Room soundproofing decreases after applying Soundproofing Sealant - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 06-28-2013, 06:26 AM - Thread Starter
nashoomoo's Avatar
After applying Soundproofing Sealant to the corners and top, inside the room, The 3x3 room becomes echoing and ringy and when i close the DIY thick door the sound leakage is much greater then before.
Seems to me that until now the sound had a place where to run in the corners and top to the Roxul Insulation, and be absorbed.
However now the sound can't run so it leaks through the door' WeatherProofing foam seal.
Makes sense?
nashoomoo is offline
post #2 of 13 Old 06-28-2013, 11:08 AM
Quoted: 3265 Post(s)
Liked: 2751
Probably the fumes, move to an area with fresh air.
Tom Bley likes this.
post #3 of 13 Old 06-28-2013, 12:06 PM
damelon's Avatar
Liked: 270
I don't know why.. but I keep laughing...
damelon is offline
post #4 of 13 Old 06-28-2013, 12:36 PM
BllDo's Avatar
Quoted: 572 Post(s)
Liked: 373
Yeah, I got a good chuckle on that one.
BllDo is offline
post #5 of 13 Old 06-28-2013, 12:38 PM
Tom Bley's Avatar
Quoted: 594 Post(s)
Liked: 529
Tom Bley is online now
post #6 of 13 Old 06-28-2013, 01:04 PM
Liked: 2751
SomethIng to consider is that In my expirence the quieter the space the more distinctive the remaining sounds become. A noisey room can be just so much white noise, in a quiet room the air rushing through a duct can be irritating. just like me blowing an answer out my $ss.
post #7 of 13 Old 06-28-2013, 02:33 PM
Nightlord's Avatar
Quoted: 712 Post(s)
Liked: 237
If you get the room better sealed, you can pressurize it harder, so yes if it only has one place to leak instead of many, that leak would sound more.
And one can definitely get other acoustic problems pop up on you when improving other things, it shouldn't be a reason to go back, rather to go forwards further by fixing.
Under construction: the Larch theater
Nightlord is offline
post #8 of 13 Old 06-28-2013, 05:09 PM
LeBon's Avatar
Quoted: 184 Post(s)
Liked: 86
Don't confuse soundproofing with acoustic treatment. You ahould put absorbers and diffusers and bass traps to deal with ringing, reverberation, bass moding, etc. First, get the room as quiet as you possibly can with soundproofing.
LeBon is offline
post #9 of 13 Old 06-28-2013, 05:38 PM - Thread Starter
nashoomoo's Avatar
the Foam is this
7/16 thick.
its all the way around the door.
I think if the seal is enough for soundproofing?
Its definitely not made for sound blocking.
The sound pass through the 7/16 rubber foam???
Here is the Rubber Foam around the opening of the door.
Before applying Noiseproofing Sealent
post #10 of 13 Old 06-28-2013, 07:53 PM
LeBon's Avatar
Quoted: 184 Post(s)
Liked: 86
If it's an airtight seal, it should be doing its job. The more expensive Zero international adjustable seals are more elaborate version of the same thing.
LeBon is offline
post #11 of 13 Old 06-29-2013, 03:36 AM
Nightlord's Avatar
Quoted: 712 Post(s)
Liked: 237
Are you sure it's though the seal, not just through the entire door?
post #12 of 13 Old 06-29-2013, 08:06 AM
Liked: 2751
That foam is a draft stopping product if you are really serious you will want to get adjustable rubber seals like the zero mentioned, see soundproofingcompany.com Turn out the lights in the booth and shine a bright light around outside perimeter of the door to see if you have any gaps in your current setup. A Two person job.
post #13 of 13 Old 06-30-2013, 06:52 AM - Thread Starter
nashoomoo's Avatar
The door is two MDF panel. GG between. Then Roxul insulation and 1 MDF panel.
The framing is 2x3.
