Screen decision... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-27-2013, 07:58 AM - Thread Starter
Metallus2000's Avatar
Liked: 30
So.....excited, getting my Panasonic AU-8000 today and seeing where it best fits. Hoping for a throw distance/screen size of 140-150 inch. My room is 13x22(going lengthwise, with a 10 foor ceiling height. I currently have a 100" screen that came with a previous projector purchase.
With that background, I am up in the air with screen framed vs pull down vs painting the wall with screen paint. I can do any at the moment and I am leaning towards a mounted screen, built into a faux front theater area that hides the speakers behind it.
Thoughts?
Ken
Metallus2000 is offline
post #2 of 7 Old 06-27-2013, 09:47 AM
neverfinished94's Avatar
Quoted: 44 Post(s)
Liked: 26
I would go with an AT fixed frame with the speakers located behind the screen.
Check out my just over $5K theater build thread
neverfinished's neverfinished theater
neverfinished94 is offline
post #3 of 7 Old 06-27-2013, 09:52 AM - Thread Starter
Liked: 30
Thanks, that was my lean. Is this a good price at this website?
http://www.projectorscreenstore.com/pss-projector-screens-fixed-frame.html
post #4 of 7 Old 06-27-2013, 10:09 AM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 780
Suggest you take a look at the "Screens" forum up a ways (sub-forum under Display Devices) for more information...
jautor is offline
post #5 of 7 Old 06-27-2013, 01:16 PM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 437
I too would echo an AT screen. Having all speakers not only hidden, but anchored directly behind the screen makes for a truly awesome experience.
I would also advise looking in the DIY screen section. You can build your own AT screen for less than $500.00. I went with XD material, but you many options, including spandex and the like.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #6 of 7 Old 06-27-2013, 01:29 PM
Quoted: 44 Post(s)
Liked: 26
you can pick up a Jamestown frame with a Seymour AT screen for less than $600
post #7 of 7 Old 06-27-2013, 05:43 PM
Quoted: 360 Post(s)
Liked: 437
I almost wish I would have known they carried XD when built mine. I've DIY'd three now and I wouldn't want to do another one. For a few bucks more you can have a very nice aluminum frame and no cussing from velvet wrapping, screen stretching, staple pulling................you get the point. smile.gif
Panasonic Ptae8000u Hd Projector
