Do basement walls adjacent to concrete foundation (solid poured) have to sound proofed - AVS Forum | Home Theater Discussions And Reviews
Old 06-28-2013, 04:24 PM - Thread Starter
Invictus1911's Avatar
My theater and basement construction is taking place. I'm in the process of putting in drywall. My questions is, on the walls that are adjacent to the foundation needing of sound proofing treatment. The framing does not touch the floor joist or concrete walls. My other two walls are 2x 4 studding
Invictus1911 is offline
Old 06-30-2013, 05:16 AM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
Its always better to use some kind of insulation, behind the sheetrock. It helps to suck up some of the soundwaves, which makes the room less live. A room that is too live is not a good thing with MC system.
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Samsung BD player, Denon DVD-A player, MacBook Pro w/ Dirac Stereo Suite.
4DHD is offline
Old 06-30-2013, 07:52 AM
Quoted: 3265 Post(s)
Liked: 2751
You can't skip the exterior walls, but not for the reason cited. Insulation behind the drywall has nothing to do with room sounding live.
Old 06-30-2013, 08:22 AM - Thread Starter
Can you explain the science of this to me, skipping exterior walls? The walls have r-13 now between studs. Right now I have a simple iPod dock and the sound is hear clear as day in my bedroom directly above theater room. The ceiling was drywalled from builder to pass inspection. The other two walls are one leading into the mechanical room with the hot water tank a d the furnace and electrical control panel, the other is adjacent to my home gym. I assume I should drywall everything, then add my channels and clips to the non exterior walls, and ceiling with 2 layers of dry wall and green glue.
Old 06-30-2013, 08:32 AM
Liked: 2751
I'm on holiday read the articles at soundproofingcompany.com. You want insulation, clips,channel and double layers of 5/8 drywall with GG on the ceiling and all walls. Address holes in the shell for lights and electrical, make sure duct work doesn't conduct sound, and add a beefy door.
Old 06-30-2013, 05:20 PM
Wahoo_envy's Avatar
Quoted: 30 Post(s)
I have 3 1/4 walls in front of below grade poured concrete and took the clips, channel, 2 layers 5/8 drywall with green glue all the way to the pressure treated 2x4 resting on top of the poured wall. This mitigates the sound flanking path typical construction creates. The one wall adjacent to by storage room is staggered stud. It saved quite of bit of money.
In this pic the acoustical sealant still needs to be completed.
This is under the the hvac supply
Wahoo_envy is offline
Old 06-30-2013, 09:14 PM
Anhydro's Avatar
Yes, see Soundproofing.com. Decouple walls from concrete... helps contain bass (low frequency sound waves). It's for soundproofing, not acoustic, reasons.
Anhydro is offline
Green Glue Noiseproofing Compound 12 Tubes
