, I put a MDF face on the last layer, roughly 5 is inches tall. then added a 1 1/8 inch three quarter inch strip at the bottom. Then added the bottom drywall for that step cutting flush with the two pieces on the front.
to cut one edge I cheated and used an extra curved assembly that I made. (it was also used to define the stage curve)
Last a 2 3/4 inch piece of pre-primed MDF was added to the front and everything got mudded.
post #92 of 185 Old 12-06-2013, 07:11 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2689
The ceiling is the secret to the sound. If you've taken Erksine class you understand why. A perfect square is not ideal for sound at all, and you can't always change the floor and make it easy to walk on. That leaves the walls or ceiling. It's not just aesthetic design why you see so many of his design builds not using perfectly flat ceilings or walls. Go back and take a look, it's an intentional design element that goes beyond looking cool.
btw,
Really nice work Jeff!!! I love watching you work and seeing your projects. Outstanding job as usual. Posts like that above with commentary and pictures are much appreciated and make this forum awesome.
Mfusick is offline
post #93 of 185 Old 12-06-2013, 08:26 AM
blipszyc's Avatar
Quoted: 134 Post(s)
Liked: 73
Great link. That would've come in handy when I was working on my arches. I ended up drawing everything in SketchUp and letting the Arc tool give me the dimensions.
Visit the Lipszyc Home Theater! 1.0
2.0 done and finally posted! - Theater 2.0
And now...The Queen City Theater (3.0)
blipszyc is offline
post #94 of 185 Old 12-06-2013, 08:34 AM
Nathan Webel's Avatar
Liked: 24
Originally Posted by Mfusick View Post
btw,
Tell me about it! I have an unfinished basement down in Richmond that is SCREAMING for some of his handiwork - if I could just get my financial house in order!
Nathan Webel is offline
post #95 of 185 Old 12-06-2013, 11:05 AM
Wahoo_envy's Avatar
Quoted: 30 Post(s)
Originally Posted by blipszyc View Post
Take a number! If it wasn't for BIG's busy schedule my wallet would be a little lighter. The good thing is he has answered all my questions and my project is nearing completion with more available funding for equipment. Thanks Jeff!
Wahoo_envy is offline
post #96 of 185 Old 12-06-2013, 01:45 PM
blipszyc's Avatar
Quoted: 134 Post(s)
Liked: 73
Originally Posted by Wahoo_envy View Post
Take a number! If it wasn't for BIG's busy schedule my wallet would be a little lighter. The good thing is he has answered all my question and my project is nearing completion and I have more funding for equipment. Thanks Jeff!
No worries. If I play my cards right, I won't need to build a 3rd theater. Hoping to stay in my current home a long, long time.
blipszyc is offline
post #97 of 185 Old 12-06-2013, 08:22 PM
auburnu008's Avatar
Quoted: 438 Post(s)
Liked: 596
Awesome work as usual BIG. The construction of that ceiling is a thing of beauty.
auburnu008 is offline
post #98 of 185 Old 12-06-2013, 10:47 PM
Just add water and stir
zuluwalker's Avatar
Quoted: 46 Post(s)
Liked: 490
Fantastic work on the ceiling! You make it look so easy. No doubt there are many great efforts, and skills at work. Truly a pleasure watching it happen.
zuluwalker is offline
post #99 of 185 Old 03-30-2014, 06:52 AM
bgsu_rhine's Avatar
Great thread. This is build is happening in my neck of the woods and I am definitely subscribed. You mentioned the ceiling was a client change mid project. Was the entire ceiling changed/added mid project or just the radii? Judging by the 1st layer of OSB i assume there was originally something intended to be hanging with multiple anchor points. If the whole tiered ceiling was added did you have to alter the spacing and layout of ceiling clips and channel to account for the additional loading or is there a large enough factor of safety already built in to the system accommodate for all of that additional weight?
bgsu_rhine is offline
post #100 of 185 Old 03-30-2014, 09:03 AM - Thread Starter
Liked: 2957
it was changed after the demo so the clip number and spacing was changed, OSB went up as a first layer to give us a continous base for screwing the frame structure for the four level stepped ceiling.
The original Erskine plan was for a two level ceiling. An oval raised portion in the middle of the room fitting between existing duct work. I thought it would make for a great skylight effect with a star-field ceiling, but the client wanted to go in the direction of other Erskine projects hence the four stepped levels.
post #101 of 185 Old 03-30-2014, 01:44 PM
NGiovas's Avatar
Liked: 44
Jeff,
Any updates on this project?  It has been a couple of months and I am curious to see how it is coming along.
Nick
NGiovas is offline
post #102 of 185 Old 06-17-2014, 08:44 AM
RedStripe88's Avatar
Quoted: 219 Post(s)
Liked: 163
Question
Jeff,
Your theaters inspire me. That's the positive. Your theaters (and a few others) are going to make me spend much more than I should on an HT.
As I not so patiently wait for Shawn to do my Erskine design, I'm trying to find a few pros to help me with my theater build. I've found some. Once I have the design, I'm going to reach out to Ted for soundproofing advice and materials.
I will be comfortable doing much of the woodworking, stage building, building acoustic panels, installing lighting, building the dead vent etc. I definitely want help installing OSB/GG/Drywall, running a couple new electrical circuits, and moving existing plumbing and lengthening fire sprinklers. I'll probably also get help with the automation.
I know you don't do the heavy lifting any more, is there a drywall crew in the DC area that has done the OSB/GG/Drywall for you that you would recommend?
What would it take to have you stop by to walk my space and share some of your wisdom
Paul
My in progress build thread: The Salt Mine
RedStripe88 is online now
post #103 of 185 Old 06-22-2014, 05:59 PM - Thread Starter
Liked: 2957
Orange is the new black COLUMNS:
JTR wall of power, Noisis 212s and two Orbit Shifters
Rich stops by with the FALCON screen, of course I got the white glove assembly service because I'm local.
its phillip and snickers1 like this.
post #104 of 185 Old 06-22-2014, 06:06 PM
Elill's Avatar
Quoted: 100 Post(s)
Liked: 90
Jeff, odd question. Generally speaking, do columns serve any structural purpose in a room?
Peter the Greek
Downunder Theatre MkII
List of Pro Designers
Elill is offline
post #105 of 185 Old 06-22-2014, 06:11 PM - Thread Starter
Liked: 2957
they hold up the speakers and provide a break for fabric seams. One column hides a steel support pole allowing the theater to be 7 inches wider.
Elill and snickers1 like this.
post #106 of 185 Old 06-22-2014, 07:29 PM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 81 Post(s)
Liked: 126
These pics do not do this room justice ...when you here it has orange columns your first thought hmmm i dunno but when you see them in person wow, hopefully when the final pics are taken everyone will see the detail in the columns and the ceiling... also thank you Jeff i now want JTR speakers!!!
snickers1 is offline
post #107 of 185 Old 06-23-2014, 06:09 AM
DougUSMC's Avatar
Quoted: 286 Post(s)
Liked: 210
Wow, that screen is B-E-A-UTIFUL!! I'm leaning towards one of theirs for my HT, how close do you have to be to be considered "Local"? I'm in Ellicott City, MD...
DougUSMC is offline
post #108 of 185 Old 06-23-2014, 07:25 AM - Thread Starter
Liked: 2957
PM Snickers1, what is your drive time from Manassas?
post #109 of 185 Old 06-23-2014, 08:33 AM
DougUSMC's Avatar
Quoted: 286 Post(s)
Liked: 210
Will do, thanks for the tip Big.
I'm 62 mi from Manassas, according to Google maps. We both know in this area that could be either 55 mins or 2 hr 55 mins, depending on day/time...
So close, that I wish I could afford YOUR design services!
DougUSMC is offline
post #110 of 185 Old 06-23-2014, 08:57 AM - Thread Starter
Liked: 2957
Erskine Group is my design resource and the basic layout service is affordable ($700) . If I don't have a plan I typically mimic a photo that my client likes using generally accepted soundproofing and acoustic methods to the extent possible.
post #111 of 185 Old 06-23-2014, 01:52 PM
raczkri's Avatar
Quoted: 14 Post(s)
Liked: 2
Great space! can't wait to see it finished.
May I ask the dimesions of the room and screen?
Thank you.
raczkri is offline
post #112 of 185 Old 06-23-2014, 07:35 PM
Wahoo_envy's Avatar
Quoted: 30 Post(s)
I was going to say what happened to that huge space you had to work with? That was until I saw how small Rich looked compared to the screen and room.
Do the open faced columns stuffed with pink fluffy also act as bass traps? I was wondering if there would be any benefit to cutting mine wide open before covering with a speaker grill.
Another great job!
post #113 of 185 Old 06-24-2014, 04:29 AM - Thread Starter
Liked: 2957
Thank you.
the room is 16ft wide, the screen is 12 ft wide, don't remember the length off the top of my head but we will have two rows and a back sit at bar.
raczkri likes this.
post #114 of 185 Old 06-24-2014, 04:31 AM - Thread Starter
Liked: 2957
Probably somewhat but there are two other bass traps in the room per the Erskine Design. Front wall and riser.
post #115 of 185 Old 06-24-2014, 09:27 AM
GoCaboNow's Avatar
Quoted: 874 Post(s)
Liked: 765
Love that wall of JTR! How do the Noesis 212's sound compared to your 4pi's?
My Dedicated Home Theater Room
GoCaboNow is offline
post #116 of 185 Old 06-24-2014, 03:10 PM - Thread Starter
Liked: 2957
dunno yet, gear not set up. working on the walls presently, all things in due time. I know if I set up the projector and connect the sound, the homeowner will be in there with a deck chair camped out watching movies.
post #117 of 185 Old 06-24-2014, 04:13 PM
Reefdvr27's Avatar
Quoted: 1572 Post(s)
Liked: 1054
Looks great Jeff, I wish I had the talent to build that. However, I have the same speakers
Reefdvr27 is offline
post #118 of 185 Old 07-02-2014, 08:24 PM - Thread Starter
Liked: 2957
Just a little preview of what the wall color is going to look like, darker in person.
post #119 of 185 Old 07-03-2014, 08:23 AM
design1stcode2nd's Avatar
Quoted: 31 Post(s)
Liked: 44
I think I've definitely had a cubicle that color. I like the orange contrast, gives it some "pop".
snickers1 likes this.
Play like a Raven
design1stcode2nd is offline
post #120 of 185 Old 07-03-2014, 08:30 AM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 81 Post(s)
Liked: 126
when you see these colors laid out on table you say hmm i dunno , but they work and look great looking forward to visiting the room again
