Corner shelves for components - AVS Forum | Home Theater Discussions And Reviews
Old 06-29-2013, 07:16 PM - Thread Starter
thekipper's Avatar
Hi,
Trying finish up our basement and pulled all the cable/wires into a corner in hopes of finding a nice corner stand that would be both functional and decorative to the wife.
I've drawn a blank on decent component stands as I need to put only the following in the corner:
AV receiver
PS3
360
PC
The PC is the most difficult piece as it's a mid tower and quite deep. I envisioned putting this on the bottom shelf that would be just above the baseboard thus allowing me to hide excess wire underneath.
Any thoughts on building these? I can imaging it's that hard and was think to running a 1x2 or 2x2 horizontally on each wall and then placing the shelves on top of that support. I have some excess cherry and mahogany that can be planed down to use or can just grab 3/4 plywood. I'm afraid the plywood will sag since shelf has to be large enough to hold Yamaha RX-V673.
With shelf size this large, I would plan on hitting two studs on each wall.
Any thoughts? Anyone done something similar?
Kip
thekipper is offline
Old 06-30-2013, 08:51 AM
petew's Avatar
Quoted: 25 Post(s)
Liked: 68
I think it'd be easier to build a corner cabinet out of plywood and then place it in the room. Attaching wood cleats to the wall is a bit of a pain - hard to get everything aligned and level. Plywood should be plenty strong if you support it on all sides. Use a piece of hardwood for the front edge that's about 3/4" x 2".
Can you post a sketch?
I'd make the bottom 18" or so like a storage cubby hole, with a door on it. It's a good place to put your power strip and all the excess power cables, wall warts, network switch, etc. (AKA Snake Ball).
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
Yamaha Rx V673 Receiver
